Go Back   HeliFreak > R/C Helicopters > Helicopter Safety
Helicopter Safety R/C Helicopter Safety
Old 02-10-2016, 05:47 PM   #21
bredler
Originally Posted by Mattinfla View Post
I installed a locking switch on my DS-16, and programmed it as a parallel throttle hold. The transmitter will alarm and not start unless the locking switch is in the hold position.
Prevents both brain farts and accidental switch actuation.
Does anyone know if a DX6/7/9/etc can assign hold to two different switches like this? I really like the locking switch idea, but it only works if you have two switches assigned to TH...otherwise you'd be way less safe in flight with just the locking switch assigned.
bredler is online now        Reply With Quote
Old 02-11-2016, 02:41 PM   #22
bredler
I suppose the alternative would be to put in a new locking switch and wire it in parallel to the one that I normally use for TH, then short out the switch wires I took away so that it stays in one 'position' and the radio wouldn't see that input as floating. I could do that, and honestly a heli is likely to utilize the largest number of switches on a 6 channel radio anyway (maybe a full house sailplane, but I would want a better radio for that anyway) so if the switch rewiring works for my heli, I wouldn't be limiting my radio for other models I would likely use it for.
Does anyone see why this wouldn't work, or have a firm yes or no to my original question?
Old 02-11-2016, 04:26 PM   #23
Coco66
I don't have a G2 radio, but they are more powerful in programming compared to my DX8 (where I could make it) so you should not have any problem.
The trick is to have one of the two switches you want to use configured as TH, and the other one configured as TC (throttle cut). They will both prevent the spool up.
[SIZE=2]Goblin 500Warp 360Blade 450XBlade 450X Nightflyer ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8
Coco66 is online now        Reply With Quote
Old 02-12-2016, 11:51 AM   #24
bredler
Duh. Major brainfart there. I'll open up the radio and see what size switch I need this weekend, order it up and do a teflon sheet mod for my throttle while I'm at it.
Old 03-10-2016, 03:02 AM   #25
AntDX316
Originally Posted by Koopyetz View Post
House guest asked to watch me fly helicopter today. After I set helicopter down I turned around and he had picked up tx near me and began moving sticks around. When I got the tx in my hands and placed it near helicopter and turned it on the throttle was at the halfway point and the throttle location warning came on. Glad I have this warning . LiPo wasn't plugged in yet .
Stupid oversight on my part not to even notice where the stick was.
yeah, the TX is as dangerous a gun
having a helicopter plugged in and letting someone hold the TX is dangerous even if it's off
turning it on and messing with the sticks after it turns on..
It was like the comments I read when some lady got eaten by a whirlpool touching the water by the rapids that looked calm but it had 10x the force of something at Niagra. A lot of comments saying she was stupid but if you don't know rapids you think it's safe. She got pulled in by the leg.
facebook.com/AntDX316
It's my responsibility to make sure it works and know what could go wrong despite what everyone else is saying because they do not see what I foresee.
AntDX316 is offline        Reply With Quote
Old 03-30-2016, 12:47 AM   #26
TeeJayShelton
The dx9 allows you to set warnings for various switch positions. I have mine set to make sure mine is on before it will stop warning me.
This ^^^
And don't let people distract you while you are doing your mental checklist.
Agreed. Another thing the dx9 has is a programmable preflight check list
Agreed. You should also never have a heli on with the tx off unless you are testing your failsafe.
The more I learn the more I realize I don't know
T-Rex 800 DFC Pro, 700L TOP, 700L, 550V2, 500Pro, 250DFC. Blade 180CFX, Nano CPX & NQX FPV.
AMA#965241
TeeJayShelton is offline        Reply With Quote
Old 08-10-2016, 09:01 AM   #27
denis747
Happened to me too. I was flying my 450 and after landing I put the Tx aside so I go and disconnect the lipo plug on the heli. My friend picked up the Tx and I shouted don't touch it as the heli is still on. He left it alone. I now have the Tx close to me at all times.
Sent from my GT-I9505 using Tapatalk
Align Trex 470LP, CopterX 450 pro DFC, HCP100S, V977, V911, Deviated Devo 10 and Deviated Devo 7E Tx.
denis747 is online now        Reply With Quote
