Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 05-03-2013, 06:39 AM   #1 (permalink)
Default Pinion upgrade question, having an issue...
Ok, so I bought the complete 19T pinion uprade for my second NX4. However, as I spin the main gear by hand there is A LOT of resistance for a good 1/3 turn then it eases up a little but not all the way like my other NX4 with stock gears. The clutch bell looks like it has a little more runout than the other stock one as well.... Anyone else experience this? I shot Empire and email and will see about getting a new kit to try out.
aviator493 is offline        Reply With Quote Quick reply to this message
Old 05-13-2013, 12:35 AM   #2 (permalink)
Actually, I'm dealing with this right now.... The stock pinion is 17, I believe, which fits just fine... Well, Of course the 19t pinion is larger, and the holes for the starter shaft/pinion/clutch bell are not oval... I just eyeballed it, and it appears, the new RED motor mount is set up for the larger pinions... BUT, I did not measure this... I just matched up the stock silver motor mount, to the red motor mount, and it looks like the red "sticks out" a little further to accommodate the larger pinion, and be in line with the starter shaft....
my guess is you/we will have to widen out the holes for the starter shaft/pinion so we can set the correct gear mesh... The tough part, is making sure the starter shaft/clutch line up correctly....
This is just my guess, I'm working on mine now, and noticed how much bigger the pinion was, in relation to the stock pinion, so came here to see what others have done with their "upgrades."
Good luck... hopefully someone who knows for sure can let me know if I'm correct or not...
Joe_Breezy
Diablo, Shape 9.0, Goblin 700 & 380, Sylphide 90, Srimok 90N x2, Srimok 90E, Dune, Vibe 90SG, TDR, E-Aurora, Logo 600SE & 500SE, T600 ESP, T600NSP, Synergy E6 & E5, Warp 360, Gaui NX4 & X4,T500, T450 Pro FBL, 180CFX and 130x
Breezyjr is offline        Reply With Quote Quick reply to this message
Old 05-13-2013, 12:05 PM   #3 (permalink)
I did a comparison between the stock and upgraded Red 19t pinion motor mount. Difference is difficult to measure, but as a whole the Red mount is 0.6mm longer than the stock, which makes sense.
But I tried to measure the "gap" here in the pic and got 1.3mm. So I think widening the mount holes for the pinion/starter shaft by approx 1mm should give you the correct gear mesh.
Take a look.
Good luck.
Joe_Breezy
Old 05-19-2013, 01:46 PM   #4 (permalink)
The 19 and 20 tooth pinion kits come with everything needed to do the entire job... There is absolutely no need to modify anything. It's all bolt in and go fly and have fun.
If your running a governor that requires the gear ratio to be entered into its parameters don't forget to change that as well in order to get the correct outcome..
Good luck. In sure your gonna really like the end result of that 19 tooth pinion.
I've tried all three now and the 19 is what I think is the best combination of torque and head speed
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote Quick reply to this message
Old 05-19-2013, 07:05 PM   #5 (permalink)
Default Re: Pinion upgrade question, having an issue...
I'm using the complete kit, that's the problem. It's too much to fly. JC at empire is always helpful and I am going to send my kit in and try another to see if that fixes it.
Sent from my DROID RAZR using Tapatalk 2
Old 05-19-2013, 08:02 PM   #6 (permalink)
Did you install the red clutch block too?
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 05-19-2013, 08:09 PM   #7 (permalink)
Yep, it's a complete kit and all parts used. Could be a bad high spot on main gear, though I thought I had ruled the gear out. Wouldn't hurt to try again!
Old 05-19-2013, 08:17 PM   #8 (permalink)
Hmm ok, just a thought.
Old 05-19-2013, 08:58 PM   #9 (permalink)
Thanks anyway!
Old 05-19-2013, 09:00 PM   #10 (permalink)
You didn't take away take apart your main gear/auto gear/ one-way assembly did you? Like remove the sleeve?
Old 05-19-2013, 09:02 PM   #11 (permalink)
Also per Bobby when you install everything Keep it loose until you get all lined up perfect so the clutch bell spins easy then tighten everything
Old 05-19-2013, 09:33 PM   #12 (permalink)
Mmmm, I may have if I changed the main gear.... Otherwise, I had the issue with it factory assembled as well.
Old 05-19-2013, 09:34 PM   #13 (permalink)
Yep, did that with both. The bone stock NX4 is very smooooooth!
Old 05-20-2013, 06:01 PM   #14 (permalink)
I've just Built a NX4 for a friend, a super combo all stock except for 2 upgrades!
After 30 flights, All I can say is! I want one! That's a great heli!
Gaui X5, TRACX FBL! Great Heli!
Radio JR XG14 Great Radio! http//:www.fbhelimodelismo.com.br
cyberjoeone is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 10:21 AM   #15 (permalink)
Take a look.
Attachment 420071
Good luck.
Joe_Breezy
I had no idea the red motor mount was different and didn't even think to check it. I bought the red motor mount only to stiffen the frames a bit and it binds the clutch bearing block pretty hard. I guess I'll go back to the stock mount. I wish they had noted that the red mount was for use with the upgraded pinion set only.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 10-16-2013, 07:35 PM   #16 (permalink)
I know this is an old thread, but for those like me, who are keen to overlook the obvious.. the clutch block mount for the 19/20t pinion upgrades is keyed, with an arrow on top pointing forward. Mounting it backwards will lead to much head scratching
Compass | MKS
[ eXo | Chronos ]
jaofos is offline        Reply With Quote Quick reply to this message
