Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-16-2011, 08:10 AM   #61
kdfi
thanks for the reply rotary guy! Mine arrives today..Hoping my tail lines up out of the box but if not, I'll do as you explained in your outstanding build thread...
kdfi is offline        Reply With Quote
Old 09-16-2011, 08:50 AM   #62
vteknical
Awesome job! I really hope Align Corp acknowledges your contribution because this could only help 500 sales.
The bitterness of poor quality, lingers long after the cheap price is forgotten.
Buy the best and only cry once!
vteknical is offline        Reply With Quote
Old 09-16-2011, 12:11 PM   #63
rotaryguy
Head build, install posted. Moving into electronics installation next, stay tuned!
rotaryguy is offline        Reply With Quote
Old 09-16-2011, 10:37 PM   #64
Deet
Do you know what the tooth count on the man gears is?
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 09-16-2011, 10:40 PM   #65
rotaryguy
134 mod .7
http://www.align.com.tw/shop/product...oducts_id=4065
Old 09-17-2011, 02:19 AM   #66
Gameburg
wow, it says it willalso work with ESP (together with the new pinion)
Also the tail will fit!!!
BR / Patrik
E-flite Blade Nano cpX, Align Trex 250SE, Align Trex 500ESP
Spektrum DX8+AR8000+AR7610+TM1000
Gameburg is offline        Reply With Quote
Old 09-17-2011, 07:12 AM   #67
Ktmheli
Rotary Guy you are doing a awesome job .....defintely will follow this for my build....waiting for it to arrive now...
Ktmheli is offline        Reply With Quote
Old 09-17-2011, 07:34 AM   #68
davehour
Rotaryguy,
I found the studs length of the short balls that are installed on the inner star of the swashplate to be too long, and were binding the center ball of the swashplate. I had to shorten each stud about 0.5mm in order to fix this.
Check yours just in case.
Great work!
David
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS
Blade mCPx 140mm boom, DX7
RealFlight 7
davehour is offline        Reply With Quote
Old 09-17-2011, 10:46 AM   #69
davehour
Hi again,
I noticed the swashplate that came in my kit has play.
Because I'm a Futaba guy, I have to use the upper mounting plate for the BeastX and the lower mounting plate for the Rx. I checked how tight both gyro mounting plates were on the frames and found the lower mounting plate tight but the upper mounting plate was with up/down play. The lower mounting plate is held by screws, and is sandwiched between the frames. But the upper mounting plate is only sandwiched between the frames and uses no screws.
In order to remove the play present between the upper mounting plate and frames, I drilled two holes similar to the ones in the lower mounting plate. I even cut the channels where the upper mounting plate goes so it could be removed as the lower mounting plate can. After installing the screws in the upper mounting plate, the up/down play was gone.
David
RealFlight 7
Old 09-18-2011, 11:09 AM   #70
rotaryguy
Originally Posted by davehour View Post
Rotaryguy,
Great work!
David
Good catch!
Although it was only just enough to make the swash ball feel a bit snug, backing out the 2 short balls I did feel the ball move easier. It appears that they put a little pressure on the plastic ball housing making it feel slightly tight. Either way I will go back and edit the swash assembly section to include your find and will shorten the two balls to match the stud length of the washout arm balls. I hope to get some electronics installed and posted later today....its been busy lately.
Thanks!
Old 09-18-2011, 07:22 PM   #71
smaze17
I gotta be honest....when I get up in the morning I actually look forward to opening this thread!!!
Here's what I do. Get up, eat breakfast, help my daughter get ready for school then open this build thread LOL
Love it man....awesome job rotaryguy!!!
I will be receiving my 500EFL kit this Friday. Really looking forward to getting into it with the help of this thread
S
Trex 700e DFC / iKON / CC ICE2 120HV / Align 700MX
Trex 450L Dominator / iKON / RCE-BL45X / 460MX
smaze17 is offline        Reply With Quote
Old 09-18-2011, 08:01 PM   #72
smaze17
Totally agree....they should absolutely compensate you for this thread and I am being deadly serious.
I will make sure the folks at Align know about this thread!!
S
Old 09-18-2011, 08:08 PM   #73
Ktmheli
S
I have copied the pics and all into a word doc. file for my build. Awesome stuff from rotary guy
Old 09-18-2011, 08:28 PM   #74
smaze17
Hi again,
David
Hi David. I think I understand what you did. Would you happen to have a photo or two to show what you did exactly?
