Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
05-20-2010, 10:31 AM | #1 (permalink) |
3G setup
First flight jitters. Burned two tanks on the fbl 600 this mourning before work. Flew great. REAL responsive. Only thing is it seems a little twitchy doing tight loops. Might be me not used to the fbl. Or maybe turn gain down a little. How do you mellow out a fbl setup? More expo? Lower dual rates?
Is there still an issue with the power bus concerns? I hooked mine up normal, and it seems to be fine How do I get V2 firmware update? |
05-21-2010, 06:32 AM | #2 (permalink) |
3g usb link cable released now.
it takes a few days to appers in international shops. |
05-21-2010, 09:57 AM | #3 (permalink) |
Just use EXPO as normal, and you can use DUAL RATES as well, just remember to dail it back to normal if you want to do the DIR setting again. You can even reduce the swash mix as well. Do not use gain settings for making it less responsive you will find it gets to mushy with lower gains, gain settings must be as high as possible before the bobbing starts. Too low a gain is normally indicated by interactions between AIL and ELEV or mushy stops.
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
