Go Back   HeliFreak > R/C Helicopter Support > Beam
Beam Beam Helicopters Factory Support Forum
Old 11-16-2009, 03:45 PM   #61
marfdaman
LOL it's the tail blades Other than that she's looking good!
Beam E4: 6S powered, Spartan DS760+Hitec 5083MG, Red Devils, Stubz, KBDD tailblades, Hitec HS65MG, Fusuno
MSH Protos: TP 2650 45C, Scorpion 880 on 14T, YGE 60A, JR8900, DS510, SAB Red Devils, KBDD Tailblades, Mini VBar V5.0!!!
marfdaman is offline        Reply With Quote
Old 11-17-2009, 01:21 AM   #62
briangp
Swap 'em to trailing edge control while you're at it
AMA# 655558
Trex 600E, Compass 6HV FBL Head, Microbeast, Inolab DS760MG cyclic, Logictech 6100G tail, CC HV85 ESC, Scorpion 4025-630
briangp is offline        Reply With Quote
Old 11-17-2009, 08:20 PM   #63
JACKD
Beam's all pretty much look the same . Black & red or orange & black. And thier all BAAAD ASS !
ps. Mine is orange & black
GAGLE 'O HELIS!
JACKD is offline        Reply With Quote
Old 11-18-2009, 02:03 AM   #64
Tommyzt
Default One more
And here is my other one "Goofy style" and both together (without KDBB)
ID:	125011   Click image for larger version
Tommyzt is offline        Reply With Quote
Old 11-18-2009, 08:18 AM   #65
marfdaman
Lol I like the goofy one the most!
Old 11-20-2009, 01:21 AM   #66
bjorn_sweden
And guess whats wrong on the last picture...
Itīs one of the tailblades that are in the wrong direction. But they look good together with that canopy, were did you buy them? Do they improve visability??
bjorn_sweden is offline        Reply With Quote
Old 11-20-2009, 08:47 AM   #67
marfdaman
Those are KBDD blades...very good blades and way more visible than carbon!
Old 11-22-2009, 01:46 PM   #68
billbill242000
Can you post pictures of this and what is the benefit of doing this? I have heard it has something to do with getting the set up in Rate mode to work correctly??
Thanks!!
All I can say is "WOW!!"
billbill242000 is offline        Reply With Quote
Old 11-29-2009, 02:19 PM   #69
LIVVI
Default Modified Beam E4
If wanting to run 6S in the Beam, I've discovered a couple of things.
What she looks like with an Align canopy or clear Beam canopy used as experiments for fitting the Outrage NRG 6S 1300mA batts inside.
The orange Outrage 6S 1300mA's fit without modification...less removing padding normally installed on the inside of canopy, gives 4-5 mm extra clearance without it. I am not certain, but have heard these orange 1300mA's are not being manufactured anymore.
Using the Dual Lock fasteners by 3M, instead of velcro helps, thanks HFG. Gets rid of the need for a strap as well.
I am using EC3 connectors for personal comparison too the Deans I used on the 3S system. They are larger, so I did not gain in space but they don't hinder the fittment.
One pic shows, the bottom portion of clear canopy cut-back 1/4" shy of edge of the bottom tray. This was my only attempt, and it is not difficult to cut. It is a snug fit with the Blue NRG batts.
billbill242000, if you have not already found it...check the Trex 450 Pro build videos...Finless covers the tail mod in several vids. I made the mod to my bird. Seems like less need to counter-correct...other than that, I'm too new to flying to give useful input.
Hope this helps anyone looking.
LIVVI
- Life, is a midget named Living; Living spends its' time searching for a Giant named Lives.
BEAM E4: Scorpion 1630; 12T \ Phoenix ICE 50 \ HS-65MG \ S9650 \ GY401 \ DX7 - AR7000 \ TP 325 \ XGEAR
LIVVI is offline        Reply With Quote
Old 01-23-2010, 04:38 AM   #70
Mikey77
Originally Posted by Jetleaf View Post
My effort
HEY jet cool strap and gear,looks awsome,would you mske me a stap like that and send it to me,i will pay for it,looks really cool and maybe a gear as well,getting the beam soon
feel free to say no
let me know
MIKey
Mikey77 is offline        Reply With Quote
Old 04-17-2010, 02:52 PM   #71
heli bob
feel free to say no
let me know
MIKey
how did you put some color to the gear and servo horns.
