Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-05-2009, 06:18 AM   #21
Mercuriell
Originally Posted by marshdave View Post
quick uk do alloy cnc servo arms for futaba & jr bang on the money real quality
Now they need to do a swash for the T700
John
Mercuriell is online now        Reply With Quote
Old 03-20-2009, 04:51 PM   #22
rcpilot6969
Default Kasama head assembly
Where did you get the canopy mounts that are shown in the pic of the head? Jim
rcpilot6969 is offline        Reply With Quote
Old 03-20-2009, 05:41 PM   #23
Mercuriell
I used a couple of QuickUK canopy mounts at the back so only two thumbscrews but nice and secure !
John
Old 03-30-2009, 03:43 PM   #24
Laurens
You don't seem to have much luck John, did you get more troublefree flights since your last update?
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 03-30-2009, 04:09 PM   #25
Mercuriell
The T700 is running very sweet now with its QUK servo wheels & clutch and Kasama head thx
John
Old 04-11-2009, 09:24 PM   #26
cbdane
Bit off topic. Apologies.
I've fitted my QUK clutch and flew yesterday and today but have two issues. (1) I installed it into a used (10 gallon) clutch bell but it still grabs like crazy at idle. Last night, I rechecked the clutch centering (G-Force mounts) and it looks perfect. After the bell warms up at the end of a flight, no grabbing at all. I'm assuming it will wear in but it's really hard to deal with for now. (2) The starter one-way is not consistently engaging and I have to spin the starter several times before the engine turns over. Not sure about this one.
Any thoughts?
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 04-12-2009, 07:00 PM   #27
Mercuriell
Any thoughts?
There's certainly less clearance with the QUK clutch and mine was a bit smelly for x2-3 flights but is fine now - that was also in ~ 10 gallon clutch. Your clutch bell couldn't be a bit out of round at all ? - no secret chicken dances you'd like to admit to ?
John
Old 04-13-2009, 01:33 AM   #28
cbdane
Humm, not that I'm aware. But who knows what my helis are up to out in the garage during the long nights... The Align clutch that I pulled out looks wonderful with a very light but even wear pattern on both sides. I've carefully put it away in case the the idle grabbing doesn't go away.
Old 07-07-2009, 10:35 AM   #29
John Cook
Location: Winnebago IL Where the politicians are MORE corrupt-Thanks alot Blago/Burris/Daley etc...
Any thoughts?
I have the same combo. G Force adjustable mounts, clutch bearing block, and Quick UK clutch. IT's very very grabby and hard to get the heli to idle. Sometimes it will idle down and then "reverse spin" which makes for a very freaky sound in the geartrain.
I've just resigned myself to holding the head until I'm ready to let the heli spool up. Adjusting needles is really a chore too. With the above mods, combined with Kasama main thrusted bearing blocks, and the Kasama head this sucker is hard to spool down. I get it as low as I can go in TH and then have to "drag" the blades for about 20 secs, letting my palm drag the blades as they pass, but not too much to tip the heli. Out towards the tips as the headbutton I can't get enough torque on it to stop the head.
Overall the Kasama head is flying well, but I'm getting some porpousing/ballooning in fast backwards flight, but need to "refine" my trim in my 12x from "4 steps" to 1 step, and that might help. No interaction on swash so that's not it.
The quality of the head is awesome, along with how you can program it for your flying styel. It's faster IMO than the stock head and will track a bit better even in most aggressive form. Especially with Axial rolls
KBDD
MKS Servos
Scorpion Power Systems/Batteries
Spartan RC
John Cook is offline        Reply With Quote
Old 07-20-2009, 09:27 AM   #30
John Cook
fixed about 95% of the porposing with a shorter flybar. I had this shorter flybar in with a group of 90 parts I aquired this past year. I think it's a 500 or 520mm flybar.
Tracks alot better now and still very very agile. I would caution anyone NOT to use the closest hole "IN" on the flybar carrier to mount the link ball. IT's either 4 or 1, I can't remember. #2 or #3 would probably be best with teh stock 570mm flybar. OR you can get a shorter flybar. In my mind anyway, running a shorter flybar might help save some energy on the head as the heli doesn't have to spin the paddles as far/fast compared to a longer flybar rod. Normally you'd lose some cyclic authority, but with the more aggressive settings of this head, I really can't tell, as it still is fast, but tracks so much better wtih the shorter flybar
KBDD
MKS Servos
Spartan RC
Old 10-17-2009, 01:37 PM   #31
John Cook
btw I managed to put my 700 into a tree the day I got back from IRCHA. I bent up my "mystery" flybar, which I have no idea what kit it came out of. Came with a big lot of spares I bought from a Freya guy to resell as I just wanted the Auroro/Avant head he had in there. Anyway, the stock 700 flybar was too long with how I had my head programmed with the most agressive flybar carrier setting. That mystery flybar was perfect. I tried a 490 kasama flybar and that was too short. The 520mm Kasama flybar is just about perfect. Good FF tracking, and tracks well through maneuvers. Still a wee bit tippy in hover though, so ideally maybe another 10mm length would do.
If I went to a less agressive setting on the flybar carrier it could probably be ok with the stock 700 flybar, but I feel I get less drag off the shorter flybar, and the head is alot more locked in yet more agressive than a stock 700 head. More like my Aurora or Outrage helis for sure. Just wanted to update you guys in case you want to try this head and are wondering about how to set it up etc...
KBDD
MKS Servos
Spartan RC
Old 11-29-2009, 08:47 PM   #32
robertckerr
does it matter which way the x brace faces on the Kasama blocks for the Trex 700, the distance looks the same whether it is front or back side.
robertckerr is offline        Reply With Quote
Old 11-30-2009, 12:16 AM   #33
robertckerr
I see they have to face the rear,
Old 02-06-2010, 09:05 AM   #34
John Cook
picked up a 2nd Kasama head used . Had to do grip bearings as the older ones were getting notchy.
Tip for these is to bang them out and then heat the grips to get the new ones in. Would take way too much force to get them in and not damage bearings.
I'm going to try the 2nd flybar position from nearest mid and try a stock 700 fly bar this time. I'm thinking if you use the Inner most/aggressive one, that a 540mm flybar would be ideal. the Kasama 520 works pretty well, but is still a bit too tipy in hover etc... while the stock 570mm trex is too pitchy in flight. The 540 would probably be right in the middle, and what my "mystery" flybar I bent up was.
KBDD
MKS Servos
Spartan RC
Old 04-16-2010, 10:15 AM   #35
Austin
About to spool up the Kasama head on my 7 hundie this morning. I hope I built it right!!
If the head preforms as well as it is built and looks, gonna love this thing.
Eric
Austin is offline        Reply With Quote
Old 05-02-2010, 12:59 PM   #36
Pulento
For the Freya there are three different part #'s available:
0404-347 490 mm
0404-348 535 mm
0404-711 555 mm
6HV, BLS451, Quark+MKS BLS990, Jive 80HV+Compass 540KV
3D+, Savox 1258TG, Spartan DS760+MKS BLS990, OS55HZ+Funtech B320
Rave ENV, Savox 1267MG@6.6V, BeastX+MKS BLS990, YS91SR+Hatori SB19
All controlled by a DX8
Pulento is offline        Reply With Quote
Old 03-04-2011, 01:12 PM   #37
465723359
nice heli
465723359 is offline        Reply With Quote
