Old 07-02-2014, 07:52 PM   #1 (permalink)
Default Setting Goblin 570 - 20T - Pyro 650-65 - Heli Jive 120 HV - 2 x 6s 3000mAh 45C
i just order my first pyro 650-65 im pairing with a Heli jive 120 HV. to set it up this are the steps.. correct me if im rung..
obviously the motor is already connected to the ESC...
1- connect and take jumper out.
2- Prog Mode 1 (reset all)
3- disconnect put jumper
4- connect and take jumper out.
5- Prog Mode 4 (throttle up after 4 beeps)
6- after beeps throttle hold switch on
7- telefone ring
8- throttle hold switch off
9- disconnect put jumper
10- connect and see if motor is rotting in correct way
Throttle hold switch 15%
normal 55% flat line 2330HS
Idel1 60% flat line 2450 HS
Idle2 65% flat line 2600 HS
Lets Fly or i am missing something..
what should I set the timer or time in the air should i be expecting in mild 3d / sport flying, nothing fancy.
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 07-03-2014, 07:15 AM   #2 (permalink)
Looks good except for one thing use a 0 and the remainder flat in your normal curve for canceling bailout if you land for a moment you dont have to wait for bailout to time out. Dont forget a linear TH curve for programming!
Magneto is offline        Reply With Quote Quick reply to this message
Old 07-03-2014, 09:28 AM   #3 (permalink)
Ok, and more thing so I need to program for lipo or since is a heli jive don't need it and if so how menny beeps
Jeti DS-14 Edition
Old 07-03-2014, 10:39 AM   #4 (permalink)
Default Re: Setting Goblin 570 - 20T - Pyro 650-65 - Heli Jive 120 HV - 2 x 6s 3000mAh 45C
Lipo mode is default with the Helijive
Old 07-03-2014, 11:01 AM   #5 (permalink)
thank you..
Jeti DS-14 Edition
