Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 02-22-2011, 03:48 PM   #41 (permalink)
Here's my setup...
-sk720 fbl
-CC ice 80hv
-scorpion 4035-530kv
-jr 8717 cyclic
-jr brushless tail
-flight power 12s 3350 packs (2-6s)
-looking for edge 623mm fbl blades
ps61785 is offline        Reply With Quote Quick reply to this message
Old 02-22-2011, 04:43 PM   #42 (permalink)
HugoCraft I send you this in PM but figure I post it here too.
This is with CC Ice HV80 the 14t will put you at 2155HS @ 90.3% in Gov set rpm . Now with 13t 2150 is 97.1% in gov mode.. THe CC esc is efficent at 95% to 97%. I try to stay at 95% so the gov can hold the HS at the end of the flight but you have to use the data logger to see how it doing for you, it depends on how hard you fly. 2110HS is 95.3% with 13t pinion .
Update Flying 4025-550 w/13t @ 2125HS at 96% 5:30 minutes 3D putting back 75% to 80%
Cheers, Glenn
Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's
Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's
Gernejr is offline        Reply With Quote Quick reply to this message
Old 02-23-2011, 02:52 PM   #43 (permalink)
Default low budget setup
Fusion 50 FBL
Beast
6S 5000er 30C
Turnigy T6 1100 on 12 or 13 tooth gear
Scorpion Commander
Align DS 610 on swash
DS 620 on Tail
Mainblades Edge 600
Tail stock blades
Any commends?
BR from Germany
be1974 is offline        Reply With Quote Quick reply to this message
Old 02-23-2011, 03:26 PM   #44 (permalink)
Be1974...keep us posted on your 6S experience...lots of people running 12S...but only a few running 6S!
Greg Alderman
Warehouse/ Facilities Manager
greg@helidirect.com
Greg Alderman is offline        Reply With Quote Quick reply to this message
Old 02-23-2011, 06:45 PM   #45 (permalink)
I'm actually going to try running an unusual setup (to be taken off my Kyosho EP700) until funds allow me to upsize to a bigger, more powerful setup:
Fusion 50 FBL
TotalG (or Mini-v if I can't get it to fit)
CC ICE 100
2x3S Hyperion Gx 5000mAh
Scorpion 4020-1390
Spektrum HS6040 x3 on cyclic
Futaba BLS251 on tail
Edge FBL 553mm main blades
Stock tail blades
Most likely a 12t pinion, governed to 2200-2300RPM.
I'll likely move to 623s, 12s 3300mAh, ICE 80HV on my first crash. (Still haven't decided if I want to run a 4025-550 or 4035-560 - latter seems overkill, and is heavier).
Audball is offline        Reply With Quote Quick reply to this message
Old 02-25-2011, 10:31 AM   #46 (permalink)
Here's my setup:
Fusion 50 FBL
VBar Mini V5.1
Futaba BLS451 Cyclic
Align DS650 Tail
Scorpion 4025-550 Motor
Castle Creations Phoenix 110HV
WR Super Bec
MS Composit Champions 620mm
Orig. Tail Blades
Nano 3300mah and 4500mah 6Sx2
Hell of a machine!
Cheers
Markus
Marlex is offline        Reply With Quote Quick reply to this message
Old 02-25-2011, 07:50 PM   #47 (permalink)
I finally use the following:
FBL system MicroBeast
Cyclic: Outrage BL 9080
Tail servo: Outrage BL 9188
Motor: Kontronik Pyro 700-52
ESC: Kontronik Jive 80HV
Blades: will test the Zigsaw blades(weigh less than 114 gram each)
Batteries -> will use the Hyperion 2950 mAh packs (2 in series) for 12S setup at the beginning(have those on the TRex 500) and might change to 3300 mAh packs (depends on flight time and experience)
Receiver battery is a Hyperion 2S 25C 2500 mAh pack.
Running the 12 t pinion
Head speed about 2200 at 80% throttle (pushed it up to 2300 at 85%).
Flight time hard -> 4:30 minutes with about 30% left in the packs.
im4711 is offline        Reply With Quote Quick reply to this message
Old 02-27-2011, 11:44 PM   #48 (permalink)
Couldn't edit my original post, so here is my updated setup:
motor: Scorpion HK-4025-550
ESC: CC Phoenix Ice HV 80
cyclic servos: Futaba S9452
tail servo: Futaba S9254
gyro / FBL: uBeast
blades: CY Radix 600, RotorTech 610
tail blades: stock
misc: (Lipos / BEC / Rx)
2 - Turnigy Nano-tech 6s 3000mAh
CC BEC Pro
Futaba R6008HS
AUW: ??? (still ordering parts & waiting for my kit)
Doug B.
