Futaba Radios and Electronics Futaba Radios, Gyros, Servos, Etc. |
07-09-2014, 11:46 AM | #1 (permalink) |
Smooth 5-Point Pitch Curve
In my Futaba 9CH I programmed the pitch curve for a small amount of exponential around center as per the diagram below. Does the 5-point pitch curve computing "smooth" out the response between the points?
Or, does it respond exactly along the line connecting the points? Thanks, Paul |
07-10-2014, 04:03 PM | #2 (permalink) |
What you see is what you get. This is the reason 5 points is not enough. The 12Z/14MZ/18MZ have SPLINE curves. JR has smoothing.
07-10-2014, 06:33 PM | #3 (permalink) |
Not sure why you need a curve with modern helicopters. Every since I have been flying flybarless I have always used a linear pitch curve. Curves really don’t help and just make the response nonlinear. With a little practice you will fly better with everything linear.
