Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 06-23-2013, 11:10 PM   #81 (permalink)
Default Re: Scorpion Backup Guard
no issue.
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 06-23-2013, 11:20 PM   #82 (permalink)
cool thanks., im gonna be using this on an AJ Slick. that align is pretty smooth.
wedoitall is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 12:20 AM   #83 (permalink)
internal bec with align ?
Old 06-24-2013, 05:12 PM   #84 (permalink)
I've been using a 70A align esc w/ the built-in BEC and Scorpion BUG on my 550 without any trouble. I follow the recommended protocol of turning the BUG on last, and turning it off first.
Align 550e, Gaui X3
krefi is offline        Reply With Quote Quick reply to this message
Old 06-25-2013, 12:59 AM   #85 (permalink)
Default Sv: Scorpion Backup Guard
Yes the backup guard must be powered on as the last device in your setup, and powered off as the first. :-)
RasmusDK is offline        Reply With Quote Quick reply to this message
Old 06-25-2013, 01:08 AM   #86 (permalink)
its not a must but can be done either way without hurting anything.
just will discharge faster
Old 06-25-2013, 04:18 PM   #87 (permalink)
yea with internal bec. also will be using telemetry so I guess theres no problems with that either?
I usually run separate bec but I had this laying around and thought it may actually be better.
Old 07-23-2013, 01:32 PM   #88 (permalink)
Originally Posted by AndreKoren View Post
I forgot to mention that I spoke with Inovative Designs the US distributor for Scorpion Products and they confirmed that the Backup Guard will not properly power all HV full size servos like the JR8717HV which is on my G770. They even mentioned that a HV version of the Backup Guard may be on the horizon.
I actually expected this since JR also sells specific Wide Voltage servos that work from 4.8 to 8.4V instead of the HV servos that need 6V minimum.
So is there any news about a HV backup guard?
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 08-12-2013, 01:48 AM   #89 (permalink)
Originally Posted by chadew View Post
OK here is what I did. I made a charge cable from the ec3 to balance connector on my parallel charge board. The iCharger shows 2s connected through the balance port and correct voltage through the main charge leads. This should allow me to balance charge the Backup Guard.
I'm planning to buy one for my next project (Goblin 500), and I have some questions:
a) with your charge cable, basically you are just shooting back the charging power into the parallel adapter's balancing circuit, correct? Will this not harm the board and/or the charger (I have iCharger 206B)?
b) is there any specific reason why you chose to use the 6S balancing plug instead of the 3,4 or 5?
c) can I normally leave the Guard plugged into the FBL unit and just switch it off on? (I assume this is one of the uses of the switch).
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 08-12-2013, 02:13 AM   #90 (permalink)
Default Scorpion Backup Guard
I just ordered one of these... Should allow me to charge the scoprion through the balance plug and keeps my main charger free
http://hobbyking.com/hobbyking/store...ger_2S_3S.html
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 08-12-2013, 12:02 PM   #91 (permalink)
Default Charge Adapter
If I didn't already have a Cellpro 4 that charges through the balance plug, I would just get the charge adapter that Innov8tive sells and not risk wiring my own the wrong way: http://www.innov8tivedesigns.com/pro...fb2cd5c86190f4
Align 550e, Gaui X3
Old 08-12-2013, 01:09 PM   #92 (permalink)
Yes. I am just using the parallel board as a male to male extension for the balance connectors. I don't see that it would do any damage to the parallel board since there isn't that many amps going through it. It has been working just fine on my I charger 3010.
The only reason I used the 6s plug is because that is what I had on hand. Any of the balance plugs should work just fine.
I leave mine plugged it and use the switch to power on the electronics, but I always remove it for charging and storage. Almost every lipo fire I have heard of other than a crash was with the battery installed in the aircraft while charging.
The premade charging cable is nice, but wasn't available last August when I got mine. Scorpion sent it to me when they replaced my ESC. It wasn't even on their site yet.
Sent from my Galaxy Nexus using Tapatalk 2
Gaui X5 FES, Scorpion 910kv, Gaui GS-501, Gaui GS-502, BeastX, R6208SB
Gaui X7 FES, Scorpion HKIII-4035-500, Torq BL9180, Savox SB272-MG, Mini vBar, R7008SB
18MZ
chadew is offline        Reply With Quote Quick reply to this message
Old 08-14-2013, 02:40 PM   #93 (permalink)
DannyG I have not heard any news or updates from Scorpion about a Back Up Guard that will accommodate HV servos. I'm hoping something like this will come soon, It's a great idea and would likely save some helicopters from hard crashes.
Goblin 770, TREX 700N, TREX 550, TREX 450, Blade 130X
AndreKoren is offline        Reply With Quote Quick reply to this message
Old 08-14-2013, 03:13 PM   #94 (permalink)
Thankfully I've tested mine and the HV servos will operate on 5v for me.
I would love one that provides user selectable voltage. Perhaps 5-7.4v... Also it's worth pointing out that It's good to have a little lower voltage if you are using telemetry as you can use the lower voltage to set off an alarm.
Old 08-15-2013, 07:17 PM   #95 (permalink)
Can you cbarge through the balance port alone? Or do you need a charge lead?
emederos is offline        Reply With Quote Quick reply to this message
Old 08-15-2013, 07:35 PM   #96 (permalink)
I charge mine from an Eflight 130X 2s charger, works sweet.
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 12:47 AM   #97 (permalink)
That's depending on your charger. If it can do it, it can do it.
If it can't, you need to build something like in pist #17 or buy the adapter like in post #90.
Old 08-17-2013, 03:51 PM   #98 (permalink)
Chad,
Thanks for posting your way with a great pic!! I was in the same boat...had the guard but no way to charge, so it sat until I ran across Mr. Mels vid. Made the cable he described but I could not get it to work using my icharger 306B. Ran across this thread about a hour ago. I had a spare parallel board, balancing plug/cable and deans connector. Two solder joints and I'm cooking with grease!! I'm mounting it to my heli now : )
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 08-19-2013, 02:25 PM   #99 (permalink)
I won a Scorpion gift certificate at a local fun fly a while back so I just bought two of these BUGs. If I can figure out the charging thing I'll be putting one on a Logo 550sx and either sell the other or put it on a 450 - I'm concerned about the weight though. Thought about keeping one for my next heli, but that will likely be an HV 700 build which, as has been established, won't work.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 08-19-2013, 07:49 PM   #100 (permalink)
It's not worth the weight on a 450, IMO.
Align 550e, Gaui X3
