Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 09-30-2009, 04:22 AM   #41
HK450NZ
Default 450 Lid
Here's another one
Cheers
ID:	117647   Click image for larger version
ID:	117648   Click image for larger version
HK450NZ is offline        Reply With Quote
Old 09-30-2009, 09:17 AM   #42
Jackfly
Originally Posted by dauste View Post
Thanks! I'm glad you like it. Here is another slightly more basic one I did afterwards for my flying buddy.
Hi Dauste,
awsome job done ! I really like the one for your buddy...
Could it be possible to have any info's about how you managed to paint / print the black & white draughtboard ?
Do you also have the template (dimensions) for the "black cockpit" ? It's quite different from what is usually made... I love it too.
Jackfly is offline        Reply With Quote
Old 10-01-2009, 12:20 AM   #43
skigmata
Default Blade 400 canopy.
My 400 canopy with pics of my other babies on it. My Heckler and Koch HK45 and my Ruger MK II
ID:	117784   Click image for larger version
ID:	117785   Click image for larger version
ID:	117786   Click image for larger version
skigmata is offline        Reply With Quote
Old 10-06-2009, 12:58 PM   #44
dauste
I just put some strips of masking tape over the area and drew the draughtboard design by hand in pencil, cut through it with an exacto and picked out the odd squares and sprayed it black. Picked out the other squares when it was dry and just went around the edge to create the shadow under the tear.
The black screen is the stock Furion screen and the other one was painted on the same shape. Some other Furion canopies are here: http://www.helifreak.com/showthread.php?t=108343
dauste is offline        Reply With Quote
Old 10-08-2009, 04:00 AM   #45
Jackfly
Thanks for the info's
I just tought you were using a "printed" template for the draughtboard... What a job ! but the result is worth the effort... ;o)
I've an old X-cell 60 and I am looking for an original deco for the canopy... The black screen looks too good... I'll try to reproduce it.
Thanks for the link.
Old 10-19-2009, 05:36 PM   #46
7wt
Since I used to own a Mini Titan, I thought I would paint a canopy for it. It's all Auto Air.
7wt is offline        Reply With Quote
Old 10-22-2009, 07:46 PM   #47
Blades345
Here is my first attempt!
ID:	121187   Click image for larger version
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!!
No helis right now! Maybe I'll be back in another year!
Blades345 is offline        Reply With Quote
Old 10-24-2009, 05:17 AM   #48
aww
Default Nothing fancy
Nothing fancy, just done with rattle cans.
Anthony
Trex 600n, 700N, 700 3GX, 450L
aww is offline        Reply With Quote
Old 11-09-2009, 06:35 PM   #49
mort99
These are great!
mort99 is offline        Reply With Quote
Old 11-11-2009, 10:35 AM   #50
PC12DRVR
House of Kolor neons, three clear coats wet sanded between
ID:	123941 Click image for larger version
Name:	Trex 700 2.jpg
Name:	Stratus R Small.jpg
ID:	123943 Click image for larger version
Name:	Straus L Small.jpg
PC12DRVR is offline        Reply With Quote
Old 11-11-2009, 07:16 PM   #51
RChristopher
I didn't paint them, but wanted to show a couple of canopies just received from Alfredo Salleh, Helifreak user: Alf_flash. Very nice work!!
Cheers
Bob C.
T-Rex 500 ESP
T-Rex 250
RChristopher is offline        Reply With Quote
Old 11-20-2009, 08:54 AM   #52
JimLerch
Mirrored canopy windscreen and water based air brush colors from the craft store. Clear coated with epoxy.
James Lerch - Raptor 90, JR Vibe 500E*, Gaui 550E*, Xcell Razor* (*=On Loan)
http://lerch.no-ip.com/atm (My homebuilt telescope site)
http://lerch.no-ip.com/ChangFa_Gen (My 15KW generator project)
http://www.youtube.com/profile?user=JlerchTampa (my you-tube crash videos)
http://lerch.no-ip.com/Hat_Cam ("Hat Cam" for recording flights)
JimLerch is offline        Reply With Quote
Old 11-21-2009, 11:04 AM   #53
Scotty123
Well here's my third one which I did for a friend of mine... I used a three stage pearl black with a gold flake top clear coat....
It can only really be seen in sunlight .....All standard 1 pack car paint, through the airbrush.. ..
Any one else find this get's quite addictive...
ID:	125501   Click image for larger version
Scotty123 is offline        Reply With Quote
Old 11-24-2009, 12:45 AM   #54
rz500
Default 30 min job
Here's what I did in about 30 mins with some tamyia paint and some drywall fibre tape, you can see I rushed it but I wanted to see what it would turn out like. what could you call it " off shore carbon fibre " or aome sort of reptile...?? Its my first try.
Cheers
RZ
ID:	125922   Click image for larger version
ID:	125923   Click image for larger version
rz500 is offline        Reply With Quote
Old 12-01-2009, 07:50 AM   #55
fastone93
awesome canopies!
fastone93 is offline        Reply With Quote
Old 12-02-2009, 06:33 AM   #56
reaaz
rz500, nice... thinking your technique will work nicely with two tone colour fades
reaaz is offline        Reply With Quote
Old 12-23-2009, 03:58 AM   #57
Chuck Norris
well, its not paint, just experimenting
ID:	130124   Click image for larger version
ID:	130125   Click image for larger version
Chuck Norris is offline        Reply With Quote
Old 12-23-2009, 08:54 AM   #58
kevinl7778
it looks good but you may not be able to see it up high?
Just had my first baby, Chloe 8-oct-2011 so with my heli's i dont get to play: Trex 600N, Blade 400, PKZ P-51, PKZ Radian Pro.
kevinl7778 is offline        Reply With Quote
Old 12-23-2009, 12:54 PM   #59
Chuck Norris
probably right- ill try it for a while and change if it gives me problems.
Old 12-26-2009, 11:01 PM   #60
X-Gear
heres a couple of pics of my latest
Name:	clay canopy4 700x.jpg
ID:	130734   Click image for larger version
Name:	clay canopy6 700x525.jpg
X-Gear is offline        Reply With Quote
