Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 05-06-2011, 04:38 PM   #1 (permalink)
Talking HOLY BELL HILLER!!!!
I've had a bell hiller mixer kit laying around waiting for bearings to arrive to install it on my full extreme metal head but got impatient so I decided to go with HH's way of modding it to a stock plastic head.
After completion of the mod I did the first few test hovers in the rc aircraft research and development center test flight area, and was all over the place... This thing is so responsive I was slapping her from one wall to another....
The test flight imediately moved out doors, where I was finally able to hold a desent hover for a minute or two... I didnt have time to run a full lipo through her but its like learning to hover all over again!!!
But I can tell Im gonna love it once I get used to it!! Thanks HH!!
ID:	226333   Click image for larger version
ID:	226334   Click image for larger version
Birdkiller is offline        Reply With Quote Quick reply to this message
Old 05-07-2011, 03:48 AM   #2 (permalink)
It's like having a brand new heli, isn't it!
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote Quick reply to this message
Old 05-07-2011, 09:17 AM   #3 (permalink)
Oh yeah, its not even close to the same bird anymore!!
Old 05-07-2011, 03:07 PM   #4 (permalink)
Nice BK. Is that a modded 450 canopy?
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote Quick reply to this message
Old 05-07-2011, 05:32 PM   #5 (permalink)
Is it that different? On the sim I use tiny stick inputs nut when I go outside I seem to have to use much bigger stick inputs, maybe this is the solution
toonttm is offline        Reply With Quote Quick reply to this message
Old 05-08-2011, 05:20 AM   #6 (permalink)
BK, your bird is looking sweet! Cool canopy, it amazing how a different canopy can change the looks of the helicopter. I see you trimmed the canopy quite a bit, did you notice any issue with lift using the stock motor?
It’s crazy how much more response the Bell/Hiller gives the Bee and I was just like you Bro when I first tried it. I was so use to the slow response of the Bee that I was all over the place, but on the first flight I knew this was the mod that would turn my Bee into a sweet yard ripping bird. It’s only took a few flights to get use to it and then the real fun begin…Yea Baby! I have to give a shout out to Luke, he was the primary one who got me to try out the Xtreme B/H and I have say once you go B/H there’s no going back. If it wasn’t for Luke turning me onto the Xtreme B/H mod I would never have come up with the stock head B/H mod, so if anything goes wrong it’s Luke fault…hehehe
HELIHANKSTER is offline        Reply With Quote Quick reply to this message
Old 05-08-2011, 05:24 AM   #7 (permalink)
YES! It’s that different
If you are looking for less stick inputs to get the Bee to react, then the B/H is definitely what you’re looking for. The instant response of the B/H lets you perform maneuvers that you could never do with the stock Bee head setup. For example…To do a loop with a stock Bee is almost impossible and you would need to be at least 200’ feet in the air to even pull it off, but with the response speed and control of the B/H you can do a loop with the Bee fairly easy and you only have to be 50’ feet off the deck.
This was the first time trying to do a loop after installing the Xtreme B/H mod on my Bee. It took three tries to get it down, but I finally got it and I know there’s no way I could of pull it off without the B/H mod.
[ame]http://www.youtube.com/watch?v=b1cqd8z3zK0[/ame]
Old 05-08-2011, 11:14 AM   #8 (permalink)
Now put some small lightweight paddles on their and watch her skip!
These are what I am flying now:
http://super-skids.com/SuperPaddles.htm
Old 05-08-2011, 08:08 PM   #9 (permalink)
Yes!! It makes it a completely different helicopter like Luke said, I knew it would make it more responsive from everyone on here talking about it. But Daaaaaaaaaaaaaaaannng!!!!!
On my first flight with it I cautiously lifted off and like usual countered the left pull the bee has and it came up and just about did a barrel role making it permanent fixture into the wall! Then countering that, I slammed it into the opposing wall. It surely took some getting used to.
That's what I'm running right now as well, I like them others don't so much.
Old 05-08-2011, 08:29 PM   #10 (permalink)
Thanks guys for the complements, yes it's a cheap 5$ HK 450 canopy cut down, I still have to trim it a little cleaner around the head area. Also I drilled one of the rubber bushing holes to big that slides onto the carbon post to keep it on.... And lost it during a crash, so now with only one rubber if I don't have everything balanced and tracked perfectly the canopy flops around like a piece of crap on the post all Cadywampus.
It may be a little tiny bit heavy for the bee, so since I already have it all cracked up on the brink of complete failure I think I'm gonna experiment with a bit more trimming to loose some weight.
You should have seen the crash that banged it all up, I'm talking pulling major bell hiller "G's" into thick white oak branches. Shredded leaves
raining down like confedii. Then after a huge over correction ripped through a large
branch of pine needles slamming directly into the trunk.
Ripped the canopy off, chucked the lipo about 20 feet away, broke the fly bar control arm, and a couple other pieces........man I got do get a head cam!!!! You guys would have loved it!!!
Old 05-08-2011, 11:59 PM   #11 (permalink)
Congrats! Sounds like a crash that would rivel HH
Old 05-09-2011, 10:36 AM   #12 (permalink)
Haha I dont know about that, HH has pretty spectacular crashes! Although mine was really cool looking with all the flying debris! ( chopped leaves, pine needles, canopy, battery, heli itself) Hahaha
Old 05-10-2011, 07:07 AM   #13 (permalink)
You Guys must be talking about someone else…cause I never crash. Some unexpected landing yes, but crashes…NOoo…not me…never.
Old 05-10-2011, 10:26 AM   #14 (permalink)
