Old 07-07-2009, 11:41 AM   #1 (permalink)
Default OS 91HZ-PS and 7100R
Is anyone running the new 91HZ pumped motor and the 7100R RX ?
If so will the sensor fit on the back of the motor with the pump?
Trex 700N, 700E, 600E, 500E all Vbar 5.2 Pro FBL
Dji F550 WKM Data Link 900MHZ
DJI F450 Naza/GPS FPV 5.8 vtx
TBS Disco w Core Naza GPS FPV 1.2 vtx MT Tiger motors
02deuce is offline        Reply With Quote Quick reply to this message
Old 07-08-2009, 03:23 PM   #2 (permalink)
I haven't actually tried a flight yet, but I did set up my 7100R in a Synergy with the 91 pumped and it does fit and after calibrating the 7100R for throttle range, the red sens light was illuminating when I turned over the engine, indicating that it should work fine. I have a while before I can get out to the field because I am selling the Synergy and have since removed all the electronics and the engine, but if I had to guess, I would say it should work fine. The sensor fits in between the fins on the backplate and the only thing you might have to do is put some washers under the pump assembly on the two screws that don't have the sensor bracket under them, and lengthen the fuel tube to ensure that it is seated properly on both nipples. Piece of cake, go for it!!
-J
syn90 is offline        Reply With Quote Quick reply to this message
