Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 03-09-2014, 10:14 PM   #61
Russell Harding
Default How-To: Piro Flips with Video
Turn the sim down all the way and think of 'keyframes' like stringing together an animation of the helicopter a orientation as it goes through the flip.
With a full 360 piro per 180 flip, L rudder, you start down elevator stirring clockwise and will be at tail down skids in at knife edge holding nose up at the halfway point.
For a double, you'll do a full 360 piro by the halfway point, and will be nose down, skids in, knife edge starting your second stir with down elevator.
Here is a slow vid I made a while back:
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote
Old 03-10-2014, 01:36 AM   #62
ArchmageAU
+1 on all that.
Put simply, the rudder moves faster and the stir is faster to match the rudder.
Keyframing to get timing is the key as the heli is tumbling (you apply flip corrections at as many points as your mind can cope with )
Having good skills at tumbling and rolling on the spot helps too (as this is collective control).
ArchmageAU is offline        Reply With Quote
Old 03-11-2014, 06:51 PM   #63
leokat001
Thanks guys ! I have a lot of pratice ahead to get this one figured out. Thank you for posting the vid it has helped .
leokat001 is offline        Reply With Quote
Old 03-18-2014, 12:19 AM   #64
leokat001
Ok here is where Im at now feel like Im getting close .[/YOUTUBE]
Old 03-18-2014, 06:32 AM   #65
Russell Harding
You are sort of close.
Try slowing down more and doing each half of the flip separately.
Your video shows a half piro flip to inverted (tail in upright to tail in inverted with a 180 piro), and then a 1.5 piro flip, from tail in inverted to tail in upright with a 270 piro)
You have too little rotation on the first half and too much on the second. Break it down and slow it down and you'll get it soon.
Old 03-18-2014, 06:12 PM   #66
Aryemis
I'm just barely managing full piroflips irl now (only on the mcpx BL for now) and I started it (on the sim) by doing it half by half, and then trying to do the full thing.
I've found that if you mess up in the first half and don't arrive very well inverted it generally messes up totally the second part.
I can do them pretty well upright to inverted and then inverted to upright, still have a bit of issues when doing them fully though (on the sim, on the mcpx BL it's even harder because of the electric tail motor not really helping for the constant piro speed).
I really need to work on doing other piroflips than the right rudder/front flip one I'm doing right now.
I also need to try them out on the mini, but last time I flew I wasn't ready to try anything new as there wasn't great visibility + the pucker factor from those flights being the first 3 after my previous crash.
"Beater" Mini Prtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote
Old 03-21-2014, 12:27 PM   #67
leokat001
Thanks for looking . I will keep working at it .
Old 03-31-2014, 11:28 PM   #68
leokat001
Please tell me I got it this time . [YOUTUBE]
Old 04-01-2014, 01:28 AM   #69
Russell Harding
Yes. Those are three complete single piroflips. Now SLOW DOWN. You should be able to do these like mini-rainbows, that way you are controlling the whole time. If you practice these too quickly, you will have a very hard time transferring them outside the sim, and progressing to double piroflips and other piro moves. You have the key to the move now though. It will all come with time.
Old 04-01-2014, 04:52 AM   #70
ArchmageAU
Originally Posted by leokat001 View Post
Please tell me I got it this time . [YOUTUBE]http://youtu.be/K7ccu3Jsf8k
Yes you have it.
Those are double pirouetting pirouetting flips.
Complete, but unfortunately poor quality. The rotor disc does not follow an even end over end flip, it spirals around as it flips.
It's enough to call a piro-flip (by all HF'ers definitions), but you can always make it better.
Old 04-16-2014, 05:19 PM   #71
mic-21
I have been working on this move for awhile now and this is what I got so far , still need to smooth it out :
mic-21 is offline        Reply With Quote
Old 04-16-2014, 05:28 PM   #72
Russell Harding
Very, very good. Obviously you have the move figured out. Now it is time to clean it up. I'd also suggest getting a consistent number if piros per flip. Now all you need is time.
Old 04-16-2014, 06:45 PM   #73
Trexwilly
I try and slow them down in this video, I lost a little bit of position control, but the point was to try and show the move, It has been a long road to get here, and I foresee many more hours of practice to get them solid!
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote
Old 04-16-2014, 07:34 PM   #74
mic-21
Thanks Buddy , I like to have 3 Piros per Flip . I may try 2 piro but 1 is to quick and look like rushing
John.
Old 04-16-2014, 09:46 PM   #75
Russell Harding
Most of the time when the pros are flipping on the deck, they are doubles. Tight enough to look good bit enough spins to smooth out.
Old 04-26-2014, 06:40 PM   #76
Hondawasaki
@Raza excellent how to videos ... just another HF'er saying thanks . with out your how to I'd have no idea where to begin ... Ive only got the very first half of the half flips down sloppy . but I know with time and practice i will be doing doubles eventually .... and i still need more basic inverted time which should help greatly ... ( as u suggested in the first sentence )
Nano cpx ... mcx2...Devo-10 tx running deviation firmware
Hondawasaki is offline        Reply With Quote
Old 02-23-2016, 10:18 PM   #77
heli227
Question Help
I started learning Piro Flips, but it looks different when I do it from the instructional video.
What am I doing wrong? I have no idea what is going on.
heli227 is offline        Reply With Quote
Old 02-24-2016, 04:03 PM   #78
Steve Graham
Slow down.
You need to deconstruct the maneuver into the components of flip and piro.
by doing this for every degree of the maneuver you will end up with targets to aim for. In a 1:1 PF with left rudder flipping away from yourself you can start with at least 3 target positions. First, upright tail in. Second, disc on knife edge skids in and tail pointing straight out horizontally to the right. Third, inverted tail in.
Until you know what it should look like you'll never know if you actually did a PF or some flippy twisty looking something else entirely.
Steve Graham is online now        Reply With Quote
Old 02-24-2016, 08:48 PM   #79
dgunawan
I'm still learning too, tho not a priority given my level. But I use these videos for tips/tutorial.
dgunawan is offline        Reply With Quote
Old 03-07-2016, 07:41 PM   #80
vhuzalo
Finally I've managed to do some piroflips more close to the ground!!!
vhuzalo is offline        Reply With Quote
