Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Old 04-17-2014, 06:48 AM   #1 (permalink)
Default talon 90
Is it safe to use a talon 90 in my goblin 500? I still read a lot of horor story with cc esc. I don't plan to use the internal bec
Gaui x5,Gaui X7, trex 250, compass 3D+,Wiplash gasser, Synergy n5c tt, goblin 500
yannick is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 07:45 AM   #2 (permalink)
yes
Goblin 500 / Goblin 380 / OXY4 / Mini Comet / OXY3+ / OXY2 / OMP M1/ .. DX9
Frankel is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 08:23 AM   #3 (permalink)
I have been using my Talon 90 for almost a year now and never had any problems with it.
Goblin 500, Align 500 Pro DFC, 450L Dominator
Golferkris is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 08:32 AM   #4 (permalink)
Mine's great. Quantum 4120/1200 17T pinion and 2500 RPM. Flys great!
G.
T-450 Sport FBL, T-550 V1 FBL, Red Goblin 700. Goblin 500. 350 QX. Bunch of little Blades, and Planks. DX8 G-2, Retired Full scale Jet Plank Driver, U.S. Navy Ret.
garyji is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 10:17 AM   #5 (permalink)
works fine, i also use the internal bec
just make sure you have the right pinion for your style/headspeed
2200-2400 rpm, quantum 4120-1200, 17t
mr. mark is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 08:52 PM   #6 (permalink)
I wouldn't run it with a high KV motor, like the scorp 4020-1350 with it. I had 3 fry on me before i changed to the Edge 100
SAB Goblin 500 Quantum 4020-1200 CCEdge 100 Silverline VBAR
SAB Goblin 570 XNova 4025-560 YGE 90HV JR 8917HV Silverline VBAR
DX18. THERE IS NO SPOON
Merse is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 11:24 PM   #7 (permalink)
What bec are you using with the edge 100? I take it it's the lite version of the edge?
terryv83 is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 05:37 PM   #8 (permalink)
Default talon 90
I would think twice. Just built a g500 with Quantum 4120-1200, Bk servos, mini Vbar and Talon. The Talon made my vbar brown out big time just hovering last weekend and it crashed. The log shows that the bec has struggeled several times the 15-20 flights i have had, and that's what you get when you cheap out on an important piece of hardware. I am going for a Jeti Mezon 90 rpm now, the one in my G700 has been flawless.
Logo 800 Xxtreme, Signature 4540, Kosmik 200, BK7001/8005, Neo
Logo 690 SX v2, Scorpion 4525, Jeti Mezon 130, MKS960/BK8005, Neo
Urukai Carbon, Scorpion 4530, Kosmik 160, Neo
Trex 700N, TT 1.00RL, Vbar
RunarSL is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 07:18 PM   #9 (permalink)
threads like this make me so hesitant to stick with the talon 90, especially with the scorpion 1350. To those of you with issues, did you have any warning from previous flights like super hot components post flight, etc?
would hate to wreck a heli over a component failure - i'm plenty good at wrecking them on my own, thank you!
WonderedUnder is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 07:38 PM   #10 (permalink)
Default talon
I think i wiil go with the yge 120 lv......peace of mind
Old 04-19-2014, 05:33 AM   #11 (permalink)
FWIW I run a stock Blade 550x motor in my G500. It's spec's to pull 110a but flies fine on my Talon 90.
I_Bent_It is offline        Reply With Quote Quick reply to this message
Old 04-19-2014, 05:47 AM   #12 (permalink)
my set up:
Pulse 45c 4500mah batts
BK mini servos
iKon flybarless
Quantum 4120
>TALON 90<
using the iKon governor I have zero issues with my talon 90 and well over 200 flights, I will say I constantly contemplate of upgrading the esc for simple 'piece of mind'
Sab Gobbles! 500 swinging 550s
Blade 450 x
Blade mcpx BL (retired)
n3cr0 is offline        Reply With Quote Quick reply to this message
Old 04-19-2014, 04:57 PM   #13 (permalink)
I have the talon 90 in my trex 550 not had any issues and that's with the 730mx which is 850kv , sure that's a motor from a 700 ...
If it's good for a 550 then it will be ok for a 500
Dx9, Blade Nano ,Trex 450pro ,Trex 550L , Trex 700
aevans692 is offline        Reply With Quote Quick reply to this message
Old 04-19-2014, 05:58 PM   #14 (permalink)
My problems have nothing to do with running a demanding motor. The problem is with the bec.
Goblin 700 Competition - Scorpion 4530 500kv - Jeti Mezon 130 - Vbar
Goblin 500 - Quantum 4120 1200kv - CC Talon - Mini Vbar
Spektrum Dx18
Old 04-20-2014, 02:51 AM   #15 (permalink)
The built in Bec with the talon 90 works well like I have said never had issues with mine , from time to time all parts can fail even the premium components.
Old 04-27-2014, 11:44 PM   #16 (permalink)
Default talon 90
I also run the Talon 90 in my Goblin 500 with the Quantum motor.
About 30 flights, no errors in my log.
But you can backup your bec like Bert does with a Backupguard from Scorpion or some caps...
hydro-heli is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 08:18 AM   #17 (permalink)
I'm pretty sure Bert does not use the backup guard. From my experience, the Talon has no log, so you must be speaking of your FBL system log.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 11:43 AM   #18 (permalink)
Default talon 90
Hi
I mentioned my telemetry log in my Futaba radio, that I had never experienced any voltage drops (errors) in the logged values.
I remember a video with Bert comparing the G500 setups he uses. One with the Jive and a HV BEC and one with the Talon and a Backup Guard.
Regards
Oliver
Old 04-28-2014, 12:03 PM   #19 (permalink)
Default talon 90
I'm pretty shure he uses one!
Watch this video, just before the end (23min) he shows the two setups he has.
[ame]http://youtu.be/E437PtZdMQc[/ame]
Regards
Oliver
Old 04-29-2014, 08:17 AM   #20 (permalink)
Regards
Oliver
That was made over a year ago. He no longer runs that setup. That was a test setup.
