Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 07-20-2009, 11:34 PM   #1 (permalink)
Default Blade adapter? help!
Hey guys just bought some new wood blades for my Hurricane 550 --the blades ar Mikado's 500 mm---I have got them balanced and they didn't need much for the balance .. now I just noticed they don't fit snuggly into the girppes and I had to pull the brass pins out of the blades so the bolt would go through. Do I need an adapter to make them fit like there suppost to or do I use a washer on the inner part of the grippes
I 've been flying my trex 450 for awhile and now just got this 550 and I'm new on this heli so I'm not sure --just asking some of you experts that may of had this problem. thanks for listening
mightymouse is offline        Reply With Quote Quick reply to this message
Old 07-20-2009, 11:37 PM   #2 (permalink)
You use washers if the blades are loose....
Blade 500x , dx8
Two retired Gaui 550 hurricanes (Sold)
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 07-21-2009, 12:30 AM   #3 (permalink)
unless you meant the brass bushes thru the roots...those you need...
kahn10 is offline        Reply With Quote Quick reply to this message
Old 07-21-2009, 06:51 AM   #4 (permalink)
only if you use a 3mm bolt.. if using a 4mm bolt you don't need the brass bushings..
if the blades are not getting tight in the grips, there are a couple things that can correct it... both are washers either shims between the blade and grip (preferred) or washers added between grip and the nut (allows it to compress the grips enough to tighten the blade)
Hurricane 550- mCX- DX7-
AMA# 901271-
Gaui Headspeed Calc
mysticmead is offline        Reply With Quote Quick reply to this message
Old 07-21-2009, 08:26 AM   #5 (permalink)
Default reply
thanks guys --is there shimmes I can buy? or do you mean shimm it with the washers? and not sure on the mm of the bolt but it would not go in with the brass fitting in... but when I removed it --the bolt fit prefect and snug into the root hole.
thanks again
Old 07-21-2009, 09:07 AM   #6 (permalink)
shim = washer
AMA# 901271-
Gaui Headspeed Calc
Old 07-21-2009, 09:07 AM   #7 (permalink)
oh yeah... stock plastic grips use a 3mm bolt.. the CNC grips use a 4mm bolt
AMA# 901271-
Gaui Headspeed Calc
Old 07-21-2009, 12:16 PM   #8 (permalink)
Thanks Mysticmead --I have a 4 mm than ok I really apprieate the help
Old 07-21-2009, 02:48 PM   #9 (permalink)
there are "official" gaui washers http://www.readyheli.com/204352_Wash...e_p/204352.htm
Old 07-28-2009, 10:39 AM   #10 (permalink)
Those are 3mm washers
I just opened mine up to 4mm and they worked fine.
There is a new set out as well 204631 for 4mm (cnc grips) and 3mm blades.
keepnitflying is offline        Reply With Quote Quick reply to this message
Old 07-28-2009, 06:09 PM   #11 (permalink)
woah cool i didn't know they came out with those. go gaui
bobbybe is offline        Reply With Quote Quick reply to this message
