Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 03-22-2012, 12:08 AM   #1 (permalink)
Default Spin 16300kV - 8T or 9T w/o governor?
Hey folks,
So I've upgraded my HP05 to an xtreme spin 16300kV motor. I bought both a 8T and 9T pinion, and am using a XP7A with stock firmware. Aside from flashing the firmware (I don't want to spend $$ to buy a BLheli programmer just yet), would I be better to run a 8T, or a 9T and limit the throttle curve to a certain percentage below 100?
Also, I picked up some Loctite 609. If I wanted to remove a pinion after using it, can I just use a pinion puller, or is there a better method?
Thanks for any guidance!
Zangetsu57 is offline        Reply With Quote Quick reply to this message
Old 03-22-2012, 05:24 AM   #2 (permalink)
I have an 8T pinion on mine and I fly 85% flat with great results. It runs even better now that my ESC is flashed.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 03-22-2012, 08:35 AM   #3 (permalink)
Originally Posted by Zangetsu57 View Post
Hey folks,
Just as Craig, my buddies flashed ESC 16.3 runs great in the 80-90% range governed.
I would be hesitant to run it non-flashed at or near 80%, should be higher to ensure good cooling and motor efficiency. I would do a short flight and get a good feel of the ESC and Motor to make sure they are not too hot. I would expect a good bit of bogging running it that low.
I recommend the 8T w/ the 16.3, especially if you desire lower HS. I think at 100% its somewhere in the 6500-7000 range. This motor IMO is best paired with the 8T as it has some descent torque. I think this was the first motor I performed descently tight tic tocs with.
To remove an old pinion that has already had 609 used on it, simply heat with a lighter or hit soldering iron for a good bit, and pry it off. (I use a small flat head under the pinion). If its hot enough it should almost slide right off, so don't pry hard.
MSH PRÔTOS
Rave Ballistic 635
Spunjah413 is offline        Reply With Quote Quick reply to this message
