Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-20-2013, 04:43 AM   #61
GMan0065
Smile Hello
new Here.
Align T-Rex 550E FBL 3GX
FlySky TH9X
GMan0065 is offline        Reply With Quote
Old 04-27-2013, 07:10 AM   #62
Varelco
Airframe
Kit: 2011 V1 flybar
Blades: Align 520 mm
tail blades: Align 90mm
Canopy: optional Align
Power system
Motor: Align 600M 1220kv
ESC: CC Talon 90
Main pack: Zippy 5000mAh 30C
gensace 4000mAh 30C
Electronics
Cyclic servos: Align DS610 @ 6v
Tail servo: Align DS620 @ 6v
FBL Unit: Mini Vbar 5.3 pro
Governor: internal CC
TX: Futaba 8FGS
Specs (flight notes)
Flight style: 3D
Head speed: 2500 and 2600
Flight time: 4min to 5min
Amp draw: ?
Upgrades
Align DFC head
Align DFC swash
700E 112T helical main gear, 11T helical pinion
600E auto hub with 0.8 mod auto gear
KDE one way bearing
Trex 700 tail fin
Metal tail fin clamps
Metal bell crank
KDE gyro mount
Metal servo horns
Mikado Logo 600- Vbar 5.3
Thunder Tiger Raptor E700- Vortex Pro
Align Trex 550 V1 DFC - Vortex
JR Forza 450 - Vortex Esprit
Varelco is offline        Reply With Quote
Old 05-16-2013, 06:37 AM   #63
willy000
Originally Posted by Varelco View Post
Airframe
Kit: 2011 V1 flybar
Power system
ESC: CC Talon 90
gensace 4000mAh 30C
Electronics
Upgrades
Are you sure you are getting 2500 and 2600 head speed with a 11 tooth pinion?
Have you checked it with a tachometer?
Thats the stock gearing the 550 DFC comes with and I cant get over 2250 head speed with the same gear you have just my batteries are 40C
willy000 is offline        Reply With Quote
Old 05-17-2013, 07:30 AM   #64
BlazinBones
Airframe
Kit: 2011 V1 flybar
Power system
ESC: CC Talon 90
gensace 4000mAh 30C
Electronics
TX: Futaba 8FGS
Flight style: 3D
Amp draw: ?
Upgrades
Align DFC head
Align DFC swash
KDE one way bearing
Trex 700 tail fin
Metal bell crank
KDE gyro mount
Metal servo horns
I agree with post above mine. I just ordered a 13T just so I can be able to get 2500 with the CC Governor. I'm currently on a 12T and the max I get is 2480rpm but It's having a super hard time regulating it.
I don't think 2500 let alone 2600 is achievable with an 11T Pinion gear.
BlazinBones is offline        Reply With Quote
Old 05-18-2013, 09:35 AM   #65
Varelco
Sorry guys I'm running a 12T pinion not 11T I misspelt it. Head speed has been tach'd at 2460rpm. Thats the most i can get out of this set up. on the original straight gears I could get 2600rpm.
Old 06-25-2013, 08:50 PM   #66
peerinto
Am i making more to this than need be? Two years ago i put together a Trex 500. I remember during the build when it came to the servos, they should move together when the swash moved in the position needed for front, back, side to side. If one was moving in the wrong direction you would in your radio reverse it till all worked together. I hope i am explaining this right. Pilots i now have a Trex 550E V2 3GX and looking on line (YouTube) some say take a receiver and bind it to you radio and then work with the servos till you get them going in harmony together. Others say install your servos, don't connect the arms and turn on the 3Gx and set the limits from their. Just make sure you update the software first. What should i do?
peerinto is offline        Reply With Quote
Old 07-04-2013, 10:44 AM   #67
Nelvick
Airframe
Kit: 2012 V2 flybar
Blades: Edge 523 mm
tail blades: Edge 87mm
Canopy: Original Align
Power system
Motor: Kontronik Pyro 600-12
ESC: Kontronik Heli Jive 120HV V13
Main pack: GENs Aces 5300Mah 30C
Electronics
Cyclic servos: Align DS615 @ 6v
Tail servo: Align DS655 @ 6v
FBL Unit: Full Vbar Blue 5.3 With Pro
Governor: Kontronik Heli Jive Gov
TX: DX8
TM1000 Telemetry with RPM, Temp, RX Voltage and Flight Pack voltage sensors.
