Old 09-09-2012, 03:44 PM   #1 (permalink)
Default Help with 3GX setup and sluggish servos
I am getting closer to getting my newly-built trex 450 in the air. I am doing DIR setup (per youtube videos, thank you) but for some reason my aileron/elevator (the two servos mounted next to the battery) respond -very- sluggishly to input from my tx's right stick, with very little travel distance up and down. However, when I move the left stick for throttle, all three servos move their full range up and down, moving the swashplate evenly up and down. Using stock align servos, AR6210 rx and DX6i. Any ideas?
EastR84 is offline        Reply With Quote Quick reply to this message
Old 09-09-2012, 08:43 PM   #2 (permalink)
make sure everything in ur radio is set up correct and then go on ur computer and make sure everything is set to default and then u can adjust as needed to correct the sluggish servos.
Sent from my EVO LTE using tapatalk 2.
Blade 130X, Nano CPX "AKA JUNK", DX9
TREX 150DFC, TREX 550 DFC w/AR7200BX
TREX 600N DFC w/3GX
TREX 700E PRO DFC w/AR7200BX
songer121 is offline        Reply With Quote Quick reply to this message
Old 09-10-2012, 08:02 PM   #3 (permalink)
Servos next to the battery are pit and aileron.
Make sure you have 120 deg swash picked in initial setup.
Leave servo horns off till your in dir setup and at mid stick.
Set TH PC 0 50 50 50 100, it makes it easier to setup your cylcic and min max pitch.
Throws will be set to the 8deg. cyclic while in setup. Outside setup you'll see more like 12 - 13. That's when you set your limits, in FM setup.
For 2.1 throttle range setup disconnect two motor wires and make sure you have a linear pitch curve.
Basics, Limits set to the max to the point it's about ot bind makes for tight flips and rolls
Control rates determine how fast cyclic responds to input and for 2.0 set cyclic expo in the software at 2 and for 2.1 I use TX expo
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
