500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-03-2011, 03:11 PM | #1 (permalink) |
how to make my trex 500 wild?
hey guys,
since day one i found my trex 500 a little sluggish. now, after flying my 550 for a while, i'm pretty sure it really is. what kind of mods can i do so that the heli will have more power? the heli flips very slowly, for example. i'm at 100% TC and it still is slow. should i have a new motor? a new pinion? which ones? thanks a lot. |
12-03-2011, 03:30 PM | #2 (permalink) |
FBL & 500MX motor with a 13t pinion and you will
I never liked my 500 as a FB, it now gest flown more that any of my other helis, well over 1000 flights. |
12-03-2011, 03:55 PM | #4 (permalink) |
If you have a flybar heli put smaller paddles on it. Makes the heli quicker
Get your head speed up.... Make small changes as you go Try those two things and see where your at. If you want you can give it more pitch
Tarot 500/550 9s / Tarot 450ProV2 4s / 600E V1 8s Academy Of Model Aeronautics 98418 If Align put their name on a pile of dog crap stuck 2 blades in it and packaged it in a super combo, people would get in line to pre order. I just dont get it |
12-03-2011, 06:42 PM | #5 (permalink) |
i also went fbl. align head, 3 gx and 500mx motor. i now fly a hot rod heli. i also changed the tail to tt.but i don't think that made a big difference
12-03-2011, 06:49 PM | #6 (permalink) |
Nope, stock esc at 100% throttle curve works great. The Scorpion was the hot motor, the MX is now the leader.
FBL also decreases the load on the motor/batteries and allows for much higher pitch on the collective/cyclic for increase agility. You will not be disappointed. |
12-03-2011, 08:10 PM | #7 (permalink) |
Get a battery charger that can measure the internal resistance of your packs like a icharger.
Your packs are probably toast. High resistance kills performance. Dido with the 500mx / 13t, 3GX FBL, TT, if you don't already and Mavrikk wide chord blades and run it at 2700 rpms, then you'll have a rocket ship |
12-04-2011, 05:11 AM | #8 (permalink) |
isn't the 500mx meant for a 70-80a esc? are you guys sure i won't burn my 60-70a esc? i saw a talk in another forum about the scorpion 3026-1600kv motor on the trex500 with great results. it is a little more expensive than align's, indeed, but it was made for a 60-70a esc. i wasn't willing to invest a fbl on my trex500. would only the 500mx (or the scorpion 1600kv) make a difference? Thanks! |
12-04-2011, 06:12 AM | #9 (permalink) | |
Trex 250se 3gx Trex 500 Beastx, Ice 75 9650's & 9257 500mx, Edge main & Kbdd tail blades Mini Titan e325 Beastx Airtronics 94809 cyclic, 9257 tail, Ice lite 50/scorp 2221-8 Edge mains, Kbdd tail blades Jr Vibe 50, Beastx, all Futaba servos OS55hz, Hatori sab 50, Radix |
12-04-2011, 06:22 AM | #10 (permalink) | |
i definitely need a log. which ones would you recommend? thanks. |
12-04-2011, 06:29 AM | #11 (permalink) |
I can only speak for the the data logging on Castle Creations esc's.
12-04-2011, 10:15 PM | #12 (permalink) |
i run a scorp 1600, ice 100, 15 tooth pinion, gov at 2600 2700 and 2825 and it halls ass, kbdd paddle in the back hole and it rolls supper fast. motor esc and batt come down almost cold.
Trex 500 ESP DFC FBL BLADE 130X GOBLIN 630 CC 120HV, Scorp 4225 610Kv, Outrage servos, Skookum SK720BE GPS combo |
12-05-2011, 07:45 PM | #13 (permalink) |
+1 on kbdd paddles for a quick cheap way to increase roll and flip rates. Night and day difference from the align paddles
Matt |
12-05-2011, 09:22 PM | #14 (permalink) |
Don't domesticate your heli !
12-06-2011, 01:10 AM | #15 (permalink) |
12-31-2011, 12:24 PM | #16 (permalink) |
alter the pitch degrees and cyclic degrees in your tx that should sort it
12-31-2011, 02:46 PM | #17 (permalink) |
i've bought a 500mx motor and i'll try it very soon. let's see what happens. thanks.
01-01-2012, 11:34 AM | #18 (permalink) |
I run a Scorpion 1400 KV motor with a 15 tooth pinion Was $79.99 from helidirect. Governer in ST1 is 85% 2711 HS, ST2 is 100% 2919 HS flat curves. Doing Mild 3d i get no bog and crap tons of power. I don't know if you run expo but if you don't add some positive expo to increase flip and roll rates. Also I found when mine was seeming sluggish I added travel to the heli through the radio and increased my cyclic from 65% up to 85%. Super fast now. guys at the local club were amazed at the difference. The total pitch on my blades from 65% to 85% was 8 deg to 10 deg. hope this helps. Oh I also run a cheapie Turnigy 70 amp esc from hobbyking. Close to 200 flights at this point with no problems.
TREX 500, Spektrum DX7, Scorpion 1400kv motor, Align speed controller, Spartan Quark Gyro with a DS520 for the tail, DS510's on cyclic and Turnigy 3300 mah 35C 6S, Fusuno EX canopy |
01-01-2012, 11:48 AM | #19 (permalink) |
"+1 on kbdd paddles for a quick cheap way to increase roll and flip rates. Night and day difference from the align paddles"
The KBDD Dampers will help too. When my Trex 600E was still flybarred, the KBDD Paddles (TWEE's on the 600) and a set of the orange dampers really sped up the cyclic, with no sacrifice in stability.
KBDD-Team Captain, JR DFA Team Pilot. Forza 450, Forza 600N, Forza 700, Compass 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Steam 550 and 600, OMP M2 (and anything else I can get my hands on...). |
