Old 09-05-2009, 07:41 PM   #41
nightflyr
Here's where i placed my CC85HV....
Old 09-06-2009, 12:25 PM   #42
NRPY
Does it get enough airflow inside the frame like that? I guess the answer is yes, but I'm using the stock Align 100A ESC, so I am concerned about cooling.
I agree mounting inside the frame is ideal from an asthetics POV.
NRPY is offline        Reply With Quote
Old 09-06-2009, 12:52 PM   #43
nightflyr
I have a 3 fan cooling system mounted internally. 1 on the motor, 1 on the ESC and 1 one the BEC so heat is no problem for me.
nightflyr
Old 09-06-2009, 01:10 PM   #44
NRPY
Oooh . . . cooling fans. Never thought about that. How are they powered?
Old 09-06-2009, 07:43 PM   #45
nightflyr
My lighting and cooling systems have there own flight battery so not to draw from my flight packs
nightflyr
Old 09-06-2009, 11:27 PM   #46
Scottyb410
Could you post a few picks of the fan positioning please?
Thanks,
Scotty
Goblin 700 KDE700XF-535, Vbar NEO 6.1, BL9180 9188, Kosmik Cool 160 Goblin 630 HK 4525-520, Vbar NEO 6.1, BL9180 9188, Jive Pro 120 Goblin 380 Xnova 3215-930, Vbar NEO 6.1, DS-3001HV, DS5005HV, Koby 90
Scottyb410 is offline        Reply With Quote
Old 09-07-2009, 12:37 AM   #47
NRPY
One thing ESP builders should note:
The bell cranks on the ESP model are 180 degrees opposite to those in Finless Bob's video, so his guidance on servo directions is therefore 180 degrees opposite too.
Old 09-07-2009, 03:53 AM   #48
nightflyr
Please be aware that Finless hasn't not done a 600 ESP build as of yet, the Video is the build of a 600 CF version.
For a full explanation on the setupof the bell cranks, servo linkages ETC please refer to post #26 in FAQ
nightflyr
Old 09-07-2009, 12:14 PM   #49
NRPY
nightflyr,
How much does that cooling setup add to your "all up" weight? Do you have CG balance issues with all your batteries up front? I'm really liking your layout.
Old 09-07-2009, 12:55 PM   #50
nightflyr
My lift off weight is 12.17 lbs, CG is dead nuts on. the cooling system weighs next to nothing neither does the lighting system.. the 3S1P battery that powers it helps to balance the heli
nightflyr
Old 09-15-2009, 06:14 PM   #51
nightflyr
Default Tail Improvement By Halley
A "tail safe" for the T Rex 600
I fly at a grass field and constantly worry about damaging the tail blades or the torque tube gears when the tail bumps the ground. Cracking the tail fin itself is also something I worry about.
So I replaced the 600 ESP stock fin with a 700 fin, which is made of thicker CF and has a longer tip so it will hit the ground earlier. Unfortunately, the point is also sharper, so I wanted to reduce the chance that it will snag on the grass or furrow into the soil dangerously. I've seen some balls on carbon rods, but I dug through my spares bin and worked out this easy solution.
Old 09-19-2009, 08:25 PM   #52
nightflyr
Default Making a 600ESP 3rd bearing block
Not sure if this has been done or not.... but it works..
I installed a 3rd bearing block into my ESP problem was is that it is a match for the upper blocks 19mm X 10mm X 5mm, the lower bearing being 17mm X 9mm X 5mm posed a problem. being that it was not going to fit correctly.
simple solution was to dismantle the 19 X 10 X 5 bearing take the outer casing and machine the ball bearing track down till it slid over the 17 X 9 X 5 bearing as a spacer sleeve.
just pop it into the block mount and bingo all good in the world!!
Old 09-20-2009, 06:52 PM   #53
blindpilot
Default trex 600 esp queston
I am setting up a 600 esp and was wanting to know about the servo arm that is on the inside of the frame the one that contrals the swash in the front of the helicopter. it rides on the bell crank with a set screw how do you set that up do you tighen the screw when the arm is level or what
blindpilot is offline        Reply With Quote
Old 09-21-2009, 02:33 AM   #54
kaon
The set screw can be tightened down anywhere on the shaft, doesn't have a flat right?
If it has a flat, then tighten it onto the flat. Otherwise, you should find that it doesn't matter.
What we want is for the push-pulls to be equal and not too long and not too short, and squared up when the servo is centered. I see no harm in using some subtrim.
For the left and right side cyclic push pulls, it is easier to sight along the holes of the Align servo wheels to get the push-pulls squared up.
kaon is offline        Reply With Quote
Old 09-21-2009, 03:38 AM   #55
nightflyr
Default Servo / Bell crank setup
Any questions concerning this ...Refer to posting #26
nightflyr
Old 09-24-2009, 12:24 AM   #56
HeLiJerSey
nightflyer..if your from long island...i will come to your house and pay you, i live 10 min from nyc..i just bought a 600 ESP...anyways excellant job!!
HeLiJerSey is offline        Reply With Quote
Old 09-24-2009, 08:09 PM   #57
Shef
edit
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 550 DFC 3GX, 600ESP V-Bar, 700E 3G
Shef is offline        Reply With Quote
Old 09-25-2009, 01:38 AM   #58
Vinger
Just buy a 19 X 9 x 5 bearing and all is well. Or you can use the stock 600E/N parts for the bottom bearing block.
Gaui R5, Henseleit TDR +TDR2, Banshee
Kontronik ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 09-25-2009, 04:29 AM   #59
nightflyr
At last inquiry BOCA does not have a yellow sealed no lube bearing in that size configuration available.
Also I don't know if a N is a metal block, E version I researched was a plastic assembly I assume it is not and prefer the metal over plastic, plus had the parts on hand.
nightflyr
Old 09-26-2009, 11:06 PM   #60
nightflyr
Default keep those TT bearings guys!
EatMorePizza
Im not sure if anyone posted this yet, but the bearing on the TT is the same as the bearings in the main grips.
I just cut the tube sanded the cut smooth and popped off the bearing. Simple.
20% of the world suffer from constipation, the other 80% don't give a S#!t.
