Old 01-04-2017, 11:50 AM   #1
DaveScott
Default Newbie Question: Cyclic Servo Arms
Im fitting 3 x DS530 servos to my Trex 500. In each box there are 3 different servo arms, 1 x single arm, 1 x 4 arm and 1 x 5 arm. Which of these to I fit to the servos?
Thank you.
Trex 500l Dominator (building).
DX6 - Phoenix.
Club: Long Eaton Model Aircraft Club.
DaveScott is offline        Reply With Quote
Old 01-04-2017, 12:58 PM   #2
Dylan Hudock
Find which one has the holes the correct length out for your ball links. I have mine at 15mm. Then change them around to find which arms give you closest to 90 degrees from your servo without using any subtrim or fbl settings.
KBDD Team Pilot Trex 700-500-450, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 01-05-2017, 08:53 AM   #3
DaveScott
Works fine! Thank you.
DX6 - Phoenix.
