Old 08-21-2012, 05:50 PM   #61 (permalink)
From what I've read searching the forums, chances are my problem is vibe related.
Most vibe related BeastX issues are solved by simply re-mounting the unit using 3M 4011 tape instead of stock tape.
Also the boom support has less vibes on it - you can feel the difference by removing the main blades and feeling both positions under power. That and the fact that the unit on the boom support can't touch the frame sides as it might under the frame during hard manoeuvres.
So lots of reasons really
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 08-21-2012, 05:52 PM   #62 (permalink)
Originally Posted by bradharvy View Post
May I ask, what would it matter, tilt wise flying, where your bx is?
The issue with the stock location is that it's a very tight fit in the frame! The opening in the frame is 29mm, and the AR7200BX is 28mm. .5mm clearance on each side? If it isn't installed EXACTLY right, it's going to be touching the frame. This transmits vibrations to the unit, which it interprets as movement, which results in drifting / tilting.
I agree it looks nice tucked in the frame, but it is not a very practical place to mount it IMO, considering the dimensions.
Chris Boultinghouse
JustPlaneChris is online now        Reply With Quote Quick reply to this message
Old 08-21-2012, 05:55 PM   #63 (permalink)
Chris
I went with your pig tails idea but as I'm crap at tying knots my floss kept coming undone
Went back to the trusty zip-ties in the end
Blade 180CFX | 300X
Old 08-21-2012, 06:01 PM   #64 (permalink)
Steve, it takes some practice! The real trick with floss is to go around and tie a knot, then take the ends and go around again, and tie a 2nd knot.
Chris Boultinghouse
Old 08-22-2012, 12:17 PM   #65 (permalink)
Very good reasoning! Lol. Wasn't really thinking about the unit being too close to the frame. Still new to fbl controllers. Right on. I will re-think.. The first thing HH asked my brother when he called is, did you remount the bx? Duno if that was good or bad, or they were trying to weasle out of a repair! take care..
Happy flying ....Brad
Trex 550e v2,BLADE 450X ,130X NEVER! McPX BRL, 120DO2s, McPX, Stryker , Edge 540qq,UMX BEASt, Crak Yakx2,
YAK 55M 35CC,A.W. yak 54 20CC,3dhs 330sc 57inch, ALL ON MY JR9503
bradharvy is offline        Reply With Quote Quick reply to this message
Old 08-22-2012, 12:45 PM   #66 (permalink)
One flight and already modding. Thanks for the tips in this thread, I like the mount better.
ID:	342691   Click image for larger version
ID:	342692   Click image for larger version
Gaui X5 sweet! Warp 360 KST, B4503D Savox- all beastx, 250 SE flybarred-current shelf queen, 130X, Mcpx BL, Nano cpx, Mini Dragonfly, DX8 AMA #982022 If you get to thinking you're a person of influence, try ordering somebody else's dog around.
shreddedpaper is offline        Reply With Quote Quick reply to this message
Old 08-22-2012, 02:01 PM   #67 (permalink)
I can confirm that relocating the BX on different mounting tape has cured my tilting problems - I can now actually fly it again without risk of crashing!!
Must be getting vibes somewhere even though they aren't apparent - maybe some bearings wearing or something. Anyway the BX is less susceptible to vibe problems in its new place so thanks for posting this in the first place Jaydekay and sharing your idea.
Blade 180CFX | 300X
Old 08-22-2012, 11:10 PM   #68 (permalink)
Originally Posted by Hubschrauberpilot View Post
DO NOT REMOVE THE CABLE TIE FROM THE AR7200BX !!!
I have done it, and soon encountered a permanet drift/roll to the right at higher speed (even with carbon blades).
The beastX obviously needs to be strapped to the (weak) frame on this little light heli !
Wow! This exact same thing happened to me. Fortunately it only cost a main gear. I put another cablie tie on and everything is good again. I have it as tight as It goes, and the frame touches both sides of the beastX firmly. Perhaps without the tie only one side of the frame touches which causes the issue. I cannot verify unless I take the tie back off.
dr_boom is online now        Reply With Quote Quick reply to this message
Old 08-24-2012, 04:12 PM   #69 (permalink)
If I were to move the BX to the frame upright, would F, M, and N still need to be changed? I realize that A would need to be. I've not messed with a BeastX before and would appreciate any help. Thanks.
Old 08-24-2012, 04:43 PM   #70 (permalink)
If you are going to change the location you should really go through and reset/check all servo related settings and of course orientation mounting A as you mentioned.
Not sure if this location is much better than stock, but easier to see/adjust (and it looks better than on top imho). Probably will also need a nytie wraped around it.