Flight style: 3D
Head speed: ????
Amp draw: ?
Upgrades
700E 112T helical main gear, 11T helical pinion, 12T Helical and 13T Helical
All 700 black gears.
Mikado Logo 800XXtreme, Vbar 5.3, 813mm Edge Blades, 14S Kontronik Cool Kosmik 200HV.
ALIGN T-REX 550E DFC with 600 Boom, 603mm Edge Blades, Kontronik Heli Jive 120HV, Pyro 600-12, Mini Vbar 5.3 Pro, V3 Tail, Black Gears, Many KDE Upgrades.
Nelvick is offline        Reply With Quote
Old 07-17-2013, 03:59 PM   #68
Jurica
Airframe
Kit: HK550 TT FBL
Blades: 550mm CF (idk what brand)
Tail blades: Align 85mm
Landing gear: black
Fins: Greenish/transparent thickened tail and horizontal removed
Canopy: 100% white & http://www.hobbyking.com/hobbyking/s...x_HK_550E.html
Power system
Motor: Turnigy T600 (1100kv)
Gearing: Stock
ESC: YGE 100A
RX power: 2s LiFe pack
Electronics
Cyclic servos: BL-83601 BLS MG HV 14.5kg / 0.13 / 56g
Tail servo: Mi HV MG 8.40kg / 0.03 / 61g
Gyro: BeastX
RX: Orange RX (works just as well as spectrum receivers, friends had less brown outs with them)
Flight style: 3D
Head speed: haven't mesured it.
Upgrades & mods
Helioption blocks, converted to belt using 600ESP parts, got an Align tail, Align gears, Compass FBL head, few other details
Align T-Rex 550 DFC SELLING
AccuRC
Spektrum Dx7s
Jurica is offline        Reply With Quote
Old 07-31-2013, 10:54 AM   #69
trexpro
Default Trex 550
Here's my baby
Airframe
  • Kit: officially V1 kit upgraded to V3 DFC rotor head main gear tail box and tail unit
  • Blades: Align 520mm
  • Tail blades: Stock 90mm
  • Landing gear: White Align 700
  • Fins: Fusano 2mm tail fin and metal lightweight tail clamp (no horizontal fin)
  • Canopy: Align Red and Black
Power system
  • Motor: 600MX
  • Gearing: Slant gear 112T main gear, stock 11T pinion gear ratio 1:10.18:3.85
  • Autorotation gear 131T
  • ESC: Stock Align 70 esc
  • Main pack: Zippy flightmax 6s 5000mAh 35C
  • Bec: Hercules 10A HC bec @ 6.0 volt
  • EC5 connector
Electronics
  • Cyclic servos: Align DS610
  • Tail servo: Align DS620
  • FBL: BeastX V3.0.12
  • RX: Futaba FASST R6008HS
Radio and RX
  • Futaba T14SG
  • R6008HS
  • Flight style: Sport
  • Head speed: Normal 1950rpm / Idle1 2100rpm / Idle2 2500rpm checked with a tachometer
  • Flight time: 10min
Upgrades & mods
  • Canopy stand-off
  • Ceramic main bearings
  • Qiuk uk metal lightweight tail clamp without a horizontal fin
  • KDE performance tail upgrade V3
  • RC Booya quick release canopy mounts
  • Metal vertical stabilizer mount Align
  • Metal anti-rotation bracket Align
  • Metal tail servo holder Align
  • Metal tail pitch slider Align
  • Metal tail bell crank Align
  • KDE metal battery mount upgrade
  • Carbon fiber tail servo push rod Align
  • Tail boom Align stock 550
  • 2mm vertical tail fin fusano Red
ID:	439939Click image for larger version
ID:	439940Click image for larger version
ID:	439941Click image for larger version
ID:	439942Click image for larger version
ID:	439943Click image for larger version
ID:	439944Click image for larger version
We Men Need a Second Hobby, Besides Women
Futaba, Vbar, Kontronik, Align, IKON, 3GX, Vario, WR Hercules
Mikado, Scorpion, BeastX, Gens Ace, Goblin, Hyperion, JetCat Turbine, APS, BD3SX
www.modelhelicopter-review.nl
trexpro is offline        Reply With Quote
Old 04-07-2014, 10:42 PM   #70
xrayray
I finally got my 550 flying the way I want and here's the setup.
