Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 03-28-2016, 11:05 AM   #81
heli227
How do you keep from losing altitude during piro flip?
I give it a little collective before each half to push it up when the disk is flat, but during the piro flip the heli falls a lot. How to keep it from falling?
heli227 is offline        Reply With Quote
Old 03-28-2016, 11:56 AM   #82
Steve Graham
Can you flip, non piro, while holding the model in place?
Isolate the collective for that maneuver and focus on it. It is EXACTLY the same collective inputs required to piro flip.
Timing and degree of collective inputs are everything for holding piroflips in one spot, or moving them around for that matter.
Steve Graham is offline        Reply With Quote
Old 06-12-2016, 06:47 PM   #83
Wargamer
Been working on this and the main challenge is that there's a lot more going on with piro flips than with simple flips. First problem when learning is that you're going fairly slowly. You're going to lose altitude until you can get the movements down so you can do them quickly. You also spend a lot of your focus on all the other stuff that's going on, which tends to cause a bit of a delayed reaction with the collective.
Breaking things into parts always helps. Working on just the first half of a half piro flip for an hour in the sim, I was able to eliminate a lot of the altitude loss. Definitely takes practice.
Compass Atom 5.5 - Oxy 3+
Blade 230S - nano CPS - XK K110/K120
Wargamer is offline        Reply With Quote
Old 06-14-2016, 10:11 PM   #84
Wargamer
Awesome but brutal practice tool for piro flips once you start to get the hang of them at altitude...
In Heli-X hover training mode, with full control of all channels, start at the center of the bullseye with the heli just above eye level. The goal is to piro flip without hitting the ground or moving outside the bullseye. Start with just the first half of a half flip (so you end hovering inverted and tail in.) Gradually work up to doing both halves of a full one.
Old 01-14-2017, 08:19 PM   #85
bazsound
What do u think if my half half piro flip
Justbclicked today after a few hiurs prsctice tiday and yesterday.
The first 2 days were another broken down excersise for piroflips.
bazsound is offline        Reply With Quote
