Old 06-25-2011, 09:38 PM   #101
Jonnyrl1
Originally Posted by oy2503 View Post
I believe I'll put an Align 500MX motor on mine,
when the time comes. I'll stick with the 500L for now.
Some write it's Align's best motor ever.
Cheers
Erik
The 500L has been really good to me, just passed 100 flights on it today and its still going strong I fly in idle up all the time and it comes down hot but still goes like a champ. Ive never rebuilt it or oiled it FWIW.
7HV kontronik pyro700-52, ar7200bx
Trex 600EFLPro-BeastX
Trex 600N
/trex450prov2/mcpx's/DX8
Jonnyrl1 is offline        Reply With Quote
Old 09-18-2011, 04:00 PM   #102
Blade120
Using a 500l also for well over 100 flights plenty of power and no issues besides running hot. Any thoghts on wether this motor needs to be oiled , i never have but wouldnt mind doing it if its going to increase its life or make it run smoother.
Blade120 is offline        Reply With Quote
Old 05-04-2013, 07:27 PM   #103
HeloMan
Default Align 500MX or Scorpion 3026 For My New 500
Just bought an Align 500PRO DFC and wondering if I should use my scorpion 3026 instead of the stock Align 500BX motor. Looks like the Align @ 1600w and 75 amps continuous vs Scropion's1470 watts and 70 amps continuous would be a stronger motor. What do you guys think? I'm fairly new and for some reason thought Scorpion was a better motor, don't know .
P.S. loved how the Align kit went together. First real kit, did two and a half HK (2 450's and one 500) Fit and finish is is perfect.
HeloMan is offline        Reply With Quote
Old 05-04-2013, 11:28 PM   #104
Blade120
Default Re: FAQ, Before you purchase, Upgrades & Normal Issues - Summarized
No doubt the Scorpion is the better motor , but I have been using a 500 mx for the past three hundred flights or so on my 500 without any issues. Gives me plenty of power. I wouldn't replace it just to replace it I would wait till the 500 MX fails.
Sent from my SCH-I605 using Tapatalk 2
Trex 500 ESP(DFC) Ikon, Radix] [Goblin 700 CompBK, 4525, Ikon, Helix 695 ] [Rave ENV Nitro O.S 105-R,Ikon,Cyclone] Rave ENV Electric]Scorpion 4525,Ikon, Outrage, SAB [Goblin 500] Ikon Rails 516 ]Blade 180 CFX]Goblin 570 12S Xnova
Old 01-11-2016, 06:22 AM   #105
andrea_farins
I'm planning to convert my 500E to DFC. I would like to continue using the tail belt, I don't want a TT yet. Do I need just main rotor holder and main rotor head? that's all?
http://www.mattiolimodellismo.com/de...&categoria=377
http://www.mattiolimodellismo.com/de...&categoria=399
I feel like I missed something..
andrea_farins is offline        Reply With Quote
Old 01-11-2016, 01:52 PM   #106
Gladius
The DFC uses a shorter main shaft, so you'll need to get that too. But otherwise, you should be good to go.
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3 <>
<> Builds in progress: Logo 600SX, KDS Chase 360 <>
*Spartan Vortex VX1e*
Gladius is offline        Reply With Quote
Old 01-11-2016, 06:15 PM   #107
andrea_farins
The DFC main shaft should be already in the box, as the description said, I will ask to the shop tomorrow
Old 01-11-2016, 06:31 PM   #108
Gladius
Yep, I missed that.
Old 01-11-2016, 07:40 PM   #109
andrea_farins
Yep, I missed that.
I ordered the head and since I had a bad tail wag few days ago I also ordered the plastic tail case and plastic tail control arm. I had a bad play on my tail shaft, I moved up and down by hand, and I noticed it on the first lipo when It wag left and right like crazy. I hope it will disappeared replacing all the tail but I would like to go with the metal tail case, would it a good investment or the plastic case does the same job? I would like to stay belted
Old 01-11-2016, 09:19 PM   #110
Gladius
I would try the plastic tail case first. If it works, then no need to spend extra money on the metal case.
Old 02-10-2016, 11:47 AM   #111
gettingthere
Ok guys, I might be getting a brand new 500L minus all the electrics. I could just get the combo but the amount of my tax check isn't going to allow that but I've waited long enough and want my heli, lol! If I do decide to go this route, I would really like to install some pretty good electronics but it doesn't have to be top of the line, but I would like to get maybe something better then what the combo comes with. I don't think there is anything wrong with the included gear, especially now that it comes with the microbeast, but if I do go this route, then maybe I can pick some things a little more high zoot. This would include everything, motor, esc, FBL unit, and servos. I love helis and am familiar with most equipment but it's been since last fall since I flew and really paid any attention to it (I race RC cars int he winter) so there may be some really great stuff that has come out since that I don't know about. Thanks!
gettingthere is offline        Reply With Quote
Old 02-21-2016, 03:41 PM   #112
nigel armstrong
Originally Posted by theLane View Post
I don't do 3D, not interested. Was just wondering if there was some issue and a seperate bec was required.
As has been pointed out by others on this forum the BEC system on a 500 Trex is fine for the model as supplied out of the box....as is the motor. The only thing I have added to my model is a Scorpion Backupguard. I had the ESC fail in a Raptor 550e a few seasons ago and lost everything in the resulting crash. This little device would have at least given me a shot at a damage limiting auto. I now have them fitted to all 3 of my electric helis.
nigel armstrong is offline        Reply With Quote
