Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 12-31-2016, 10:52 PM   #21
rlane4osu
Originally Posted by Squier250 View Post
On the plastic kit, a lot of the plastic things have a metal treated insert which is great. the tail case has no metal insert, it uses little locknuts that you thread into which is great.
That's great. I actually noted that on the lower block of the LM (which is plastic). What about the servo locations on the bearings blocks, do they have inserts?
rlane4osu is online now        Reply With Quote
Old 01-01-2017, 12:11 AM   #22
Number
The servo mounting screws are self tapping into plastic. That's about all you could do with the 2mm holes in the servos. You would have to try pretty hard to strip them out though, certainly cranking harder than necessary...
Number is online now        Reply With Quote
Old 01-01-2017, 12:22 AM   #23
rlane4osu
That's true, I guess it never was an issue on the old x3. The only reason I brought it up on the 470 is because of the tail servo mount. I'm not one to overtighten but one of those screws that goes through the frame won't make it another reinstall. Nothing I can't fill and retap, but I'll eventually replace it with metal.
Old 01-01-2017, 12:38 AM   #24
HeliLust
Quick tip on threading screws into the pastic. After they have been installed and removed, when you go to thread it back in, turn the screw like your taking it out by turning counter clockwise. You will feel a distinct click where the threads line up, at that point turn clockwise and your home free.
Doing it that way ensures that the threads line up the same every time and by not over tightening you won't strip plastic anymore. Also I don't use super glue as loctite to hold screws that have been threaded into plastic, that destroys the threads just as quick. I've never had a problem with them backing out, but if it's a concern for you, use some clear elmars glue instead of CA.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 700N
Team Align Enterprise Hobby Facebook Align Part Finder
HeliLust is online now        Reply With Quote
Old 01-01-2017, 12:39 AM   #25
rlane4osu
Been doing this for the last year or so. Works great!
Old 01-01-2017, 01:47 AM   #26
Dipweed
Red face Important Build Step
Yes
This is a extremely important build trick.
Do not turn the bolt / screw in.
Insert bolt / screw.
Back out bolt / screw until you hear or feel a click.
I use this trick on all plastic and metal threads.
You will never know how important this is until you get a stripped motor screw or cross threaded bolt that has to be cut out and the parts have to be replace.
Extremely Important.
Align&HK450 L/470L/150 DFC/Blade stuff
DJI/AR Drone
Dipweed is offline        Reply With Quote
Old 01-06-2017, 10:45 PM   #27
windcatcher
Default Align 470lm vs 470lp
Have you received 470LP kit recently?
1. What should be in the box of the latest kit?
Longer tail shaft? 74mm tail blades? Carbon tail rod? Any other free updates or changes to expect?
2. Are there any parts of LP version known to be faulty and worth replacing with metal out of the box?
3. Are there any 470LP owners with +100 flights? Would you choose LP over LM again and how is the plastic parts wear and quality after longer use?
windcatcher is online now        Reply With Quote
Old 01-09-2017, 11:27 AM   #28
BoozinFlyer
I went with the LP and ordered some "upgraded parts":
1. Carbon Tail Control Rod (I, personally, can't stand the wire & guides).
2. Counter Clockwise Ball Joints (there was some discussion on this, but the kits come with RH threaded ball joints even though they look like turn buckles - They are not TB's.This is purely preference).
3. 74mm Tail Blades (Both carbon fiber and neon yellow).
Crashes happen and I've been out of the heli loop for a couple years now. Plastic version for me for now as it's cheaper to fix.
P.O.P.P.E.R.
Plank flyer by choice/ poser heli flyer AMA 975380
Typical Gun-nut
BoozinFlyer is offline        Reply With Quote
Old 01-11-2017, 04:15 AM   #29
Livan75
Originally Posted by Dipweed View Post
470LM vrs 470LP I own / built both kits
Metal Tail
Plastic you will not be able to take advantage of the new metal tail rotor shaft.
I'm not sure about the plastic alloy used, but its really easy to get hairline fractures in cold weather flying... I had a couple of mid-flight exploding tail boxes before I realized that on my Blade...
Blades tail-box alloy gets really brittle in cold weather...
Oxy 285 (4s) (AR7200BX, EOX 2214-4100, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV)
Lynx Team Pilot / Oxy Field Rep
Livan75 is online now        Reply With Quote
