Airplane Related R/C Airplanes Discussion |
07-31-2010, 09:38 PM | #1 (permalink) |
horizontal stabilizer replacement
any one what disolves epoxy? im building a funtanna 50 and the horizontal stabilizer didnt turn out correctly. had everything set up and it must have gotten bumped before the epoxy dried. now the stabilizer is 1/8 inch off center. trying to figure out if i can loosen it or if i have to start over with a new stabilizer. any suggestions would be great.
08-01-2010, 06:50 AM | #2 (permalink) |
Google lists a few things but epoxy covers a load of proprietary conconctions with additives. It makes sense to get your advice from the company that cooked up the stuff that you used. Dremel might be easiest and safest.
If you do take a gamble with random advice then you should probably test a small area first, in a well ventilated area, with respirator, goggles, gloves, etc. Most of these chemicals will eventually screw you up. (subscribed)
