Old 08-18-2014, 03:48 PM   #1 (permalink)
Default Multigov Pro + Futaba s-bus: How to.......???
W/ this set-up on a 2 channel Rx, HOW can I enable the rpm port on the multigov pro to see a signal change w/ my flight switch?
Can I jump the signal wire from the throttle input to the rpm port on the multigov pro? (just signal wire I guess.)
Or, use the second channel somehow on the 2 channel R6202SBw Rx?
Thing needs to see a signal from an aux port tied to your flight switches to have changing rpm's w/ the flight mode switch. Just want 3 rpms, but Im thinking I have to get a full blown Rx if I want that... not sure though! Uggg!
RotorFloater is offline        Reply With Quote Quick reply to this message
Old 08-18-2014, 07:14 PM   #2 (permalink)
The R6202SBW channel ports are linked to channels 2 and 3.
There's a few ways to approach this. What FBL unit are you running?
A quick way, assuming you are not using channel 2 and 3 for anything, is to enter the function menu on your radio and reassign channel 2 and 3 to "THROTTLE" and "GOVERNOR" respectively.
You would then plug the Throttle lead from the Multi-Gov into your Channel 2, and the RPM set lead into Channel 3. Then simply use your governor menu to set the % to -100, 0, and +100 for Normal, IU1, and IU2. Your multigov should be G2G.
Another way may be to go through the S-Bus lead and plug one or both of the Multigov leads into your FBL unit. You could then remap the THROTTLE and GOVERNOR functions to whichever channel you desired in your FBL unit.
Hope this helps!
dchekas is offline        Reply With Quote Quick reply to this message
Old 08-19-2014, 02:18 AM   #3 (permalink)
Hope this helps!
It does help!
Ill try one of the above methods...
My setup is
YS .56 engine.
CC BEC pro
all align servos
tracX head
multigov pro
spektrum back plate sensor.
using the temp setup
8FG Tx
HC3SX fbl controller (throttle simply functions as a pass thru)
Old 08-31-2014, 08:27 PM   #4 (permalink)
Hope this helps!
How do I generally re-map the governor to the throttle? I know Futaba Tx's so-so...I know spektrum waaay better, but I left spektrum for a reason
Thanks for that help by the way, it helps!
Old 08-12-2015, 01:47 PM   #5 (permalink)
I have a similar problem with the JR28X +Beast X + multigov.
Ive setup the wires between beast x and multigov as follows:
multigov
THR-- BEAST X CH5
SEN-- Spektrum backplate sensor
SV1-- Throttle servo
I dont know where to connect the RPM wire from multigov to?
Im unable to switch speeds1,2,3 on the screen. why cant i switch between 3 modes?
rcfreek is offline        Reply With Quote Quick reply to this message
Old 08-12-2015, 05:16 PM   #6 (permalink)
I tossed my Multi gov in the trash and used the Ikon gov. Never looked back, and it works like a champ.
Specter 700, Protos 700 Gasser, XLPower 550, Protos 380 - Jeti DS14
Citizen - #202
Dowquest is offline        Reply With Quote Quick reply to this message