Please let us know how you make out with this. Thanks.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 08-25-2012, 06:42 PM   #71 (permalink)
I just finished the relocation. 1st time going thru the BeastX setup. Fairly simple actually. Now to see how she flies....
If you are still using the box the 300x came in (like my cheap a**) make sure and cut away the styrofoam that the beastx will hit when put in the box
wavekatcher is offline        Reply With Quote Quick reply to this message
Old 08-28-2012, 04:23 PM   #72 (permalink)
Had a servo fail in flight yesterday so had to do a rebuild. The upside is I finally moved my BeastX. Used some 3M 4010 tape and covered the servo wires. Flies even smoother now. I think I had some small vibes from the BeastX touching the frame before I moved it.
ID:	344386   Click image for larger version
300X, mCPX
moscin is offline        Reply With Quote Quick reply to this message
Old 09-01-2012, 10:12 PM   #73 (permalink)
Post
Great job wrapping the servo wires moscin.
TomC, putting the BX on the side did not solve the pitch right issue for me. The frame there is just too flexible and prone to vibration imo. I moved it to the top platform and that worked. Now to wrap the servo wires like moscin.
Old 09-01-2012, 11:25 PM   #74 (permalink)
Nice!
Where did you get those 'wrap' tubes for the cables?
mixfisto is offline        Reply With Quote Quick reply to this message
Old 09-02-2012, 12:29 AM   #75 (permalink)
Thanks for letting me know about your side-mounting experiment. Looked good on paper, lol!
Sorry moscin, but that is the ugliest thing I've ever seen (except for the great braiding job). Looks like a colon bypass, lol! The weight of all those wires plus the fact that your BX is hanging on a ledge, not tied down, looks like an accident waiting to happen imho. Go back to the very first post and look at jaydekay's installation. This looks like the best relocated one I've seen to date.
Personally, I don't have any issues with either of my 300x's with the Bx in the stock position, firmly nytied down. I did spend a bit of time (probably a whole 30 minutes) getting rid of all vibs to begin with.
This mainly involved tightening all frame and mainshaft screws, balancing the main blades, checking/adjusting tail belt tension, and dynamically balancing the tail blades.
The stock location makes it a bit of a pain to see all the lights easily, but far from impossible. Startup is pretty straight forward. Wait for the beeps and the swash up/down dance and you are good to go. Reading an earlier post saying a guy needed to pack a mirror to the field in order to see the Bx blue light kills me, lol!
By all means, relocate anything to anywhere you like if you think it will help. Just don't buy in to everything to hear on this, or any other forum (incl my posts, lol!).
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 09-02-2012, 06:59 AM   #76 (permalink)
Originally Posted by mixfisto View Post
Nice!
It is sold by many hobby shops. Amainhobbies and Hobbyking carry it for sure, try searching "servo wire cover" or something similar. I ended up using 1/8” Expandable Mesh Sleeving from McMaster-Carr because it was inexpensive with cheap shipping options. I cut to length and used black heat shrink tubing on each end to prevent fraying.
http://www.mcmaster.com/#standard-ca...eeving/=j466u0
There are also a number of threads in which people comment on the merits of their favorite brands.
https://www.helifreak.com/showthread.php?t=186654
https://www.helifreak.com/showthread.php?t=430764
The next time I do it I'll probably experiment with routing the wires different directions but as it stands everything is very secure and zip tied to the frame. Added weight on the Beastx is minimal if any.
300X, mCPX
Old 09-02-2012, 09:51 PM   #77 (permalink)
Thanks, will check out now!
Old 09-05-2012, 06:03 PM   #78 (permalink)
Ok I am sold on this. So cliff notes. Once I relocate the BeastX , what menu and what color do the lights need to be set at.
Thanks.
450X | 450 3DX | 300X | 130X | Mcpx BL | Mcpx | SR | 350QX | Mqx | Nano Cpx | Nano Qx | 120 SR | And one DX8 to rule them all.
Blackanthem is offline        Reply With Quote Quick reply to this message
Old 09-07-2012, 05:40 AM   #79 (permalink)
Thanks.
So what setting do we have to change? I just compare the 300x settings to the 450x and the only differences besides servo frequencies are
F= solid red
N=Solid red
Why change M again on the 300x?
Nintyfive is offline        Reply With Quote Quick reply to this message
Old 09-07-2012, 06:40 AM   #80 (permalink)
Thanks.
F= solid red
N=Solid red
If you guys do not know enough about how to setup an ar7200bx unit from scratch, I'd leave it in the stock position where it works fine imho,
Cheers,
TomC
TT X50E, 10s, bd3sx
