Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 03-10-2016, 07:20 PM   #1
TTboy53
Question Fbl blades
Is there a difference between normal cf and fbl blades?? And which fbl ones are the best for normal flying?
TTboy53 is offline        Reply With Quote
Old 03-11-2016, 05:09 PM   #2
Relisys190
There are so many to choose from! Which size do you have intentions on trying?
Typically FBL blades are weighted differently than a flybar blade.
Typically FBL blades are slightly heavier with the mass or balance of the blade focused more towards the end of the blade. It really depends on the manufacturer.
I am currently running Flybar style blades on my T-rex 500. They are faster initial response around center. Which can also be changed using FBL controller settings.
Welome to RC Helicopters
-Markus
*LINKS*
* G660c IKON * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote
Old 03-11-2016, 07:02 PM   #3
TTboy53
Yes sorry. I've got a raptor 53 with Outrage fbl head. 600 mm Tt blades right now.
Old 09-07-2016, 11:57 AM   #4
bad007
I check all mine like this B4 installing them. Yep they act different.
http://www.vstabi.info/en/node/74
450Pro 3GX HW PL ProV4, Edge KDBB, 500ESP DFC 3GX Edge, 500L MicroBeast Plus HW PL Pro V4 KDBB Blades KST HV, Align 550 DFC MicroBeast Plus, Velocity 50 Vbar 5.3 Pro, OS55 HZ-R, Radix V2 KDBB Castle, D380, MicroBeast Plus Switch Blades
bad007 is offline        Reply With Quote
