Old 08-11-2008, 08:43 PM   #61
MavriC
Originally Posted by pwoodyp View Post
You wouldn't want to pee off your barber either..............
Laugh my a$$ off!
Rick.
Rick.
Heli Pilot, Engineer & Mechanic for Team Dirka Dirka!
MavriC is offline        Reply With Quote
Old 08-19-2008, 05:15 AM   #62
TomRex
Originally Posted by CHOPPER PATROL View Post
Furthermore after looking at your pic you can remove the bearing, machine screw for bearing, the upper and lower spacer, and the machine screws for those also. They are all doing nothing.
Been this way for two plus years! I think I'm the one who started the whole thing!
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote
Old 08-19-2008, 05:56 AM   #63
satchy
wont lose that heli very quickly Tom
"So What is 3D Flying"
Definition: 3D as applied to current rc helicopter flying is any maneuver that to be performed requires the constant harmonized input of three or more controls simultaneously while the maneuver is taking place.
satchy is offline        Reply With Quote
Old 08-26-2008, 07:15 PM   #64
Gary JP4
Tom, that ought to about offset the weight you added with the Chinese weight mod.
T-Rex 450 SE, 430L 13t, Align 35A ESC, 325 Pro, JR 6102DX6, GY401, 9650, HS-65MG'S.
Gary JP4 is offline        Reply With Quote
Old 08-27-2008, 07:02 PM   #65
CHOPPER PATROL
Tom, would like to see some pics of the heli, maybe in a new thread or direct me to a thread of pics with it. It looks as though it would be hot looking. Do you have this Chinese weight on this heli? I must read more on this to see what the advantages are, for example is it for beginners or experienced pilots or both, etc. TIA
Chopper Patrol
JR-XG14, JR Forza 700, Warp 360
CHOPPER PATROL is offline        Reply With Quote
Old 08-30-2008, 07:19 PM   #66
Gary JP4
Those 4 balls and screw on the sides of the blade grip holders are the Chinese weights mod. There is a long thread on it started by Fireup who popularized it and came up with a way to implement it on the Trex. It is called Tail Mod for More Consistent Piros/Backward flight . Check it out. Fireup offers a drill jig, drill and tap to do the modification too. You can find it in that thread.
It would benefit everyone in the since that it takes a big load off the tail servo. It will benefit more aggressive flier by helping make the tail hold during demanding maneuvers.
Old 08-30-2008, 08:06 PM   #67
CHOPPER PATROL
Thanks Gary for the simple explanation on the weight mod, I see it now, and will follow the link provided.
Chopper Patrol
Old 09-01-2008, 11:07 AM   #68
Gary JP4
GreenCello says in this thread that if you use the Greaser to lubricate bearings that it wont fit the smaller 4mm bearings in our Trex. If you remove the idler pulley which has a 4mm bearing in it and use it as an adaptor you can grease the smaller bearings.
Hmm, now where is that idler pulley it is in this box somewhere?
Originally Posted by GreenCello View Post
+1 on Goldslinger's reply.
BTW, should you invest in a Greaser, be aware that it works great on bearings down to 5mm in diameter. The 450 has lots of bearings that are 4mm. If you've removed the tail idler pulley, it has a 4mm bearing that removes easily. You can use the pulley in the Greaser as a holder to lube your 4mm bearings.
Old 09-01-2008, 05:08 PM   #69
CHOPPER PATROL
Good one.
Chopper Patrol
Old 09-01-2008, 06:43 PM   #70
Gary JP4
Found it. Yeah. So, yous guys that don't want to take the idler pulley off don't have a Greaser adapter for the 4mm bearings. See.
I got two. One stock Align and one MX-400 flanged one.
Now, If I just had a Greaser and some grease.
Happy Labor Day
Old 09-02-2008, 07:45 PM   #71
shield
T-rex 450SE V2, 250SE / Blade CX2, mCX, mSR, SR / Walkera 5G6, 4#3B, 4G3, CB100 / Piccolo Pro / Hornet II / HBK 2
shield is offline        Reply With Quote
Old 09-03-2008, 08:59 AM   #72
geoavia
shield, loool
Helis: TRex 450S all metal, TRex 500CF
Planks: EZ Star FPV mod, PA Katana mini
geoavia is offline        Reply With Quote
Old 09-04-2008, 03:14 AM   #73
lotaloi
I had a problem of the belt going off the pulley but heard from my fr it's because of too many flights in a nutshel it's gone worn out. Put on a new belt removed the idler pulley now working great up to present flight. Now I would say....if it works great without the pulley why we would keep it? It helps creating a resistance on the belt a little for sure.Loss of energy. So the more free ur belt is the smoother ur machine will work. THIS IS SIMPLE TO UNDERSTAND.
lotaloi is offline        Reply With Quote
Old 09-04-2008, 05:23 AM   #74
geoavia
Originally Posted by lotaloi View Post
...THIS IS SIMPLE TO UNDERSTAND.
..not for some aesthetes out here
Old 09-07-2008, 12:22 PM   #75
PyroM!KE
SO
PyroM!KE is offline        Reply With Quote
Old 09-08-2008, 06:52 PM   #76
borsato
Default Belt slipping
I wasn't sure about removing mine but after reading these posts and having my belt climb up and off the pulley I chose to take it off. As a matter fo fact. I took off the screw infront of it also and this seems to be the ticket. I lubed the belt with silicone shock oil from my rc cars and have not had any problems yet. I'm very happy. A simple mod with great results.
borsato is offline        Reply With Quote
Old 09-08-2008, 07:49 PM   #77
Felt
Has anyone ever removed their pulley from a copterx 450sev2? It sure looks like the belt will rub on that screw just forward of the pulley.
Felt is offline        Reply With Quote
Old 09-09-2008, 04:31 PM   #78
Mr.Andersen
Yes i did and had the same consernes as you but after a few flights the conserne went away.
There are no thread marks on the white text aeria on the belt but there are rubberresedues on the schrew.
As long as there is no threadmarks from the screw on the belt there is no problem with that close contact.
Logo 600SX
Warp 360
Chase 360
Mr.Andersen is offline        Reply With Quote
Old 09-10-2008, 11:55 AM   #79
thePreacher
I just took out my idle pully from my rex and had a few flights today and it flies beautifully. I found that it was at low rpms that my belt kept sticking to the side and giving me problems. It happend to me 3 - 4 times before i got fed up and decided to take the pully out. its defintely something worth while to do when u do get that problem
thePreacher is offline        Reply With Quote
Old 09-10-2008, 03:44 PM   #80
CHOPPER PATROL
Another believer!
Lets wait for V3 to come out and see that Align is also a believer.
Chopper Patrol
