Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-18-2010, 10:11 PM   #61
Blades345
This isn't my video as I have no video camera yet to film mine, but I enjoy this video and its flying. This is the style I fly!
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!!
No helis right now! Maybe I'll be back in another year!
Blades345 is offline        Reply With Quote
Old 11-24-2010, 02:54 AM   #62
Geegar
Default Mattie-lodge flying trex 550 v bar
Mattie-lodge 550 V Bar fun
Hi All,
We had some good weather here in the UK recently and had a chance to shoot a quick video of me flying the Trex 550 heli FBL with a V bar fitted to it.
Very understated the 550 IMO!!!!!!!
Hope you enjoy it
With Music
Without music
Fast Lad Performance
Edge blades
Opti-power
Geegar is offline        Reply With Quote
Old 12-23-2010, 01:54 PM   #63
Nko15
Nko15 is offline        Reply With Quote
Old 01-09-2011, 05:47 PM   #64
CACN
Maiden flight of my 550 3g. I've never flown anything bigger than the Blade 400.
CACN is offline        Reply With Quote
Old 01-10-2011, 05:03 AM   #65
Nko15
Get rid of the normal mode... or make it more linear... you notice the rpm's dropping when coming down.
Old 01-13-2011, 11:06 PM   #66
CACN
What would you suggest the normal mode throttle curve be like?
Thanks.
Old 01-14-2011, 06:36 AM   #67
Nko15
So you dont get the hopping when the wind picks it up
Old 01-14-2011, 09:09 PM   #68
CACN
0-55-75-85-90
Thanks! I will try that setting.
Old 01-16-2011, 11:41 AM   #69
invertsick
invertsick is offline        Reply With Quote
Old 01-16-2011, 11:59 AM   #70
Nko15
If you already fly in an idle, i'd do that yes. but if youre flying(not hovering) in normal, than i wouldn keep as i said earlier
Old 01-17-2011, 02:25 AM   #71
invertsick
Whatever ur doing ur normal mode needs to be str8 curve,
Like 0- and 70s. Or 0 and 75s
Other wise you will have rpm changes which will make ur pitch control bumpy + will coz tail wag.
Thank you
Old 01-17-2011, 05:38 AM   #72
Nko15
rpm changes between 75 and 85 wont be that much. you're loading the head too i like having my normal around 0-50-55-60-65 so i know that i am in normal.. (inverted hovering doesnt work in normal..)
Old 01-18-2011, 12:48 AM   #73
invertsick
Just tell me wats the point of having that kind of curve and not flat curve.
Maybe wat ur doing is right,
But i want to know y??
Old 01-18-2011, 03:30 AM   #74
Nko15
with a flatline you will almost get a bladestop if you use the 12 degrees pitch if you have it set for less than 70 precent. it will bog very much and easy not.
recommended to do such things in normal though.. but that line keeps the rpm's more constant, as you begin to give pitch, rpms will drop, that curve will prevent that a bit.
For all people that want to fly with the most constant rpm. use a governor. problem solved.
Old 01-20-2011, 04:04 AM   #75
wouterd
not mine, but still worth to watch
wouterd is offline        Reply With Quote
Old 01-20-2011, 04:27 AM   #76
kouasupra
That's the man himself, Mr. Alan szabo jr.
kouasupra is offline        Reply With Quote
Old 01-23-2011, 10:32 AM   #77
mulicheng
Maidened my 550e with BeastX. Was really windy but the bird was as stable as I ever could have hoped for. No trims or anything required. It just worked.
Trex 550e FBL BeastX, Trex 450 se v2, Blade mCPx
And lots of those funny things with wings and a prop on the front instead of the top.
mulicheng is offline        Reply With Quote
Old 01-24-2011, 12:41 PM   #78
cdhfr
Smile Trex 550 FB Neu 1515/2.5D/F
Hi
Trex 550 E version flybar with Neu motor 1515/2.5D/F .. Rhino 6S 4900 25C
cdhfr is offline        Reply With Quote
Old 01-30-2011, 08:16 PM   #79
mulicheng
I got this crazy idea to film myself while I built my 550e. At the end, I time lapsed them all together and uploaded to youtube. I added a few tips as well. Probably not as many as you need to build the thing but I added a few of the things I got stuck on... like the direction of the frame bearings. It's long!
Old 01-31-2011, 02:34 AM   #80
Nko15
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
