Old 12-16-2015, 01:57 PM   #1 (permalink)
Default Pitch question?
I replaced the complete head assembly on my 400 and I have a issue now even though I thought I had everything setup correctly. I slowly started spooling up the blades to check for vibrations and such and with very little head speed it lifted off the ground about a foot. It basically flew like a fixed pitch heli. If I gave it more left stick it would rise while RPM's increased and drop with a decrease in RPM's. I was lucky enough to build HS about 3 feet off the ground and hit throttle hold and put it down easy.
I did not change the settings in my transmitter for this but maybe I should? If I am thinking correctly I have way too much positive pitch? What is the best way too correct this issue as I do not want too make it worse? Thanks
Blade 120SR, Blade 180CFX, 2 Blade 400's, Blade 450X V2
Evinrude150 is offline        Reply With Quote Quick reply to this message
Old 12-17-2015, 06:47 PM   #2 (permalink)
Do you have a pitch gauge? They are quite inexpensive. How many degrees of pitch are you running?
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2
AMA 732104
MiataJohn is offline        Reply With Quote Quick reply to this message
Old 12-19-2015, 07:03 PM   #3 (permalink)
I do. I plan on seeing what it is on my next day off. I just have not had much time with the holiday coming up. I will make sure my servo's are 90*, swash level and zero pitch at mid stick and go from there.
Old 12-22-2015, 09:14 AM   #4 (permalink)
You can hold the throttle hold and move the throttle stick up and down to see the pitch change. It should be obvious if you have no negative pitch.
Is the 400 even a CP heli? Perhaps i misunderstood your situation. Don
dontrinko is offline        Reply With Quote Quick reply to this message
Old 12-25-2015, 07:39 AM   #5 (permalink)
Ahh the rigors for Flybarred heli's, by the sound of it you already know what needs to be done. I found replacing anything on my 500d head threw the entire pitch range off, and I needed quite some time to get it right.
GOBLIN 500/ DX9/ Lynx 300X / Blade 500 3d, Mcpx, McpxBL, NanoCpx.
terryv83 is offline        Reply With Quote Quick reply to this message
Old 12-25-2015, 09:41 AM   #6 (permalink)
Yes the 400 is a flybar CP Heli. I have not had the chance to correct the issue but I have almost no negative pitch. I am going to use the 4 youtube video's I know of and set the whole thing up again.
Old 12-25-2015, 09:45 AM   #7 (permalink)
The more I fly my 450X the more I dislike the 400, or I should say working on it. The 450X is a awesome helicopter BUT I have not had to work on it yet. I just charge the battery and go fly it then clean it up and put it away. I hope to get my 400 that way. I have a CNC head I got from another freaker that I am thinking about trying out.