dougb is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 03:21 PM   #49 (permalink)
Full size Vbar 5.1 pro
Align ds610 cyclic
Futaba 9256 tail
Hyperion 4035 500kv 16T - CC Ice HV120- 12s
CC pro BEC
Edge 623 FBL blade
Dont have lipo yet, i am current flying on my friends loan packs, going to get Voltz 3700amp 12s soon,
Love it
lowflyer101 is offline        Reply With Quote Quick reply to this message
Old 03-16-2011, 02:01 AM   #50 (permalink)
Wanted to ask .. I set up my cc esc with Hyperion 740kv motor with 14t head speed 1950, 2150, 2250 but the software day I'm running around 82% efficiency .. Will that damage any thing would should I do? It should be 92-95 efficiency ??
kevinbj1 is offline        Reply With Quote Quick reply to this message
Old 03-17-2011, 11:50 PM   #51 (permalink)
Blade Forum Support
Default here are mine
CC HV 85 govern @ 1953, governor gain @ 10
CC BEC PRO wire to run off of one 6s pack
(black) V-Bar 5.1 update
9080's on the cyclic and on the tail 9188 ( all are running on 8.0 volts)
12s (2-6s) 3000
Scorpion 4025-630kv
Rotor Tech Main Blades and factory tail blades
Spectrum SATS
God is Good
Isaac
tntburnett is offline        Reply With Quote Quick reply to this message
Old 03-21-2011, 02:18 PM   #52 (permalink)
Scorpion 4025-630
Castle Ice HV80
2 - Nano-Tech 6S 3300s (12s)
Microbeast with Spectrum Satellite receiver
Edge 603 FBL blades
3 - DS610s
1 - DS 650 or 9188.
"Gravity is a myth, the earth sucks"
Trex 700N, 600N, Fusion 50, Trex 500. All Microbeast FBL.
kodiak is offline        Reply With Quote Quick reply to this message
Old 03-21-2011, 02:30 PM   #53 (permalink)
A single satellite on anything larger than a "mini" heli is definitely not recommended....
My setup (at the moment...):
Turnigy T600 880kv
CC ICE 100
AR7000
2S LiFe RX pack
Spektrum regulator for tail servo (JR DS8900)
Hyperion DS20 FMD cyclic servos
8S 5000 (brand undetermined at this point)
Blades undetermined at this point.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 03-21-2011, 02:33 PM   #54 (permalink)
Fusion 50 FBL
Futaba CGY 750 / R6203SB RX (Shipping right now
9080 cyclic
9188 tail
Kontronik Jive 80HV
CC Bec PRO
X-Era 4025-3Y 560kV 6mm long shaft (thanks to silverbullet)
14t pinion -> might go 13t or even 12t (will see later)
EDGE 603mm FBL -> 623 once i can find some ;(
EDGE 95mm tail
12s - Volts 3300mah 35c/Desire Power 3300mAh 35C
Fusuno Canopy - to match my Vel 90
harryboe is offline        Reply With Quote Quick reply to this message
Old 03-21-2011, 03:49 PM   #55 (permalink)
Sorry to say, you're not alone, I picked up that canopy & the red G10 Fusuno Frames.
kazager is offline        Reply With Quote Quick reply to this message
Old 03-26-2011, 09:08 AM   #56 (permalink)
Default Align 700MX 510kv setup
Hi all
I have a fusion50 with the following
full size v-bar
Castle ICE 100 HV
Align 700MX 510kv with a 15 tooth pinion
2x 6s3300mAh nanotech packs setup as 12s
JR 8717 on the head
600mm V-blades
hover head speed is 2200
full pitch is 2050
max amp draw is 70Amps
only have one flight on this setup but it was very happy.
when the weather gets better I will ring it out and report back
This motor is interesting because this is the kit motor for the Trex700E so you should be able to find them used for a fair price
JTJ
justin4u is offline        Reply With Quote Quick reply to this message
Old 03-26-2011, 02:26 PM   #57 (permalink)
Outrage Fusion 50 set up
Atom 6HV motor 540KV 6mm (protruding out length 34mm) with 14T 6mm pinion gear
Hobby Wing 70HV ESC
Hobby Wing 8A High current BEC
MKS BLS 950
MKS BLS 980
Micro Beast X FBL
Spektrum 7600 receiver
Turnigy nano tech 4000mah 25c 4s x 3 = 12s
Turnigy nano tech 3300mah 25c 6s x 2 = 12s
Align 2650mah 25c 6s x 2 = 12s
Outrage 3000mah 25c 6s x 2 = 12s
Compass Model Warp 360, Trex 500, Outrage G5, Outrage 550,
Outrage Fusion 50, AleeS Rush 750, AleeS Rush 750 evolution.
Radio man is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 12:01 AM   #58 (permalink)
"X-Era 4025-3Y 560kV 6mm long shaft (thanks to silverbullet)"
Harryboe How do I get long shaft for X-era?
Cheers, Glenn
Old 03-29-2011, 09:31 PM   #59 (permalink)
https://www.helifreak.com/showthread.php?t=292360
RusElKnight is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 03:38 AM   #60 (permalink)
Wink
Harry, thanks for the Props,
I recoment to juse the 12T or max 13T Pinion,
with the 14T, the Headspeed and power will be insane, coz the motor shows no Boging,,
13T with 75% ESC seems to be extreem powerfully, that what i flying it at.
silverbullet is offline        Reply With Quote Quick reply to this message
