Old 10-15-2010, 04:08 AM   #21
Steve Evans
You wanted to see neat, I guess, so... this is what can be achieved if you shorten your leads and crimp on new connectors. No messy bundles of cable.
ESC cable also shortened to the perfect length. Shows one antenna in short length of tube.
ESC is mounted on front of bottom plate using a cable tie through a couple of extra holes.
ESC cabling to motor runs neatly underneath.
Gyro cabling coiled to reduce vibration. Servo connector inside frame. Servo cable supported in braid. Also shows one antenna.
Hope that give you a few useful ideas.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 10-15-2010, 08:43 AM   #22
WBFAir
Steve, nice to see a fellow Futaba man!
Seems to be fewer and fewer of us huh.
Real real nice wiring work.
I myself was thinking of shortening the wires on my build and even bought the tools & the terminal kits & plugs and tried a few off attempts but wasn't 100% happy with the results.
That wire is so thin an small and it really takes just the right feel for getting the terminal crimped without going to far and crushing it that all in all I just was to worried about one bad connection bringing the helo down that I opted for the bundling.
That was three years ago and since then I had done quite a bit for it my O scale trains now and gotten pretty good but still, those don't fall out of the sky.
But it looks like you got the hang of it and my hats off to you, very very nice cabling.
Originally Posted by hellafreaky View Post
Beautiful work guys and thanks for sharing, all of you.
Where do you buy the black mesh sleeve material?
hellafreeaky, I got a lot of my stuff from CableOrganizer.com
Specifically here: http://cableorganizer.com/wire-management/
One of the things I liked that I could get here, along with such a hug availability of sizes, types & colors, was also the multiple ratio heat shrink too.
In the heat shrink section there are 2:1, 3:1, 4:1 & 6:1 which all means a much larger dia to start that then shrinks down a great deal to the finished size.
This then allowed me to cover things such as the deans connectors and other types of larger items that then the extra could hang over its neighboring part so then when shrunk, all then tightened down nicely over every thing.
All in all yes there was a lot more figuring out on everything I had to buy, (and for sure, a bit left over) but in the end all the choices made the eventual outcome very nice.
Best of luck with it all
WBFAir is offline        Reply With Quote
Old 10-15-2010, 11:29 AM   #23
Starcruiser
One of my 450's
ID:	185037   Click image for larger version
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
Old 10-17-2010, 09:35 PM   #24
vessel02
Hey Guys this is Great! Lets keep this thread fresh so others who are wiring or will eventually wire there helis will have some thoughts to go off of!! How do we ge this tread stickied!? can just anyone do it or does a higher up have to! who ever can, lets do it!
I am almost finished with my heli, ill post pics soon! thanks for starting this thread guys!
vessel02 is offline        Reply With Quote
Old 10-18-2010, 12:30 AM   #25
Intact
Wow, very impressed that you shortened your wires Steve! Thats what i've really wanted to see done on these. Thats how i would do mine if i were pro. Good job.
Align Trex 450 Sport - Align Metal control arm and Metal VSM
- Spektrum ar6110e Rx, Airtronics 94809s, Hyperion 3s 2200mah 35C
- Align 325mm Pro / 325D Carbon Blades, KBDD Flybar Paddles + Tail Blades
Spektrum DX7 - Phoenix R/C Flight Sim
Walkera 4G6S
Intact is offline        Reply With Quote
Old 11-15-2010, 11:12 AM   #26
lazor 22
Let's get this thread going again!
Lincoln
#HIGHONHELIS ):>
Pull Hard
lazor 22 is offline        Reply With Quote
Old 11-15-2010, 03:26 PM   #27
Tag1260
How do you guys do the "pig's tail" wiring thing? Looks pretty neat on the gyro wires.
Tag1260 is offline        Reply With Quote
Old 11-15-2010, 03:45 PM   #28
vessel02
I finished up with my wiring a few weeks ago, but I have yet to take some pics! Hopefully tomorrow Ill have some pics to put on here! I love a Clean Heli!
Old 11-15-2010, 03:57 PM   #29
gravydrive
Just wrap the wire around something cylindrical, like a screwdriver. The wire will retain the circular shape.
gravydrive is offline        Reply With Quote
Old 11-15-2010, 07:24 PM   #30
crpearson
Anyone else think this thread would make a good sticky?
crpearson is offline        Reply With Quote
Old 11-15-2010, 08:31 PM   #31
flerpie
Durned tootin' this would make a good sticky!
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 11-16-2010, 08:48 AM   #32
scottalesibowm
Default My wires
Here's my wires!! LOL!!
T-rex 600N Dfc, SAB Goblin 500
DX8
scottalesibowm is offline        Reply With Quote
Old 11-16-2010, 02:48 PM   #33
lazor 22
Is your tailboom bent?
Lincoln
#HIGHONHELIS ):>
Pull Hard
Old 11-17-2010, 02:38 AM   #34
markleyland
It does look bent?
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 11-17-2010, 08:12 AM   #35
scottalesibowm
No, there isn't a bat in the heli so it's leaning back on the tail fin.
DX8
Old 11-17-2010, 10:22 AM   #36
vessel02
STICKY! STICKY! STICKY!! WE WANT THIS STICKIED!! can someone help Pleeeeeaaaasssseeee!!!
Old 11-17-2010, 12:14 PM   #37
kenkadish
As a newbie just about to start the build of my 450 Sport, this thread, which I just found, will be invaluable once I get to that stage. Thanks!
kenkadish is offline        Reply With Quote
Old 11-18-2010, 10:05 AM   #38
arturoo1977
Can someone post some general guides to wiring a Heli? Do's and dont's... All this pics are very ilustrative but I'm sure there are a lot of "rules" that a pic cannot tell to a newbie...
Arturo
HK450V2, HK450Pro, GAUI Hurri425
arturoo1977 is offline        Reply With Quote
Old 11-18-2010, 10:29 AM   #39
flerpie
Mebbe others will have do's and dont's but I've found that it mostly
comes down to wiring/soldering skills and personal build preference.
Keeping ESC/motor high-current wires as far away from low-current wiring
(like servo wires...Rx antennas) is about the only rule I follow.
If you mess with the wiring, like removing plugs, shortening wires, etc.
you void your warranty. I void all warranties instantly.
Product has a warranty? Not when they sell it to me.
So for all new servos that I buy - I throw them on a servo tester
and see if I have an OOBF, out of box failure. Then after I know
that I don't have to return it I'll hack up the wiring and do what I want.
Build Different!
Old 11-18-2010, 11:23 AM   #40
markleyland
I'm the same with cutting wires, just be carefull with the gyro wire because if you want to put it on another heli after upgrading you might find your options are limited as to placement.
P.s If you put all the 'Show off your wiring' threads on this forum together it might make a good sticky.
