Old 04-03-2015, 05:55 PM   #21
Russell Harding
Can you still actually find a GF kit? These are basically ancient technology. Get the 500 efl at least. A dfc or simply 500L is your best bet.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote
Old 04-03-2015, 06:03 PM   #22
Nikki5
ok thanks for the info.. i saw some cheap GF kit for $149 on ebay..with motor and esc
Nikki
Nikki5 is offline        Reply With Quote
Old 04-03-2015, 06:06 PM   #23
Russell Harding
You are still going to spend $200 to get it in the air... So now you're up to at least half the price of a new one and parts may be tough to find. Many are compatible, some are not.
Old 04-03-2015, 06:09 PM   #24
Nikki5
As its older and not same parts as newer i already cancel the idea
Old 08-01-2015, 01:41 PM   #25
AzHeliCrasher
So can someone clarify what parts the 500EFL Pro shares?
I'm interested in getting one but don't want to have parts availability issues.
Not really interested in the 500L due to the cost and reviews.
*Trex 550E, Beast w/Kontronik
*Trex 500ESP FBL Beast
*Previous helis: Trex 700LE-E,Trex 600 ESP, Trex 550, Trex 500 ESP, Trex 500CF, Trex 450 Pro, Trex 250, Blade 180CFX
AzHeliCrasher is offline        Reply With Quote
Old 08-01-2015, 02:37 PM   #26
AzHeliCrasher
Or I should ask what it doesn't share?
Old 08-01-2015, 02:39 PM   #27
Russell Harding
L vs EFL: head frames frame plates, head are all different. If not more.
Old 08-01-2015, 05:46 PM   #28
AzHeliCrasher
Ok thank you
Old 08-20-2015, 12:08 PM   #29
SumOFparts
Its very popular to change out the dfc head for the newer 'L' one.
- it lessens the harshness and crash damage....
But that would for me necessitate going back to the faster esp tt gear ratio....
And a taller main shaft....
Why so many previous - do you have something against helis?
Yeah - the dream realized - is not nearly as sweet - as when its shared....
SumOFparts is offline        Reply With Quote
Old 09-14-2015, 04:44 PM   #30
technut
I just received a Trex 500e. Start build tonight. Thanks for all the info and parts info...great job!!!
technut is offline        Reply With Quote
Old 10-07-2015, 10:45 AM   #31
coderzone77
I want to buy a tail boom for my 500EFL Pro... Someone knows if is it the same of the ESP model ?
coderzone77 is offline        Reply With Quote
Old 10-07-2015, 04:10 PM   #32
Gladius
Yep. The tail booms are the same on all of the 500 variants.
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3 <>
<> Builds in progress: Logo 600SX, KDS Chase 360 <>
*Spartan Vortex VX1e*
Gladius is offline        Reply With Quote
Old 02-26-2016, 08:16 AM   #33
HB870
I also just picked up a 500E on a deal. I also got a 3G head with it and built it with that head. I really like the way it fly's. I flew it with the stock blades first and then picked up some Edge 423 and it is more solid now. I put on PRO tail pitch slider and bell crank as there was a lot of slop in the tail blades. It is a fun size and EZ fit in a Jeep.
I just need to find a new canopy as this blue and white doesn't work with old eyes.
Buz HB870
HB870 is offline        Reply With Quote
Old 04-02-2016, 03:08 PM   #34
wrench567
Deciphering this 500 I have from the variant guide.
GF frame and belt tail tells me its the Q4 2007 version. But it has metal bearing blocks,aluminum anti rotation bracket, FBL all metal head, 70 amp Align ESC, Scorpion HK-3026 1600KV motor, metal tail housing and grips, and screw in canopy mounts.
I changed out the DS510 servos with S9257MG for cyclic and the Spektrum 5020 tail servo for an E-max ES9257 (cheap and only one on hand) servo. I also changed out the BX+/ 6200 for an Ikon and 2 satellites.
So I would say it is a highly upgraded Q4 2007 version. Would you agree?
Thanks for making this list.
Pete
I started with nothing and still have most of that left.
DX7, 450 Frankenbird, 500 Align, Blade Nano CPs, Blade Inductrix. Chase 360 on the bench.
wrench567 is offline        Reply With Quote
