Old 03-24-2014, 07:34 PM   #1 (permalink)
Default G20 belt
I have now flown the g20 numerous times...every few flights I have to tighten the belt a little or it jumps off the tail guide pulley...once it even slipped some. I have made 3 or 4 adjustments now. All my other belt tails take a RARE adjustment. This belt is big and new so I expected a fair amount of stretch but this seems like it is stretching excessively....in you guys' experience does it eventually stop stretching? I think I am going to do the torque tube conversion but just curious.
AE .50 apache, TT .90 TOW MD500, 2 x JR ergo 60, TT x50 titan, TT 50, TT 30, 3 x MTe325, MSH Mini protos, trex 450 Apache, MT cobra, Airwolf 450, Blade 400, century 50 Bell 47, MT EC135, RADIKAL G20, trex450 MD500, Protos 500
Bikersurgeon is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 08:00 PM   #2 (permalink)
I have heard a few different people complain of this issue. I have had a G20 and G30 with belts and they stretched some over the first few flights and then where good for a very long time after that. I would suspect that the boom is slipping and a simple fix is to pin it. this is normal with a lot of heli brands and you can just set the belt tension and then drill a small hole through and into the boom . Then install a small self taping screw in the boom. Make sure that the screw is short and into the open part of the belt.
Rotor-Tech Blades
Old 03-24-2014, 08:39 PM   #3 (permalink)
Pinning works well, however having 2 belt driven Raptors over the years, I just used a Scotchbrite pad to roughen the tailboom surface on the portion that is clamped by the frame. Never had a boom slip that way. Some guys would also put 1 wrap of Scotch tape around the boom before clamping, as an alternative method.
To confirm if the boom is slipping just draw a line on the boom with a Sharpie where the boom clamp meets the tailboom itself. If the line disappears after a flight or two, the boom has slipped inward....
The reason I don't pin a boom is because I like to fly in the winter, which requires a readjustment of the belt tension as the boom itself shrinks in the cold and the belt gets loose. With it pinned I couldn't do that. Consequently when it warmed up I would have to loosen the belt slightly as it would get very tight.
Rush 750, Radikal E640, Rave 90 ENV, Trex 600N, Trex 450V1, many others since '97.
Team No WhinerS, Team Renegade R/C Heliflyers
helinutz2 is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 09:15 PM   #4 (permalink)
Ahhh excellent tips...thanks guys!
Old 03-26-2014, 08:38 PM   #5 (permalink)
I pined the front and the back case. Just run a short socket head bolt in just a little longer than the plastic. Set everything up the way you want it and drill a hole through the plastic and metal tube on one side. Go soft so you do not hit the belt, then just run a bolt in. Just do it on one side on the front and the back that way if you need to change something down the road you can just drill the other side.
SAB Piuma 6S, Xnova LIGHTNING 4030/1000kV, Spirit FBL
SAB Goblin 700 Q4530-500, Sprit FBL
SAB Buddy Egodrift Tengu 3220HS/960kV, Spirit FBL
TRex 450L 6S Spirit FBL
Mr.HillBilly is offline        Reply With Quote Quick reply to this message
