Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion
KDS Helicopters General Discussion KDS Helicopters General Discussion
Old 04-05-2014, 01:40 PM   #1 (permalink)
Default Main gear mesh with second reduction gear to tight
I have been having problems with vibes in my heli and the only thing i can find is that the main gear mesh with the second reduction gear is super tight. Since it has no adjustment i am not sure how i can fix it. Please help. thanks
yamahajoe is offline        Reply With Quote Quick reply to this message
Old 07-11-2014, 12:15 AM   #2 (permalink)
Did you solve this?
I had a grinding noise once I put the tail boom on; so I removed the 0.5 washer between the main gear and the spiral gear (tail)
Have not flown it yet.
EDIT: Never mind, my bad - can't do this as the spiral gear is locked by the jesus bolt. I refitted the boom and it seems OK meshed but not very smooth running maybe it'l run in
So much fun but so little time Bring it to work !
J_Rig is offline        Reply With Quote Quick reply to this message
Old 07-11-2014, 02:40 AM   #3 (permalink)
Originally Posted by J_Rig View Post
Did you solve this?
I think I had the same problem. The spiral gear (tail drive gear on the main shaft) was not true, so there was a decent grinding noise. I replaced the .5mm washer between the bottom of the main gear and the lower bearing block with a .2mm and the grinding went away. Essentially lowering the entire main gear assembly so that the front TT mesh is not as tight against it.
Protos Max 700, Logo 550SX, Goblin 570
MSH USA Flight Team, MSH Brain, Jeti Model, Cyclone
soniczen is offline        Reply With Quote Quick reply to this message
Old 07-11-2014, 03:09 AM   #4 (permalink)
Excellent- I had 0.5 + 0.5 + 0.2 shims sitting there- took out one 0.5 and it's smooth now.
It somewhat compromises the pinion and main gear alignment but should not be critical on slanted gears. Thanks