Airframe
  • Kit: Stock v1 3G
  • Blades: Mavrikk G5 Pro FBL 550mm
  • Tail blades: Edge 90mm
  • Landing gear: stock
  • Fins: Fusuno G10
  • Canopy: Blue flames from helidirect I think..
Power system
  • Motor: KDE 600XF-1100kv
  • Gearing: Trex 700 helical 112T black main gear on KDE T700 universal main gear case, helical 13T pinion
  • ESC: YEP 150LV 18* timing and 9 pwm governor mode
  • RX power: Eflte 2s lipo 1300mah 20c
  • Main pack: Glacier 3300mah 30C for now
Electronics
  • Cyclic servos: Promodeler HV digital 140oz
  • Tail servo: Futaba BLS251
  • Gyro: Microbeast
  • RX: Spektrum AR7000 with satellite
  • Flight style: 3D
  • Head speed: 2500 governed
  • Flight time: 3 minutes
  • Amp draw: unknown
Upgrades & mods
Fusuno G10 side frames, Booyah canopy mounts, shaved servo spacers to fit 700E main gear (no frame cutting required), small BEC for the tail servo.
Team FlybarLESS
Trex 550e FL
Trex 450 pro DFC
xrayray is offline        Reply With Quote
Old 08-08-2014, 12:05 AM   #71
Scott1115
Airframe
  • Kit: Stock FBL v2
  • Blades: Align 3g FBL 550 (new design)
  • Tail blades: Stock 85mm
  • Landing gear: Stock
  • Fins:Stock
  • Canopy: Fusuno "Crackers"
Power system
  • Motor: KDE 600XF-1100-G3
  • Gearing: Helical 112T main gear, 12T pinion
  • ESC: HobbyWing 100A Platinum LV
  • Main pack: Pulse Ultra 6s 5000mAh 45C
  • Bec: Castle Creation BEC Pro
Electronics
  • Tail servo: Protek 230
  • FBL: vbar 5.3 pro
Radio and RX
  • Futaba 8FG
  • R6203SB
  • Flight style: aggressive sprt/Mild 3D
  • Head speed: Governed 0000/1850/2350rpm
  • Flight time: 5 - 5:20 min
Upgrades & mods
  • Aluminum tail servo mount
  • Aluminum anti-rotation plate
  • RC Booya canopy clips
  • HeliOptions main bearing block
Scott1115 is offline        Reply With Quote
Old 10-29-2014, 09:54 PM   #72
xrayray
My newest setup
Airframe
  • Kit: Stock 550E dfc but with a 550 tailboom
  • Blades: Align fbl 520mm
  • Fins: Fusuno G10 yellow tail fin, no horizontal fin
  • Canopy: 550E dfc stock
Power system
  • Gearing: Trex 600 helical 112T black main gear on KDE T700 universal main gear case, helical 11T pinion
  • ESC: YEP 150LV 30*timing and 9 pwm no governor
Electronics
  • Gyro: The mini k-word
  • RX: Spektrum AR6210with satellite
  • Flight style: 3D
  • Head speed: 2500 to 2400
  • Amp draw: unknown
Upgrades & mods
small BEC for the tail servo, v1 standard fbl head
Team FlybarLESS
Trex 550e FL
Trex 450 pro DFC
Old 12-13-2014, 05:57 PM   #73
mribeiro
Airframe
Kit: HK 550 Flybarless
Blades: RJX Vector 550mm
Tail blades: RJX Vector 85mm
Landing gear: stock
Canopy: Stock HK 550
Power system
Motor: Turnigy Typhoon 600H Heli Motor 1100kv
