Old 11-18-2010, 12:31 PM   #41
crpearson
I only know of two guidlines:
1) Keep the big wires away from the little wires (motor stuff separate from radio stuff)
2) Use the ferrite ring, even though it looks ugly in a wiring job that is otherwise nice and clean
As far as warranties go... Pfshh... The only good warranty is a voided warranty!
Cliff
crpearson is offline        Reply With Quote
Old 11-18-2010, 12:57 PM   #42
crpearson
Originally Posted by markleyland View Post
P.s If you put all the 'Show off your wiring' threads on this forum together it might make a good sticky.
Well, if we made this one sticky, perhaps there wouldn't be a dozen similar threads to follow it. You have to start somewhere, but if this one falls off the front page, another one like it is sure to follow.
Old 11-18-2010, 01:22 PM   #43
flerpie
I keep the ferrite ring if it's appropriately sized. Sometimes you get
a big old honkin' toroid - those go in the trash. Toroids were more effective
back in the day of lower frequency radios, but I keep them anyways.
They really help with legacy radios.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 11-18-2010, 02:28 PM   #44
markleyland
True, True. Make it a sticky, Im easy. I might even get my camera out!
ID:	190716Click image for larger version
ID:	190717Click image for larger version
ID:	190718Click image for larger version
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 11-20-2010, 06:41 AM   #45
DonDuc
Markleyland: it appears that the spartan is tilted agains the rotor shaft. As far as I understand, this is far from ideal as rotations around other axes will trigger a response from the gyro
Here are some pics of mine. It doesn't look clean but it works...
The two unused servo connectors on either side of the rear frame are for conecting a Rx pack for setup and for the castle link. The two black tubes sticking out the rear house the Rx antennas.
ID:	191008   Click image for larger version
ID:	191009   Click image for larger version
ID:	191010   Click image for larger version
TRex 500 ESP
several hybrid 450s with bits from Align 450SEV2, CopterX, BEAM E4 and Outrage G5
Walkera 4G3 dbl BL
DonDuc is offline        Reply With Quote
Old 11-20-2010, 06:59 AM   #46
markleyland
Never had any issues with it like that, solid as a rock?
Old 11-25-2010, 01:31 AM   #47
Santini
I like to use color.
"The Great Santini"
Futaba 8FHGS; Logo 600 3D FBL:, 4035-500, 12T, 12S, Jive80+HV, Futaba 6203SB, Fullsize V-Bar 5.1pro (Vergnugenstabi), BLS 451+251; Align 500esp: TracX FBL, 14T, ICE75, Beastx v3
Santini is offline        Reply With Quote
Old 11-25-2010, 02:55 AM   #48
Steve Evans
Santini,
You've run the braid right up to the servos, for example the rear one is clearly visible. It may look neat but it's not a good idea. Braid stiffens the wire as well as supporting it, but the wire will still move (indeed vibrate). With the wire as you have it all that movement will be concentrated at the point where the cable enters the servo. This will make the cable prone to stress fractures. Instead leave half an inch or so of the cable unbraided to spread the required movement over a short length as shown below:
And that is a 500ESP and this is a 450 thread, but the same applies!
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 11-25-2010, 02:26 PM   #49
gravydrive
You can also run the heat shrink right into the servo case, or if the grommet is big enough, shrink right over it.
gravydrive is offline        Reply With Quote
Old 11-26-2010, 02:58 AM   #50
DonDuc
Agree with SteveEvans, I remember Finless saying something similar in one of the vids. He also says that stiffening up everything including the gromet, like gravydrive suggested, is not recommended as it defeats the purpose of the grommet: with everything stiffened up outside, any movement / vibration would bend the wires inside the servos and may cause them to break at the solder.
TRex 500 ESP
Walkera 4G3 dbl BL
Old 11-26-2010, 03:00 PM   #51
flerpie
Sympathetic vibration is one of the reasons that RC wire is usually made
of many many more strands than regular stranded wire. That's why they
call it "noodle wire" cause it's so flexible.....to an extent. Even shrink
and especially braid adds to the mass of the wire and if not really tied down
it can lead to broken wires as others have said.
I don't braid servo wires because the braid makes it alot harder to hide the wires.
I don't want to see the wires. I want them hidden. Not inside of showy
braid that's way too big in diameter to begin with such as I often see.
I'll braid other wires but usually not servo wires.
Now, having said that...I still might braid some servo wires depending
on the space I have available and how well I can hide the braided wires.
Larger diameter wires like ESC and motor wires, I may braid them for bling
factor and anti-chafing depending where the run has to go.
Build Different!
Old 11-26-2010, 07:27 PM   #52
gravydrive
Noodle wire is what they call ESC battery and motor leads and is almost always 12AWG. Servo wire is just regular old 26AWG stranded wire. After thousands of flights on various helis I can say from experience that adding braided sleeving won't cause your servo solder joints to fail, regardless of who says it will.
Old 11-27-2010, 06:31 AM   #53
markleyland
+1 nothing to get all worried about. Worry more about wires exposed to sharp edges.
Old 11-28-2010, 06:37 AM   #54
markab
Here's my 450 sport, hitec down one side and CC ICE 50 down the other, this is my first build so hopefully this will work out...
markab is offline        Reply With Quote
Old 11-30-2010, 09:18 AM   #55
johnnychimpo
Wiring.
ID:	192625   Click image for larger version
Trex 450Sport, AH64D Longbow Apache
AMA 470413
NMPRA 26Q
johnnychimpo is offline        Reply With Quote
Old 12-06-2010, 08:51 PM   #56
CustomOne
Is it recommended to get the extra gyro mount. From looking through alot of the sport pictures, it seems like alot of you got the extra mount in some form.
Trex 450 Pro: Scorpion 2221-8, Quark+S2957, 3xHS-65MG's, AR6200, KBDD Everything, Gorilla Gear. Maverick G5 Blades
Trex 250 Beastx, 3x5065's+5084 on tail, 3900kv, 3g Head
DX7+Phoenix
CustomOne is offline        Reply With Quote
Old 12-06-2010, 09:33 PM   #57
johnnychimpo
You dont need no stinking extra gyro mount.
AMA 470413
NMPRA 26Q
Old 12-06-2010, 10:49 PM   #58
gravydrive
It comes in the kit.
Old 12-06-2010, 11:03 PM   #59
CustomOne
I meant the upside down mount for tail boom, and no i dont mean the rudder servo. But all is good. Think I have settled on a placement I like.
DX7+Phoenix
Old 02-11-2011, 12:33 AM   #60
helo_doggy
Make this a sticky. I went crazy looking for something like this. This great for us newbs
helo_doggy is offline        Reply With Quote
