Closed Thread
Old 05-09-2014, 11:39 AM   #461
shaun.evans09
Hey guys I want to make sure that I'm heading in the right direction with a small issue. I've noticed that in IU1 & 2 whenever I do a full rudder input the heli comes around fine and as it stops suddenly it snaps back and forth just a little. It's like a little bounce back and forth, albeit very slight. I'm pretty sure that this is going to be a tail gain adjustment but I wanted to make sure before I go jacking around with something that doesn't need playing with. Any suggestions?
shaun.evans09 is offline
Old 05-10-2014, 07:06 PM   #462
zortness
Got mine all assembled and ready for a flight... now if only the wind would go away.
ID:	508138   Click image for larger version
ID:	508139   Click image for larger version
ID:	508140   Click image for larger version
zortness is offline
Old 05-10-2014, 07:23 PM   #463
dunkonu23
Mind you, I don't know IKon FBL systems, but it sounds to me like the stops are a tad too high. Stop are different from overall gain. Try lowering stops in small amounts and see what happens.
Scott
Team Compass USA--Field Rep
KBDD Team Pilot ):>
www.experiencerc.com: Making Helicopters Great Again!
dunkonu23 is online now
Old 05-10-2014, 07:25 PM   #464
dunkonu23
Outstanding looking helicopter, Zortness! Congratulations! It's really windy here, too. Beautiful day otherwise. We can't wait to hear about your maiden flight!
Scott
KBDD Team Pilot ):>
Old 05-10-2014, 07:29 PM   #465
shaun.evans09
Scott
Actually that's what I've come to while doing some reading. In the Ikon I believe it is referred to as tail asymmetry and includes the stop ratios so I'll play with those and see if I can't get it ironed out. It's only present on hard piro's under full deflection and it's a slight return bounce, like it's hunting a bit. I'll hook up the Ikon later on and take a look at the settings.
Old 05-29-2014, 03:19 PM   #466
shaun.evans09
I posted this elsewhere already but I'm so excited I'll post it here too. I've been busy building my G700C and haven't put a lot of flights on the Rush in the past week but I was able to iron out the issue I was having with the tail bouncing back a bit. After adjusting the D & I gains and tail assymetry advanced settings in the Ikon a bit it stops perfectly now during all flight modes. The slight "hunting" or bounce back I had when stopping on hard piros is a thing of the past. It's sharp and crisp now on the stops so thanks everyone for getting me pointed in the right direction.
Old 05-29-2014, 07:45 PM   #467
dunkonu23
That's great! Thanks for letting us know.
Scott
KBDD Team Pilot ):>
Old 06-06-2014, 04:08 AM   #468
doujoh
Default Sv: Rush 750 Build Thread
It's hard to see in the pictures, but it looks like the motor cables are a bit exposed to the top carbon fiber plate. I would put some velcro or fuel tubing on the edges of the top plate so the wires don't wear out.
|Goblins|Vcontrol|Vbars|
doujoh is offline
Old 06-06-2014, 10:58 AM   #469
zortness
The edges of the carbon are sanded smooth, so there's not much danger of the wires being damaged. I do have them velcro'd down at the moment though.
zortness is offline
Old 06-07-2014, 09:46 PM   #470
DaveHolland
I just recently bought an Ikon to get familiar with the system since its so popular. The value you are looking for is D Gain or Derivative Gain in the Advanced options. Here is also a link to all the advanced info on the Ikon and how to adjust for a clean tail.
http://67.228.244.248/showthread.php?t=443625
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline
Old 06-08-2014, 09:50 AM   #471
wbefield
Excellent thread on getting the tail dialed in on the Brain/Ikon. My tail barks a little bit on counterclockwise piro stops, but it doesn't bounce. I need to dial the bark out, but it is flying so good, I didn't want to mess with it.
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline
Old 06-08-2014, 01:02 PM   #472
shaun.evans09
Thank you for the info. I forgot to update this thread, but I've already gotten the issue worked out. I don't have any issues with the tail authority now. Mine also had a little bark on piro's which I got ironed out. It took some minor corrections with the D & I gains and the tail asymmetry to get everything the way I want it to be.
Old 06-08-2014, 10:54 PM   #473
DaveHolland
Seems to be a major issue with the Ikon. I have some wiggly / barking / loose, tail issues with my Goblin 500 and Ikon combo. Its just a different mindset coming from the SK540. Leading class for tail gyro but you have to set up the cyclic, Ikon is the opposite, cyclic was good but tail needed work.
FrSky Taranis
Closed Thread
