Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Like Tree6Likes
Old 09-14-2012, 02:58 PM   #61 (permalink)
Agility IS NOT expo by any meaning. Agility is more like how much you want the unit to lock the heli in position. Lower agility more locked, to certain extent the unit fights the comands a little bit, the higher the agility the more natural the feeling but less locked.
Corrado
www.msheli.com
HighFreq is offline        Reply With Quote Quick reply to this message
Old 09-14-2012, 04:54 PM   #62 (permalink)
So its the heading hold gain?
The word agility is kinda misleading for this param in my eyes.
Does it interact with i gain which locks the Heli in some way too..?
Maye one can compare it with I-limit ?
So long
Benjamin
almigurt is offline        Reply With Quote Quick reply to this message
Old 09-15-2012, 06:24 AM   #63 (permalink)
So long
Benjamin
Hello,
It's not any of the other gains, it's something else we won't tell because it's part of the BRAIN IP and we don't want 50$ chinease copy of the brain, do we ?
Thomas.
Otatiaro is offline        Reply With Quote Quick reply to this message
Old 09-15-2012, 07:36 AM   #64 (permalink)
Nay
Old 09-15-2012, 12:47 PM   #65 (permalink)
I believe it's more of a feel thing like Vivid on the Vbar. Does this sound right?
Mr Nice Guy is offline        Reply With Quote Quick reply to this message
Old 09-23-2012, 11:43 PM   #66 (permalink)
Thank you, this is an excellent thread and great resource
phranticness is offline        Reply With Quote Quick reply to this message
Old 09-28-2012, 03:56 AM   #67 (permalink)
Default Help with my MSH brain!!
All,
I was trying to setup my MSH brain with my computer, and the tail servo didn't seem to operate at all. I would move the rudder stick on my dx7 and it would move the aileron servos instead?
I got worked up and was trying to rebind .,and update my brain, and now....it won't even power up!!! No red and green lights at all!!
Please help!! I tried to do the recovery technique by pushing the 2 middle pins together as desribed ...that didn't help!!! I am so frustrated!!!
studmoss is offline        Reply With Quote Quick reply to this message
Old 09-28-2012, 09:18 AM   #68 (permalink)
Originally Posted by studmoss View Post
All,
Your post isn't related to this thread. Please create a new thread and we'll try to help there.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 09-30-2012, 02:08 PM   #69 (permalink)
Ok so in ff flight, hands free straight flight! But small slow wag. What gain should i try?
mikewheel is offline        Reply With Quote Quick reply to this message
Old 09-30-2012, 02:09 PM   #70 (permalink)
Elevator wag.... Really small and slow
Old 09-30-2012, 03:14 PM   #71 (permalink)
If it's kind of porpoising in FFF lower the I gain on the elevator.
Old 09-30-2012, 07:12 PM   #72 (permalink)
+1
Slow wag is usually I gain, fast wag is P.
IT gets more complicated when you add the D gain in as that can somewhat compensate for higher I gain. So try D gain as well if lowering I does not work, or causes poor performance.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 10-02-2012, 04:48 PM   #73 (permalink)
Lowering cause poor performance and don't cure the wag....what do i do with the d gain........ Lower....higher
Old 10-02-2012, 05:02 PM   #74 (permalink)
What are your other p i d settings?
"poor performance" with i gain to low would mean non consistent roll-rate on elev and climbing in fff
If you fff in with the nose in the wind and the wag increases, you'd lower p gain.
Increasing D would reduce p overshooting in some cases, but it could also increase vibtation issues.
Old 10-08-2012, 10:34 AM   #75 (permalink)
Any news about the UNUFFICIAL manual??????
rino2 is offline        Reply With Quote Quick reply to this message
Old 10-09-2012, 10:40 AM   #76 (permalink)
Fabien???!!!!! Are you still HERE?????
Rino
Old 10-09-2012, 12:45 PM   #77 (permalink)
Please don't forget that some people may still have a real life...
Old 10-09-2012, 12:50 PM   #78 (permalink)
You are absolutelly right... but the first post is dated 12-08-2012..... also.. I don't forget that Fabien have no relation with MSH ... but you know..... a Guide to Program is really usefull
Old 10-09-2012, 01:05 PM   #79 (permalink)
I am sure they are working on it! and soon they will release it, the time they spend keeping us updated on the progress would be time subtracted from the work to get it done and delivered.
GRIMX is offline        Reply With Quote Quick reply to this message
Old 10-11-2012, 02:04 AM   #80 (permalink)
More parameters for governor :
https://www.helifreak.com/showpost.p...16&postcount=6
This is part of the advanced instruction we will have in the next software release, hope it helps:
Ramp up: “This parameter sets the speed at which governor goes from a slower to a faster target speed. Lower values make the transition slower while higher values make the transition faster
Ramp down: “This parameter sets the speed at which the governor goes from a faster to a slower target speed (for example, going from speed 2 2000 rpm to speed 1 1800 rpm). Lower values make the transition slower, higher values make the transition faster
Spool up ramp: This is the speed at which the unit increases speed during soft start, before the governor engages. Higher values make the soft start faster, while lower values make the soft start slower
Corrado
godjc is offline        Reply With Quote Quick reply to this message