Thanks man
-Spence
Old 09-19-2011, 04:23 PM   #75
Eckchaz
Just ordered mine as it only hit the UK a few days ago.. This thread has made me even more eager to start as its sooo much cooler than the ESP I have. Is the carbon boom a straight fit as I cant resist my fake carbon!!
Also, does the 500EFL have the same tail holding issues as the 600EFL when running a lower HS because of the lower gearing?
Eddie
Velocity 90 FBL - Trex600 LE FBL - Trex 500 EFL
All Beastx V3 and powered by a DX7
Eckchaz is offline        Reply With Quote
Old 09-19-2011, 11:16 PM   #76
rotaryguy
Thanks again for all the great comments - I am anxious to get more posted but its been really busy with work and family and I do not want to rush it. Besides, honestly I am in no real big hurry to fly anyway as I love building! I do have most of the electronics installed, wired and photos taken but I still have to get them off the camera, uploaded, create the post, etc, etc...I hope to get some of it up tomorrow, followed by vbar setup after so stay tuned!
Teaser shot...
Old 09-20-2011, 12:58 AM   #77
erni66
Vbar setup?!! I wana see that!! This is the best build thread that I ever see!! I almost done with mine!! Thank u Rotaryguy for ur help!!!
erni66 is offline        Reply With Quote
Old 09-20-2011, 01:37 PM   #78
davehour
Spence,
Below are a couple of pictures of my 500EFL Pro.
I did the maiden flight this past weekend. Flew it 4 times. Found the boom was moving out of the frames with everything tightened well. I do have the pirouetting speed lightning fast.
Very impressed! The heli feels smoooooooooth and quiet. The 500EFL Pro flies on rails and is very powerful with the included gear. Tail holds great and although I'm using the Align ESC without governor, the heli was flying as it was governed. Smooth, predictable and very agile. More agile than my great 600EFL Pro.
Giving a quick comparison to the ESP, with the same motor, the Pro feels more predictable, less affected by wind, and more responsive.
I'm using a BeastX. I used the inner holes of the servo horns instead of the outer holes as called by the Manual and was able to reach a proper setup with blue lights.
The recommended link lengths given in the Manual were dead on, and to my surprise, the cyclic servos with the metal servo horns, centered with little or no sub-trim (contrary to the 600EFL Pro Align servos using the metal servo horns).
Mods that I've done so far are:
1. Installed screws in the upper gyro mount because it had play on the frames, and needed the mount to be well secured because it's used for the BeastX.
2. Pinned the boom because it was moving out of the frames. Was it due to the fast lightning pyros I did, or because the frames don't clamp the boom well? We'll see as other start to fly theirs 500EFL Pro's.
Regards,
David
Name:	DSCF0102 (Large).jpg
ID:	254942   Click image for larger version
Name:	DSCF0109 (Large).jpg
ID:	254943   Click image for larger version
Name:	DSCF0112 (Large).jpg
ID:	254944   Click image for larger version
Name:	DSCF0122 (Large).jpg
ID:	254945   Click image for larger version
Name:	DSCF0127 (Large).jpg
Name:	DSCF0137 (Large).jpg
ID:	254948   Click image for larger version
Name:	DSCF0138 (Large).jpg
ID:	254949   Click image for larger version
Name:	DSCF0139 (Large).jpg
ID:	254950   Click image for larger version
Name:	DSCF0141 (Large).jpg
ID:	254951   Click image for larger version
Name:	DSCF0142 (Large).jpg
Name:	DSCF0143 (Large).jpg
ID:	254953   Click image for larger version
Name:	DSCF0144 (Large).jpg
ID:	254954   Click image for larger version
Name:	DSCF0147 (Large).jpg
ID:	254955   Click image for larger version
Name:	DSCF0148 (Large).jpg
ID:	254956   Click image for larger version
Name:	DSCF0150 (Large).jpg
RealFlight 7
Old 09-20-2011, 02:06 PM   #79
Eckchaz
Nice.. How come you aint got the carbon boom installed?? Dont tell me it dont fit now i've ordered that aswell!!
Eddie
Old 09-20-2011, 02:13 PM   #80
rotaryguy
CF boom fits just fine. Its actually carbon wrapped over aluminum like the larger booms.
