Old 04-26-2010, 03:36 PM   #1 (permalink)
Default Align T-rex 700 E Manual and Pictures
I received me T-700 E today. I know that there is some guys wanted to see the manual so I have scanned most of the important pages of the manual. My scanners is slow and sucks otherwise I would have done the whole manual. If you need some thing else that I missed let me know and I will get it for you
For some reason I can't upload this file to helifreak so you will need to get it from my site
I found out the problem file was to big to upload on helifreak.
http://www.3dhelishop.com/align_t-rex_700_e
David Olsen
rcman is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 03:42 PM   #2 (permalink)
Thank you, this was the thing, what we all were waiting for
Greetz Marco
Align T-REX 700 E BeastX, Pyro 700-52L, Power Jive 120 HV
T-REX 600 ESP Jive 80LV, BLS451, GY520, BLS 254
ghost400 is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 03:47 PM   #3 (permalink)
No problem, let me know if I missed anything you need
David Olsen
Old 04-26-2010, 03:51 PM   #4 (permalink)
Thank You...I have a request..Battery compartment dimensions please
rotaryguy is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 03:57 PM   #5 (permalink)
There is nothing in the manual about battery compartment dimensions, so I will get the frames togather hopefully tonight and let you know.
David Olsen
Old 04-26-2010, 05:00 PM   #6 (permalink)
Thats all I could ask for...thanks for taking the time out.
Old 04-26-2010, 05:23 PM   #7 (permalink)
The frame is 60mm wide....ID
[COLOR=Navy] #FutabaUSA , #XLP, #SpinBlades
MarkFlysHelis is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 06:13 PM   #8 (permalink)
There is a lot of people asking about the white think in the side for the frame, is it a battery tray
Here is some pictures
David Olsen
ID:	153421   Click image for larger version
ID:	153422   Click image for larger version
ID:	153423   Click image for larger version
Old 04-26-2010, 06:15 PM   #9 (permalink)
More pictures
Radio tray and servo box.
Main bearing block are a lot different then the Nitro version
David Olsen
ID:	153425   Click image for larger version
ID:	153426   Click image for larger version
ID:	153427   Click image for larger version
Old 04-26-2010, 06:17 PM   #10 (permalink)
You do get two lipo battery trays that is a nice deal.
David Olsen
ID:	153429   Click image for larger version
ID:	153430   Click image for larger version
ID:	153431   Click image for larger version
Old 04-26-2010, 06:20 PM   #11 (permalink)
David Olsen
Just incase someone asks. The battery tray is molded into the frames. It's injected plastic.
Old 04-26-2010, 06:28 PM   #12 (permalink)
Thanks Mark
David Olsen
Old 04-26-2010, 06:40 PM   #13 (permalink)
That's good to see they supply two battery trays. I bought 4 6s packs for mine, but was thinking it's not going to save much time between battery swaps if I have to use the same tray.
Really can't wait for mine to turn up, got everything but the heli now. I went for the flybar version as I didn't get on well with the 3G on my other models.
Cheers for the pictures
Simon
Si_B is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 06:49 PM   #14 (permalink)
Here is the frame half assembled for your reference
David Olsen
ID:	153433   Click image for larger version
Old 04-26-2010, 07:34 PM   #15 (permalink)
David Olsen
Will the scorpion 500kv motor fit without cutting?
1NV3RT3D YOUTUBE HelloHeli
1nv3rt3d is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 08:13 PM   #16 (permalink)
David Olsen
David,
Will the motor accept -4- mounting bolts? I may be wrong, but with only -2- motor bolts, seems like it could flex fairly easity.
If it would take -4- bolts, Should be very easy to drill out -2- more holes in the mount.
-Mark
Old 04-26-2010, 08:15 PM   #17 (permalink)
David Olsen
Hi David - you will want to put the motor in as the last step. Just take the motor out including the motor mount. Plugs right in towards the end of the build.
Edvard R is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 10:34 PM   #18 (permalink)
Yes the Scorpion 500KV motor will fit with out mods.
David Olsen
Old 04-26-2010, 10:35 PM   #19 (permalink)
Originally Posted by MarkFlysHelis View Post
David,
-Mark
Mark, (revised 4-27)
Yes the motor has 4 bolt holes, the motor mount only has two mounting holes, kit comes with two bolts. You would need to drill the other two mounting holes in the motor mount to accept 4 bolts
David Olsen
Old 04-26-2010, 10:37 PM   #20 (permalink)
Thank you for the advice, I was thinking the same thing. I will pull it out that should give me more room for installing servo and linkage
Thank you
David Olsen
