Go Back   HeliFreak > R/C Electronics Support > Spartan RC > Spartan Vortex
Spartan Vortex Spartan RC - Vortex VX1 Factory Support Forum
Old 04-07-2014, 03:44 PM   #1 (permalink)
Default Vortex V3.00 settings
I Like to create a thread, which I just did too see your guys settings with the new V3.00 I already saw a lot of guys from the compass team flying with it.
I will update mine bird soon and I hope v3 can resolve issues I have with my 6HVU which it probably can
Verstuurd vanaf mijn Nexus 10 met Tapatalk
MrEmail is online now        Reply With Quote Quick reply to this message
Old 04-07-2014, 04:12 PM   #2 (permalink)
Member
All I did was select my model size from the Heli Wizard, select 3D from the Style Wizard, and chose my head type in the Rotor menu. Only things I adjusted after that were Tail gain, Mid-Agility (increased it by 5%), and D Elevator (increased it to 80). That was it.
Though I did try the BertK Style setting. While very "quick and agile" I'll describe it, I had to back off an use the 3D Style instead.
Old 04-07-2014, 05:32 PM   #3 (permalink)
Is a re setup required after updating?
Edit....
Just read the other thread
Team Xnova for revolutionrc.com.au
Alees Helicopters Australia
Feral is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 07:26 PM   #4 (permalink)
I dont use the gov right?
I saw in the menu it was enabled by default, i disabled it. I selected esc for throttle type.
Now if it is working, i have a hyperion and eagletree rpm sensor. Which ever one will work.
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 07:37 PM   #5 (permalink)
Member
No E-gov yet.
You can choose ESC or Analog for the servo type if you're running a brushless ESC. Or the KBUG option for Kosmik ESCs if you need to.
Check out the new User Guide.
http://www.spartan-rc.com/products/v..._guide.php?p=5
Old 04-07-2014, 07:55 PM   #6 (permalink)
I read it and used it for setup, just was not clear if it is available or not. Also the default settings are set with it on. But like i said i turn the gov off and just input my rpms.
Old 04-07-2014, 08:05 PM   #7 (permalink)
My GOD !!! I have to re-setting its all
ID:	500958   Click image for larger version
ID:	500959   Click image for larger version
ID:	500960   Click image for larger version
ID:	500961   Click image for larger version
ID:	500963   Click image for larger version
ID:	500964   Click image for larger version
w_prasit is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 08:36 PM   #8 (permalink)
I think the the default for governor is off.
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 08:57 PM   #9 (permalink)
Not for me either...
FNFAL is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 09:06 PM   #10 (permalink)
Are we talking about the same thing? In Setup::Throttle::Governor Type the governor defaults to Inhibit. When it is inhibited it does not matter what the individual flight modes are as the entire governor function is disabled.
-Angelos
SPARTANRC - R&D
Old 04-07-2014, 09:17 PM   #11 (permalink)
A couple of questions for set up menue as instructions are not clear
1. Throttle servo type- do we need to select analog here or esc. In previous versions we were advised to select analog
2. Heli wizard- how do you categorize the different size machine by blade size or heli size?
for example for a 450 heli we should select 325+ blade size
for a trex 500 or protos 500 do we select 500+ ? these heli's run 425mm stock blades?
dl5973 is offline        Reply With Quote Quick reply to this message
Old 04-08-2014, 03:39 AM   #12 (permalink)
-Angelos
This is the section im talking about. This one was set to on. I had to select off and then i put my rpms in there.
In the setup portion all i did was select esc.
Old 04-09-2014, 08:37 PM   #13 (permalink)
I found governer default is on
Old 04-10-2014, 04:01 AM   #14 (permalink)
I was talking about the setup governor type option. It is 'Inhibit' which forces the governor off no matter what the individual fligth mode options are.
SPARTANRC - R&D
Old 04-10-2014, 12:15 PM   #15 (permalink)
Yes, I got it
Old 04-10-2014, 12:45 PM   #16 (permalink)
might want to add a note in the manual that the e gov is not active. and not to use it.
thats why i was confused and excited at the same time
Old 04-10-2014, 07:11 PM   #17 (permalink)
I'll know how it goes tomorrow, as the updates are all done now. Thanks once again for doing the update video bob. Even though I've done it a few times, I always have to refer to your video, which makes it nice and straight forward.
As you advised Bob, I simply made a spread sheet with all my set-up values, like servo trims, directions, etc, etc, for each sub section, and after the update I just put all those settings and numbers back in, and everything seems to be spot on.
My settings for my 550 are 550+ in the heli wizard, and 3D for style, with my normal previous tail gain. No other changes so far as I have not flown it. Perhaps I won't need any.
If someone could just remind me where I put in the rough headspeed for vibration management. Is it in the section shown above in fusionsx00's picture. That's where I have put in 2400 for all four flight modes. I know it will be in the manual somewhere, but so far I'm hoping I won't have to read it, lol.
Cheers
Sutty
Regards, Sutty
sutty is online now        Reply With Quote Quick reply to this message
Old 04-26-2014, 05:52 AM   #18 (permalink)
Here's my current Logo settings.
ALIGN TREX 700L DOMINATOR
ALIGN 800MX MOTOR & CC 120 HV
ALIGN BL815H & BL750H SERVOS
MIKADO VBAR NEO & JR XG14 & RG031BX
a2544321 is offline        Reply With Quote Quick reply to this message
