Go Back   HeliFreak > R/C Helicopters > 3D Printing
3D Printing Discuss 3D printed items and 3D printers as they relate to RC
Old 12-23-2015, 04:05 PM   #21
westayfly
Cool Not yet . . . but
I have decent 3d printing experience but they've mostly been just one piece prints. I think I'm working my way up because soon I'll be printing this:
https://pinshape.com/items/8490-3d-printed-walkera-runner-250-upper-racing-tray
This is my goal for 2016
westayfly is offline        Reply With Quote
Old 12-29-2015, 02:30 AM   #22
AntDX316
Originally Posted by apexx View Post
In my research, I believe you can even obtain 3d scanners that will scan an existing part into the required format, and then you can build a catalog of the parts you require. Of course this adds to the expense of the 3d printer setup.
Here is an example of someone who designed a quad and printed it for flight.
http://www.thingiverse.com/thing:10753
There are a couple other examples. In one a gentleman made his main blades, but they shattered upon impact, not good.
However gears, cases, landing skids, heads, could these be essentially manufactured in a home heli shop?
I know a maker bot is not inexpensive (about $2k for the current 2 head version), but I would be using it for other things as well.
http://store.makerbot.com/replicator-404.html
That's a wiser way than making it from scratch. You can take an original design then modify it up after scaling.
facebook.com/AntDX316
It's my responsibility to make sure it works and know what could go wrong despite what everyone else is saying because they do not see what I foresee.
AntDX316 is offline        Reply With Quote
Old 12-30-2015, 05:25 PM   #23
distructor
Just to prove the point this person built a 1/10 scale buggy using 3d printing.
http://www.thingiverse.com/thing:42198 looks pretty tough from the video.
I've printed a fair number of smaller widgets for my helicopters. Antenna guides, pushrod guides, receiver mounts, fuel tank mounts.
B450x, Chase360, Warp360, mini Protos stretched, Protos 500 stretched, NX4 gasser, Goblin 500 x 2, Century E640 stretched, MD7 and MD8.
distructor is online now        Reply With Quote
Old 09-25-2016, 09:25 PM   #24
CHATCHAIAPI
I printed bearing block for mini protos. more likely to damage when crashed.
CHATCHAIAPI is offline        Reply With Quote
Old 09-29-2016, 09:01 AM   #25
crimson66
Yes,
230s main frame supports,
Tail fin (custom design)
crimson66 is offline        Reply With Quote
Old 11-15-2016, 02:41 PM   #26
Ghostwhiper
I have printed a cooling shroud for the rotorstar gh56 motor running petrol in my TZ 50v2.
Was a big improvement over the original shroud but it still needs a couple of design changes but the cooling improved a lot.
Also printed a set of cdi brackets and a mount for the opto kill switch.
Used a malyan m150 i3 printer with abs filament.
ID:	680352   Click image for larger version
ID:	680353   Click image for larger version
ID:	680354   Click image for larger version
Ghostwhiper is offline        Reply With Quote
Old 11-17-2016, 01:57 PM   #27
Sowa
Nice! What material did you use for the shroud?
Edit: Nvm! Interesting abs is taking the heat. How many gallons through the shroud?
Protos 380 - Xnova 2820 - HW60V4 -Brain2
Goblin 570 - 91SRX Tareq - Hatori - Brain
Goblin 700c - TRM VX300se - TRM - Brain2
Protos 770 Max V2 - Xnova 4535 - HW160V4 - Brain2
Sowa is offline        Reply With Quote
Old 01-07-2017, 02:08 PM   #28
Squirrlybird
I know this thread is getting some age, but wanted to point this out for anyone who hasn't seen it yet...
Sent from my bag phone!
While driving, eating a sandwich, and flying my heli!
Squirrlybird is offline        Reply With Quote
Old Yesterday, 12:29 PM   #29
cmulder
Cool the subject will become more common
with 3d scanners becoming cheaper and better copying plastic parts will become easier and so more common.
This will allow to keep flying helicopters that lost there manufacturer support (cough thunder tigre).
I hope that in 2 to 3 years i will be able to print my raptor 30/50/60/90 frame parts
cmulder is offline        Reply With Quote
Old Yesterday, 01:57 PM   #30
JEEPWORLD2002
If you had this printer you would be all set to print and thing you need. Just different resin s I love that compressor impeller can withstand temp into 900 deg range n still function much better then it's metal counter parts. And at a third or forth the material cost plus machining time n labor plus saving of a stock room of inventory. Is Huge. Production ready parts in rapid time. It's a win win for any one with this printer can't wait to use one
Trex600n,Trex500,MR25,MikadoLoGo5003d/KDE,Goblin 380XNova,CastleCreations,Ys,JR XG8,Tags Mini XBus Dmss//FAA# FA3NYC9TAP. Keystone rc club.
JEEPWORLD2002 is online now        Reply With Quote
