Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 05-23-2014, 06:54 AM   #161
Soccerjay
Default How to canopy Painting
Originally Posted by snbartley View Post
Thanks. Been fun as always.
Im an idiot when it comes to painting but how did u get the planet on there? And the stars? The effect looks awesome
Sent from my Goblin 125 using SAB
"I fly because it releases my mind from the tyranny of petty things."
Jay Helifreak number: 189,781 Lynx Heli Innovations | ThunderPower RC
Soccerjay is offline        Reply With Quote
Old 05-23-2014, 08:19 AM   #162
snbartley
I made multiple stencils out of paper. Painted a blue background first. Put down a circle stencil and shade in what you want to make the round planet then a stencil for the rings shade to your liking. As for the stars if you turn the air pressure way down on an airbrush it loads up the tip with paint and when you quickly pull the trigger it splatters paint. Just do that over and over till you get the amount of stars you want. Check out YouTube search airbrushing planets. There is a ton of info.
You can't reason with crazy people!
snbartley is offline        Reply With Quote
Old 05-27-2014, 11:09 PM   #163
snbartley
All done. Now to just finish the build.
Old 05-28-2014, 06:37 AM   #164
Soccerjay
Wow shiny
Old 05-28-2014, 10:43 PM   #165
snbartley
Yep. Used the clear I sent you the info on. Works great.
Old 12-31-2014, 04:03 AM   #166
Frequency
Originally Posted by 22charlie View Post
Hey dude an awesome job! However I have my reservations about using 2pac stuff in the home environment because of the isocyanate in the brew.That stuff will eat your lungs out lickety-split so I am told and we should be using a rebreather type mask or a completley separate air supply with pump etc.The auto guys I know tell me that stuff is bad news if you get a sniff of it!
Looks to me you are only using a filtered mask,whch supposedly is not worth a cupfull of crushed ice on isocyanate. I do appologise for raining on your parade and I am probably dead wrong. Are you comfortable with this?
I would like to give the 2pac clear a go but 'am to scared to use the stuff. I want to live long and prosper if you get my drift.
I would like to hear other opinions on this subject from the pros out there.
Isocyanates are pretty nasty I sprayed rhino linings for a couple years and that stuff will soak through any open mucous membrane and through your skin if you don't wear gloves. We would be bad in the summer when it was super hot and just wear our half masks the 3m brand ones but you could feel your eyes sting. When it wasn't hotter than hell I wore a full face fresh air positive pressure mask. Be careful with just about anything two part or that smells really bad. Usually means it's really good material but awful for your health and if you're unsure read the Msds that will usually scare you safe.
~Synergy N7, YS91-3DS, IKONV2/BT XPERT SERVOS
~Synergy N5c TT, OS55-H, IKONV2
~Blade 180cfx
~Futaba T14SG
TeamXpertServos
Frequency is offline        Reply With Quote
Old 01-29-2015, 11:51 PM   #167
Woultand
Graco Magnum 262800 X5 Stand Airless Paint Sprayer is latest paint sprayer now-a-days. It includes 25 ft duraflex airless hose, 515 Reverse-A-Clean RAC IV tip, Pump Armor storage fluid , Operational DVD and Quick Start-up Guide. It is easy to use and clean.
Woultand is offline        Reply With Quote
Old 02-09-2015, 11:40 AM   #168
Fune
Default First paint
Hi there,
One friend make fiberglass canopy for my heli and I like maybe possile airbrush, you post is very help, but I have ones questions, in my country not can get the primer white only gray, and I think mabe used this first and and fine tune the canopy, and then apply spray white matt or glossy white I think better the matt but not sure which one to use, and possible use this as a base. But I don't sure this.
For the design and this paint with airbrush acrylics paint and the finish used spay gloss.
I aprecciatte you help and attention.
Thanks,
Luis.
Fune is offline        Reply With Quote
Old 04-06-2015, 04:47 PM   #169
Serious power
Hi,
That is very nice work.
Brian
Serious power is offline        Reply With Quote
Old 04-10-2015, 10:26 PM   #170
snbartley
Default Grey vs white
Luis
You can use gray no problem. I actually like using gray so when I paint the base color of white I can see that I am getting a complete cover. Use the same paint you will do the rest of the painting with and use flat. Easier to get an even cover with and the clear in the end will give you the gloss you want anyway. Just may thoughts. Best of luck on the painting.
Thanks Brian was fun doing it.
Old 05-22-2015, 03:17 AM   #171
jangee
Awesome
jangee is offline        Reply With Quote
