300X Blade 300X Helicopters Information and Help |
07-02-2014, 05:32 PM | #61 (permalink) |
They go a horrible brown color after a while, well mine were when I removed them.
07-02-2014, 09:17 PM | #62 (permalink) | |||
I also just ordered the Aglin tail hub and grips. Just in case i have bad vibes with my stock even tho it seemed the stock was vibe free running it up even with the very vibration motor was on mine
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs. |
07-02-2014, 10:13 PM | #63 (permalink) | |
07-03-2014, 12:46 AM | #64 (permalink) |
Has anyone ever just glued the pitch and aileron servos together to achieve bracing?
Anything worth doing, is worth doing badly. |
07-03-2014, 01:16 AM | #65 (permalink) |
I just shim those two servos and have a quick and dirty frame brace (a small piece of spare carbon) glued and screwed to the rhs. Been working fine for the last 2 years
Blade 180CFX | 300X MSH Mini-Protos 3S, Spirit FBL Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim Last edited by stevebaker; 07-03-2014 at 07:04 AM.. |
07-03-2014, 06:34 AM | #66 (permalink) | |
Oh nice. so you braced behind each servo so they be no Gap? Post pictures if you have them.. I asked in another thread i guess if they a way to temp brace and no one said anything.
07-03-2014, 06:50 AM | #67 (permalink) |
Before I got the Lynx frame I used to run with 2 guitar picks wedged, 1 below and 1 inbetween the servos and a zip tie around the anti rotation bracket to the rear fbl mounting shelf it was a while ago, you can see the zip tie in this pic not sure if you can see the picks though. This crude way of bracing suprisingly worked great for quite a while but eventually the plastic frame just got too soft one 45°c day while in direct sunlight and warped.
07-03-2014, 07:03 AM | #68 (permalink) |
Here's an old photo when I still had the crap Eflite servos, motor and esc.
You can see the shims on top of the servos and the frame brace:
Blade 180CFX | 300X MSH Mini-Protos 3S, Spirit FBL Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim |
07-03-2014, 12:44 PM | #69 (permalink) |
Mine didn't come with servos so couldn't see it in person but with those e flite servos you must have more room in between the servos cause with these Coronas there seems to me No room between or on top of the top one maybe a spot below the bottom one maybe.. it have to be wedged with something tiny... but there is room in front of the servos and a tiny room behind i the mount that is why i thought that was were you guys were bracing them at.
07-03-2014, 03:43 PM | #70 (permalink) |
Re: Gaui X2 blades and other cf blades...
I shim my Corona servos with plastics with credit card thickness. Look closely at the servo ear that goes to the bottom rearmost side. The frame has a step up there. You can either file down that step or nail-clip the ear so that bottom servo flushes with frame.
Sent from my SGH-I337M using Tapatalk
mCPx'es/130X/3D-foamie: ugly mods 300X: fast beater/trainer, Protos stretched: trainer but can also go fast FPV250 5.8G, nQx FPV, Oh also Trex 450DFC |
07-03-2014, 04:18 PM | #71 (permalink) | |
Oh I used a File and made a 45 on that rear servo to get it to fit right, did he same with the bottom of the front servo so it would go in good. I guess you shim the elevator servo so the ball would go on the front of the arm? I didn't shim it cause it looked fine, but now looking at it i do see the elevator push rod is not straight up and down with the main shaft do you know what hole you used on the corona servo arms? I am in the 4th now, the 5th hole ( last) was hitting the motor.
07-04-2014, 01:31 AM | #72 (permalink) |
See my latest flight log post for more details.
https://www.helifreak.com/showpost.p...&postcount=542
07-04-2014, 07:34 AM | #73 (permalink) | |
