Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 01-09-2013, 02:42 PM   #41 (permalink)
That was fast! Thanks guys. This is one area you guys are ahead of me on. And no need for me to try and reinvent the wheel trying to nail it fresh on my end. So, just surmising here. 11mm should do it then? I can hit that.
Old 01-09-2013, 02:54 PM   #42 (permalink)
I'm running 8mm and get 100 travel both directions with my 8910a+,you don't need as much travel with thrust.I'm at gain of 40 on my Robird.
Steve
Stevemech is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 12:29 AM   #43 (permalink)
Anyone else getting elevator bobble? I was realty hoping the skookum would work on this heli. Its not as bad as on the atom but its enough that I will swap to a brain if I have to
___________________________
Sent via Android, Tapatalk. 7HV, Atom, Warp,
rallyant is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 07:45 AM   #44 (permalink)
Default Elevator bobble
What servos are you using ? I too had an elevator bobble using align DS 415M servos I switched servos to turnigy s306g hv. The helicopter is now solid as a rock this helicopter requires very strong servos. Nothing else I could do or did do would make the bobble or my Tailwag go away.
frito169 is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 07:52 AM   #45 (permalink)
Default Sk gov
Anyone using sk gov? I get slight tail wag with gov on using Yge esc. Logging off w/ 25 gain in gov.. No wag at all w/ gov off...
vwopd is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 08:37 AM   #46 (permalink)
Which YGE are you using? The 40A or something larger?
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 09:34 AM   #47 (permalink)
MKS DS95.
Old 01-10-2013, 11:21 AM   #48 (permalink)
Using YGE 90LV w/built in phase sensor/bec.
Old 01-10-2013, 11:48 AM   #49 (permalink)
Please see post #22 by me in this thread:
https://www.helifreak.com/showthread...=481198&page=3
Double check that the governor is correctly setup. You may also want to try dropping your headspeed slightly.... maybe you're hitting a limit?
Old 01-10-2013, 08:18 PM   #50 (permalink)
Headspeed at 2800..which is plenty low for the stock setup on the warp 360...gov was setup excaxtly how you posted in the thread.. still get tail wag w/gov ON....
no wag at all w/gov OFF....hmmm weird.
Old 01-10-2013, 08:40 PM   #51 (permalink)
Do you have freewheeling or anything else on?
It only happens with the governor on?? Which firmware are you running?
Old 01-10-2013, 08:49 PM   #52 (permalink)
Freewh. on..newest sk 3.15 firmw... and it the newest yge 90LV
ONLY w/ gov on i get the tail wag..."logging off" on sk... logging on..I get tail wag w/gov on and off..
Old 01-10-2013, 09:31 PM   #53 (permalink)
That is a fairly well documented software bug in the 3:15. Also you may need to clean out your logs. Even with logging off. Some esc's have the tail wag with gov. Others don't. Have you dropped gains down yet till it looses its tail and brought it back up? Then, lower your overall head gains a few degrees down. I have heard a few guys saying that also helped on their helis.
Old 01-10-2013, 10:03 PM   #54 (permalink)
Default UPDATE
Update:
I reset the yge esc throttle ends High/Low for the 5th time..and the Led on the ESC finally went all the way dim(out) at full throttle like it does w/gov off. and NOW no tail wag with gov on... wow...
Still get tail wag with logging on no matter any adjustment...bug in skookum still.
So key...make sure LED on yge goes out at full throttle(100%).
I'm at 50cyclic gain/ 47 tail gain at 2850 headspeed w/gov on. Flys great
Old 01-14-2013, 09:56 PM   #55 (permalink)
What setting needs adjusted in the SK720 to prevent tail wag in FFF turns...?
I don't want to lower the tail gain to much or won't feel locked in higher winds...
Will lowering the HH gain in tail tab help any with this?
thanks
Old 01-14-2013, 10:29 PM   #56 (permalink)
I'm running about 50% gain at ~3900rpm with 60mm Edge tail blades.
Old 01-15-2013, 05:12 PM   #57 (permalink)
thanks
What tail servo are you running?
Old 01-15-2013, 07:13 PM   #58 (permalink)
Running all turnigy 306hv's @7.4v .05/ 3.7g Over 80 flights. No problems with them. I think I have fixed FFF wag on turns by lowing the collective mix gain to 20 from 30.
Old 01-15-2013, 10:41 PM   #59 (permalink)
Default Re: Skookum setups. Post yours please!
Statistically you have about 20 flights left before a FET Burns out and smashes your heli. That's the only reason I didn't get them. Unless they have started using better ones now?
Lower your gain to reduce wag, (I'm on 55% with ds95i) up your hold gain as well as start and stop gains to get that locked in feel you want back again.
Old 01-16-2013, 08:17 AM   #60 (permalink)
Rallyant.....
I spoke with Hobbyking personally...and they received a new updated batch of the Turnigy HV's. I see no problem with them...taking them appart and comparing them with the DS95's ..I will keep everyone updated..
Your running 55 on your tail gain? I turned mine down to 38 to get rid of wag on FFF collective turns.. Alvin suggested playing with the Rate gain first..then HH gain... which I'm looking at now..
I also think my SK gov is producing some minor wag..at 26 gain now...