Gearing: Trex 550 170T, helical 16T pinion
ESC: Castle Edge 100 with Gov
Turnigy RotorStar Dual Power 15A Voltage Regulator
RX power: 2s lipo 1300mah 20c
Main pack: Turnigy 6000mAh 25C
Electronics
Cyclic servos: RotorStar RS 550MGC
Tail servo: Savox 1258
Gyro: Beastx
RX: Turnigy 9x
Flight style: Sport
Head speed: 1800 a 2300
Flight time: 4 minutes
____
HK 550e Flybarless
HK 450 pro DFC
HK 450 Flybar
mribeiro is offline        Reply With Quote
Old 12-14-2014, 06:32 AM   #74
"SkyNet"
Air Frame
Kit Trex 550E V1 Original box Modified V4 PRO
Canopy DFC Fusuno Mod. Tropic Thunder Upgrade
Align DFC rotor head Upgrade
Plate Align DFC Update
Pale Edge by 553mm by 52mm rope Upgrade
Tail rotor series Align DFC Update
Tail Tail Edge from 96mm Upgrade
Maingear 170T (original box)
Tail Gear 180T / 40T (original box)
Landing gear Align Mod. F3C Update
Align 600 tail pipe instead of the original 550 Update
Carbon Tail Contol Rod Upgrade
Tail fin Fusuno 2mm Upgrade
Aluminum support anti-rotation plate Tarot Upgrade
Support tail servo aluminum Tarot Upgrade
Upgrading the entire transmission with gears with high resistance (Color Black)
Power System:
Motor Scorpion 4025-1100Kv Upgrade
Revco Pinion Hard One with Mod .07 and 20T Upgrade
Esc Edge Hv 120 Amp Upgrade
Bec Gryphon Agena Hyper Hv 7 amps continuous and 15 amps of peak Upgrade
6s LiPo GigaPower 60c continuous and 98C peak
Electronics:
Servi Align Ds 610 for cyclic (original box)
Servo Align Ds 655 for the tail Update
Brain FBL system
Transmitter Aurora 9
Optima 9 receiver telemetry
Specifications (known flight)
Flight Style: Soft 3D and Acrobatic fast / aggressive
Rotor rpm Governed: Idle 1 2350 Rpm
Idle 2 2550 Rpm
Idle 3 2750 Rpm
Time of Flight: Variables between 3.30 minutes and 4:30 minutes
Amperage with sprocket 17T: Average 43 Ampere
Max 153 Ampere
Degrees maximum collective pitch and cyclic set:
Collective 13.5
Ailerons and elevators 13.5
Sab Goblin 570 12s with Brain
Msh Protos Max V2 with Brain
"SkyNet" is offline        Reply With Quote
Old 05-29-2015, 04:31 AM   #75
xrayray
My newest setup
Airframe
  • Blades: Align fbl 550
  • Tail blades: Align 85
  • Landing gear: 700 f3c
Power system
  • Gearing: Trex 600 helical 112T black main gear on KDE T700 universal main gear case, helical 12t pinion
  • ESC: YEP 150LV 18 timing and 12 pwm no governor
  • Main packs: Thor 5000 45c
Electronics
  • Cyclic servos: Promodeler HV digital 160 oz
  • Gyro: mini kbar
  • RX: Spektrum AR6210 with satellite
  • Flight style: 3D
  • Head speed: 2800 @ 13* pitch
  • Flight time: 3:40
  • Amp draw: unknown
Upgrades & mods
small BEC for the tail servo, Dominator FL head, 3mm Ti turnbuckes
Team FlybarLESS
Trex 550e FL
Trex 450 pro DFC
