700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-02-2012, 01:47 AM | #1 (permalink) |
3GX Has No Power, But RX Does
I am baffled. I really wanna get this maidened
12-02-2012, 11:57 AM | #3 (permalink) |
Ok brother, unfortunately no one has replied because we have nothing to go on.
Two pictures that don't provide any meaningful information. Have you attempted to bind it your radio? I see your using the align regulator, is it plugged into the 3GX? Sent from my iPad using Tapatalk HD
Its all about having fun |
12-02-2012, 12:07 PM | #4 (permalink) | |
Yeah. im getting a new bec today and probaly a beastx. If not lhs will have to sort it out |
12-02-2012, 02:44 PM | #5 (permalink) |
are you plugging the lead from the reg into the battery port on the 3gx
3gx does not support dsm 3 i see your going wire to wire you must power the 3gx not the rx
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba |
12-03-2012, 08:40 AM | #6 (permalink) |
If you're using a spektrum radio (DX7 and up). Get rid of the spektrum receiver completely. Plug your bec into the 3gx, plug your two satellite receivers into the 3gx directly, plug your servos into the 3gx. Bind it, and go.
If you're using a spektrum dx6, you need to keep the spektrum receiver. Your bec needs to power the 3gx and the receiver. The 3gx comes with a female to female 3 wire servo lead (red, black, white). That lead needs to be plugged into the 3gx and the rx on an open port to transfer power from one to the other.
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf Align 600EFL PRO, DFC, 3GX, KDE Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s Thunder Power 65C LiPo & JR 12X |
12-03-2012, 08:41 AM | #7 (permalink) | |
"Wire to wire" you still need to power the rx......
12-03-2012, 10:10 AM | #9 (permalink) |
you must power the 3gx first the rx will pickup power from the 3gx if you power the rx and not the 3gx you will see a brown out
12-03-2012, 10:25 AM | #10 (permalink) |
The ESC won't arm if it does not see zero throttle. Try lowering your throttle end point in your tx....
Velos 880/Sab Urukay, KSE, Carbon Speed/Mikado Uvular/RCA Blackshark/Chaos 500 Evo, 550, 600, 700/Trex 500, 600, 600 Pro, 700/Roban 470 Cobra, 700 Apache, Cobra, 429, Jayhawk, 800 Airwolf/TFM 800 Blue Thunder, Seahawk, Jayhawk/ DX8 DX18QQ |
