bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support |
06-19-2013, 02:54 PM | #41 (permalink) |
In my latest doc, Governor section for Setup 2/2G, I did mention the possible alternative:
Pos 2: -100% -Captain Rescue (or another positive value for self-level since we already have Trainer as CR) Thanks for the feedback anyway.
Blade mCPX | TRex 550e | TRex 500DFC | DX8 Helix G700 17T, HC3sX, CY F270, GV1/SG, Century V2, Generator |
06-19-2013, 02:57 PM | #42 (permalink) |
Re: My HC3sX and DX8 setup
Good idea. I've been trying to figure out if a trim or dial could be used to only adjust sl gain without impacting 0 for rigid. But two sl modes is better than one.
Sent from my SPH-D700 using Tapatalk 2
DX9, Mostro 700N 120SRX, HD Cell 500, Blade 450xl 6S, 180 CFX and 130x. |
07-16-2013, 03:31 PM | #43 (permalink) |
Updated to v2.2: added example of how to set up Trainer + Gear switch (instead of Rudder switch).
07-17-2013, 02:59 PM | #44 (permalink) |
I have thanked you before but why miss an opportunity to do it again... Thanks for the support and continued development I really like this recent configuration.
California Cabernet & Cuban Cigars Warp 360 | HC-3SX | JIVE 80+ | HK 2520-1360 | MKS DS92A+/95i | Radix | DX8 | PL6 | GP 6S 1500 |
07-22-2013, 01:29 AM | #45 (permalink) |
i followed set up to use trainer and gear switch and looking at my moniter on gear 0 im getting -150 and gear one 50, shouldnt gear 0 be at 0% for rigid? not sure what i missed... thanks
07-22-2013, 10:17 AM | #46 (permalink) |
Did you activate all the mixes for N,1,2,H?
07-22-2013, 11:40 AM | #47 (permalink) |
I may have only activated the one I was supposed to have left un activated... at the bottom of mix's should N12H need to be selected or is it M is unselected ?
07-22-2013, 11:58 AM | #48 (permalink) |
got it, gear 0 = 0% gear 1= 50% hitting trainer =-150% i had activated m instead of activating n12h , thanks a ton, gonna go try it out .
07-22-2013, 11:59 AM | #49 (permalink) |
You select N12H, M should not be selected
~Jim~ Goblin700 Gasser TRM-300, BD Axon, Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH Last edited by KSHeli; 07-22-2013 at 11:59 AM.. Reason: chaneged the bold |
07-22-2013, 12:39 PM | #50 (permalink) |
all set up just checking it on the bench seems to be working sitting upright , is there any way to check if its working inverted or just trust that it is ? i kind of held it upside down and it doesnt look like its doing what it should when its closer to upside down but im not sure, i set it to acro in horizon tab. thanks
07-22-2013, 12:40 PM | #51 (permalink) |
thanks ks ya that was my problem in the first place.
07-22-2013, 01:35 PM | #52 (permalink) |
Make sure to test CR with gear switch at both positions to be sure that you get less that -100 in both positions.
~Jim~ Goblin700 Gasser TRM-300, BD Axon, Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH |
07-22-2013, 01:49 PM | #53 (permalink) |
Yes on moniter in gear 0 and 1, aux 3 is hitting -100 upon pressing trainer switch. .. Thanks
09-01-2013, 05:48 PM | #54 (permalink) |
Wow, great thread. I am looking for exactly the same information on the 3SX, but for the DX7...
If anyone has anything, please help me out over here: https://www.helifreak.com/showthread.php?t=560910 |
10-09-2013, 11:06 AM | #55 (permalink) |
Thanks to ArchmageAU for posting pics of switching Trainer & Gear buttons here
https://www.helifreak.com/showpost.p...5&postcount=29
10-10-2013, 12:04 AM | #56 (permalink) | |
Reposting from my original post (so readers don't have to follow the links).
Disassembled and re-assembled my DX8. Took photos showing the various buttons and switches exploded. Switches in normal positions (swapped back and finger tightened only). Notice I have already swapped labels for my actual layout. Note also that the nuts on the outside of the DX8 holding in the button and switch are notched. The right size screwdriver and these undo easily. 500 size ball link pliers are not big enough to bridge the button, maybe 700 size ones would be. Gear switch disassembled. The silver washer and the black washer go inside the DX8, the switch pokes through and the silver nut tightens to lock switch in place. Bind switch disassembled. This is the one you probably had issues with. Once the outer (high) nut is undone, the button will not pop out. The black button cap has to come off separate from the button to allow this to come out. The button cap just sits in the housing by friction. There is now screw or thead on the inside of the black button cap. Reassembled and ready for duty. This is the configuration I use for my DX8 for use with BD3SX. My DX8 settings for my X5 that has a BD3SX with rescue enabled. 04GAUIX5.SPM (9.5 KB) Quote:
Hope this helps people.
TRex 700E Pro DFC HV (BD3SX) - Gaui X5 (6S/BD3SX), Blade 130X, RealFlight, Heli-X, Taranis+DSMX |
10-16-2013, 02:34 AM | #57 (permalink) | |
I found a way of mixing out aileron and elevator inputs based on a SW.
I just posted it in the "JR and Spektrum Radios and Electronics > 2.4G Spektrum Radios" forum. Works through the monitor screen, now for a field test. Quote:
10-16-2013, 11:51 AM | #58 (permalink) | |
Here's the link to the thread above: https://www.helifreak.com/showthread...51#post5370251 . Thanks for the great work and the testing ArchmageAU , glad you figured it out for use. Jim
10-16-2013, 12:57 PM | #59 (permalink) |
Will definitely be giving it a try. Thanks for the post.
11-09-2013, 10:14 PM | #60 (permalink) | |
Correction to my original post on mixes.
The Ax2 channel disappears (and is replaced by "gov") if you enable the Governor to allow you to set the values of the 3 position switch. So to correct the post (I added the correction to the end of the "2.4G Spektrum Radios" thread). Quote:
