Go Back   HeliFreak > R/C Helicopter Support > Beam
Beam Beam Helicopters Factory Support Forum
Old 12-15-2008, 04:28 PM   #1
oldschool269
Default BEAM E4 pictures , picture thread
Post up some pics of your beams... !!
soon to be 6s beam , with NEW scorpion HK-22 1620 Kv motor and align 6s 60a esc.
Jason
ID:	72594   Click image for larger version
ID:	72595   Click image for larger version
oldschool269 is offline        Reply With Quote
Old 12-15-2008, 09:35 PM   #2
silvio600
Talking My Beam E4 FES With Helicommand
Beam E4 Kit
Helicommand Rigid
GY-401
S9650 X1
HS5065MG X3
Futaba Fasst
Gaui 400-450 Flybarless head
Align 430XL
Pinion 11 80%
Here http://www.helifreak.com/showthread.php?t=108432
silvio600 is offline        Reply With Quote
Old 12-16-2008, 12:17 AM   #3
huskynox
500CF - 3650's, 3500G, Spartan, Stock ESC, Stock Motor, TP 6s Pro Power 2700mAh
PROTOS - 3650's, 3500G, Spartan, Scorpion 3026-880, ICE Lite 100, TP 6s Pro Power 2700mAh
600E - 8717's, 8900G, Spartan, Scorpion 4025-890, CC HV85, TP Pro Power 8s 3850mAh
Kasama Srimok - 8717HV's, 8900G, AR7100R, Spartan, YS 91SR, Hatori SB19
huskynox is offline        Reply With Quote
Old 12-16-2008, 01:00 AM   #4
oldschool269
Love that orange canopy .,... hmmmm
Thats a nice build ... !!
Jason
Old 12-16-2008, 02:39 AM   #5
Jetleaf
My effort
I put the "__" in lazy
Jetleaf is offline        Reply With Quote
Old 12-16-2008, 05:43 PM   #6
tibbs
Hey Jetleaf, where did you get the coloured gears and strap
cheers
Tibbs
RAPTOR 50
PLANKS
HITEC AURORA 9
OLD FART !!!!
tibbs is offline        Reply With Quote
Old 12-16-2008, 06:12 PM   #7
Jetleaf
Gears and servo arms are dyed. The strap was stitched on a home embroidery machine
Old 12-16-2008, 09:42 PM   #8
silvio600
? dyed? whats that sorry i dont understant
Old 12-16-2008, 10:43 PM   #9
heliMark
HF Video Underlord
more than likely using a fabric dye like RIT. Great pictures, keep them coming!
Mark Schneider Team Rotor Rage, YS, RC Accessory, Poweredge batteries, Perfect Regulator.
Fury 55, Trex 700, Trex 450
heliMark is offline        Reply With Quote
Old 12-16-2008, 10:47 PM   #10
Jetleaf
Yeah RIT fabric dye.
Old 12-17-2008, 01:16 AM   #11
tibbs
Hey Jetleaf
do you want to sell a couple of those straps?
cheers
Tibbs
RAPTOR 50
PLANKS
HITEC AURORA 9
OLD FART !!!!
Old 12-17-2008, 04:22 AM   #12
oldschool269
BEST beam so far ....
that's got some NICE detail ... !!!
i never knew you die the gears.. thats nuts , ritt fabric die , where the heck can i get that DOWN UNDER >>????
sweet ride !!
Jason
Old 12-17-2008, 03:40 PM   #13
Jetleaf
Thanks Jason. I have always found the RIT dye in the grocery store on the same aisle as the laundry supplies. You can get it from the RIT web site as well http://www.ritdye.com/home.lasso
Old 12-17-2008, 10:04 PM   #14
billbill242000
What speed control did you go with it jetleaf?
All I can say is "WOW!!"
billbill242000 is offline        Reply With Quote
Old 12-18-2008, 12:43 AM   #15
VAN ORDEN
nice pics, i have a beam on the way, it is stuck in colorado because of weather. but ill post pics when it comes
VAN ORDEN is offline        Reply With Quote
Old 12-18-2008, 01:23 AM   #16
Jetleaf
I have the Scorpion 35amp commander and the -8 motor. I've tried the 13,14, and 15 tooth pinions. 13 is more than enough for sport flying. 14 tooth makes for a lively experience and the 15 makes the Beam very quick. I'm talking 450 heli with Gaui 200 reflexes. Don't blink.
Here's an updated pic. The previous ones were taken back in April. The only major changes are the Radix blades, Hyperion tail blades, paddles, landing gear, and minor cosmetic bits. This heli has held up very well after a few crashes. Motor, ESC, servos are the ones installed originally.
Old 12-22-2008, 05:08 AM   #17
Simarion
all the way from sunny singapore
setup : scorp -6 with 10T , 55A V2 esc
ID:	73388   Click image for larger version
ID:	73389   Click image for larger version
ID:	73390   Click image for larger version
Simarion is offline        Reply With Quote
Old 12-22-2008, 08:13 PM   #18
oldschool269
Simarion ,, swap your tail servo to the other side of the boom... that way if it has a bad crash the main blade cant chop the back off the servo case
if its mounted on the other side then the main blade will hit the boom not the servo
looks nice
Jason
Old 12-22-2008, 10:29 PM   #19
Simarion
hmm ok
Old 12-23-2008, 09:37 PM   #20
nitro_joe
Here is a pic of my E4. Running a Scorpion 8v2 with a Scorpion 55A ESC - HS65MGs on the head and a HG-5000 Gyro with a HSG-5083 tail servo.
I just bumped it up to a 12T pinion and I am loving the Beam.
nitro_joe is offline        Reply With Quote