heli bob is offline        Reply With Quote
Old 05-28-2010, 03:10 AM   #72
charliebrown
And YES, I am aware of the fact that the tail blades are mounted incorrect. I have removed the tail and twisted the belt the correct way and reversed the blades and corrected my settings in the VBar
EDIT: Forgot the setup specs
Beam E4 V1
Mikado 450 VBar Head
Mikado Mini-VBar
Scorpion HK-2221-8 12T
Scorpion Commander V2 55
3 x Ino-Lab D202MG on cyclic
1 X Ino-Lab D261HB on tail
Edge Flybarless 325
KBDD Tail blades
Last edited by charliebrown; 05-28-2010 at 06:06 AM.. Reason: Added specs on setup
charliebrown is offline        Reply With Quote
Old 06-12-2010, 01:16 AM   #73
supra6
Ok I'll bite, and maybe a bit dumb, but why reverse the tail rotation?
supra6 is offline        Reply With Quote
Old 06-12-2010, 11:04 AM   #74
jockstrap
Recently scored a Beam E4 early Version..
I must say - this heli rocks! This is my first non-Align 450 and I love it...
Specs;
* Std Fibre blades
* Turnigy typhoon 2215 motor - 12 tooth pinion
* Turnigy Plush 40A esc
* Hitec HS65's on cyclic
* Futaba S9257 on tail
* Spartan 760 gyro
* AR6100 receiver
* Hyperion VX 2200mah batts...
I'm only a sport flyer and learing some 3D basics... So I do loops, rolls, flips, inverted, etc.. and this thing has great cyclic response - I'm using 40% expo and have put flybar weights on since the pics.. This was a tip I was given and placed them approx 1/3 down from the flybar cage and it really settled the heli down with not very much cyclic degradation at all...
I'm very impressed with the Beam E4 - that's all I can say!
ID:	162481   Click image for larger version
ID:	162482   Click image for larger version
ID:	162483   Click image for larger version
ID:	162484   Click image for larger version
ID:	162486   Click image for larger version
ID:	162487   Click image for larger version
ID:	162488   Click image for larger version
ID:	162489   Click image for larger version
ID:	162491   Click image for larger version
ID:	162492   Click image for larger version
ID:	162493   Click image for larger version
ID:	162494   Click image for larger version
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote
Old 06-19-2010, 10:41 PM   #75
Randall-68
Some really nice looking machines in this picture forum. I am a Beam owner also. I am fairly new to this hobby, and my wife says that I am now OCD with it. Although I have had some really frustrating moments in trying to keep my Beam in one piece for one reason or another I do have to say I really enjoy it. I will say that the Beam is one of the most indestructable Helis around. How many can say theirs have been run over by a van and all that happened was bent shaft and destroyed main blades.
Randall-68 is offline        Reply With Quote
Old 07-05-2010, 06:18 PM   #76
rablett
Default Beam E4 FBL
Skookum SK360 w/ Gaui head
HS-5065MG on cyclic
GY520 w/ S9257
AR7000
CC ICE Lite 75
Scoprion 2221-8
AUW w/ 2500mAh 3S pack is 846 grams
Name:	IMG_1040 800x600.JPG
ID:	166710   Click image for larger version
Name:	IMG_0961 800x600.JPG
ID:	166711   Click image for larger version
Name:	IMG_0983 800x600.JPG
rablett is offline        Reply With Quote
Old 07-17-2010, 11:35 AM   #77
Mikey77
Not the best phto..will post a better one soon and more
Old 08-24-2010, 06:57 PM   #78
akshaw
Here's a vid of me flying the beam last weekend. This heli is a blast to fly. I was having some fun!
BEAM: jazz 40, scorpion-8, 3xHS65mg, gy401+9257
FBL Compass Atom: Stock motor, YGE80, 3x9650, 9254
akshaw is offline        Reply With Quote
Old 09-27-2010, 03:05 PM   #79
Lplate
Still loving mine too. Although it's getting really old and worn.
Here's a recent flight of mine including crash with slow mo
Lplate is offline        Reply With Quote
Old 10-09-2010, 09:05 PM   #80
Bluerocktj
Here's mine, I kept the wiring real clean so as not to take away from the beauty of the frame. I'm tempted to paint the ESC black.
Beam - "Best Expert Acquired Man" - "Beautifully Engineered Action Machine"
Bluerocktj is offline        Reply With Quote
