Old 11-02-2016, 02:08 PM   #521
Kootenai Rider
Here is my 470L build. I custom sized the servo wires, crimping on new plugs. I shortened the ESC wires a little. This was the best solution. They're close to the motor, in fact I don't have the top frame cross member. The S-Bus Futaba RX is just mounted to the bottom plate.
Tight ESC wiring. I shortened the ESC wires.
Placement for proper CG of 2200mah NanoTech
Kootenai Rider is offline        Reply With Quote
Old 11-02-2016, 06:35 PM   #522
rdlohr
Lookin good!
Rick
Helifreak, the place to be!
Rush 750 w/VBAR,Logo 400SE, 600SE w/NEOs, TREX 450SE, 500, 600, Blade mCPX,130X, 180CFX, Nano QX, MiniProtos w/BD3SX
rdlohr is online now        Reply With Quote
Old 11-11-2016, 02:53 PM   #523
AllanNg
My 470L
AllanNg is online now        Reply With Quote
Old 11-11-2016, 05:46 PM   #524
kenkadish
Are those motor wires bent as sharply as they look (pic 2) or just the picture angle?
Ken
Blade SR - 865 flights; Blade MCPX - 921 flights
Trex 450 Sport - 684 flights; Trex 450 Pro DFC - 163 flights
Trex 500e - 213 flights; Blade 300x - 300 flights - Trex 550 DFC - 51 flights; Blade 130x - 87 flights........Learning every day!
kenkadish is offline        Reply With Quote
Old 11-13-2016, 06:03 PM   #525
Kootenai Rider
Ken
Yes, yes they are...I don't think its stopping any electrons though. Its about 2mm from rubbing the motor, but doesn't touch.
Old 11-13-2016, 06:28 PM   #526
LEORITY
Default Show Off Your Wiring!
Originally Posted by AllanNg View Post
My 470L
Hey, does anyone know if I can use the 470L canopy mounting bolt in my 450L? (Broke it in a crash... )
Nice wiring by the way!!
T-Rex 450L Dominator | T-Rex 450PRO DFC
MCPX BL heavily modded | DX9... and a lot of effort and passion!
LEORITY is offline        Reply With Quote
Old 11-21-2016, 10:32 PM   #527
AllanNg
Im not sure. I will measure or might even test them out and let you know.
Old 11-21-2016, 10:55 PM   #528
LEORITY
No worries mate. Thanks heaps !
Old 12-15-2016, 10:52 PM   #529
siguy2k
Sent from my LG-LS997 using Tapatalk
siguy2k is offline        Reply With Quote
Old 12-16-2016, 08:23 PM   #530
siguy2k
Better pics!
Old 12-20-2016, 12:59 AM   #531
rlane4osu
My first attempt sleeving with paracord. Turned out okay, just looks a little "snakey"?? Doing it again I would have bought a crimper and shortened the servo wires.
Sent from my Pixel using Tapatalk
rlane4osu is offline        Reply With Quote
Old 12-20-2016, 01:53 AM   #532
HeliLust
I would have never thought of Para chord. Great idea that looks really nice. I have tried the finger trap sleeve stuff and it sucks.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 700N
Team Align Enterprise Hobby Facebook Align Part Finder
HeliLust is offline        Reply With Quote
Old 12-20-2016, 03:33 AM   #533
RFCXPerT
Default T600 CF in 500E
I reconfigured some from the original owner such as battery tray at angle up now (was flat in front for better CoG but too unsafe for packs), ESC on the frame now (was angled on the battery tray), BEC on level frame now, wires around in back frame now so much cleaner with just right distance for ESC to pack connector (no loose wires).
ID:	684919   Click image for larger version
ID:	684920   Click image for larger version
ID:	684921   Click image for larger version
ID:	684922   Click image for larger version
ID:	684924   Click image for larger version
ID:	684925   Click image for larger version
RFCXPerT is offline        Reply With Quote
Old 12-20-2016, 08:30 AM   #534
rlane4osu
Yeah, I bought a used heli with the finger trap stuff. It's nice you can fit it around a servo connector but that's about all I liked about it.
I bought 50' of 1/8 inch paracord at Home Depot for under $3 bucks and went to town. You'll need to remove the pins from the servo connector separate the 3 wires from each other. Then feed one after another (only about an inch or so apart) to fit through the paracord. Just be sure to slip your heat shrink over the ends as soon as you cut it because it more difficult when it starts to unravel a bit.
Old 12-20-2016, 09:40 AM   #535
RoboHeli
I've had the same questions about the finger trap sleeve stuff as well. I bought some of it from Hobby King a while back but it always unravels into a pile of useless plastic strands when I try to use it. I figured there must be a trick for working with it but I've yet to figure it out.
* 450X, 180CFX, 130X, V120D02s, mCPX BL, nCPX w/pjacq BL, mCPX v2, Super CP, & lots of FP micros!
* DX7 G2, Devo 10 & 7e w/Deviation, Turnigy 9x w/ er9x, & DX6i.
* RCHN 129
RoboHeli is offline        Reply With Quote
Old 01-05-2017, 09:11 AM   #536
J13ME
Here is mine. Not as neat as most! I need some of that black paracord. Looks great for the few exposed wires!
J13ME is offline        Reply With Quote
Old 01-05-2017, 10:10 AM   #537
UCPharmD
I'd use that Dyson in the corner to suck up all that extra wire, lol.
But seriously, I'd route that one wire over the side somewhere else and give it a lil slack. Looks taught and laying on a carbon frame you're asking for a short eventually.
Goblin 380 / 500 / 700C / 700KSE / ZMR250/ QAV180/ VAS Banshee/ VAS Wraith Micro/ MSH Brain FBLs/ HW ESCs/ XNOVA Motors/ Jeti DS-14
UCPharmD is offline        Reply With Quote
Old 01-05-2017, 05:37 PM   #538
J13ME
Thanks for that! I struggle to run it anywhere inside as it would need to go over the torque tube gear set. I'm at the stage of learning and I'm replacing gears every flight
How can I shorten the cables going into receiver?
Old 01-05-2017, 06:16 PM   #539
CZorzella
You can either cut excess of cable and resolder the ends or you can crimp new servo leads after you cut the cable to correct length.
There are several threads about subject and so many "how to" videos on you tube. A google search brought lots of them; this is a link that I selected at random.
RC Quick Tips - How to crimp servo leads
Carlos
CZorzella is online now        Reply With Quote
