Go Back   HeliFreak > R/C Helicopters > CAD/CAM
CAD/CAM R/C Helicopter CAD/CAM
Old 05-30-2014, 04:13 AM   #21
ScotY
What do your cutting bits look like? And what's the PCD coating? Is it a diamond type finish?
ScotY is offline        Reply With Quote
Old 05-30-2014, 04:25 AM   #22
Dylwad
Default Re: CNC Cutting Service...
For carbon and G10
http://pages.ebay.com/link/?nav=item...101861&alt=web
Polycrystalline diamond http://www.hamprecision.com/HAM_Milling_Diamond.asp
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote
Old 05-30-2014, 05:17 AM   #23
osat
Hi.
You are doing something wrong that carbide tools don`t last longer.
I use 0.8 and 1.5mm carbide cutters with diamond and coating and last for 12-20 hours for 0.8mm and 18-24hours for 1.5mm no problem, with perfect results.
I cut mostly CF and GF, and little of plywood and balsa with those cutters.
I had carbide cutters with no coating but it looses sharpness after 2-3 hours. If edges are not that important it last at least 8 hours if you are adapting feed rate even more.
I use double site tape as well but I never cut through tape because tape close cutting edge of the tool, there come to much resistance on the tool and brake.
Other possible reasons for braking are:
-not enough rpm
-too much feed
-you take to much material at once
-machine is not rigid enough
-accelerations are to big (if machine is not rigid enough is this a big problem)
-hard lead in on toolpath, (use lead ins or ramping to cut in the material)
-If tool don`t spin centered that reduces tool life.
Here I buy my tools: http://www.sorotec.de/shop/index.php...-Fraeser.html/
Hope that helps.
Best regards.
osat is online now        Reply With Quote
Old 05-30-2014, 05:18 AM   #24
fastpcuser
Ok... Here are some pictures...
these are frames for Jr Vibe 90SG and Jr Vibe 50 NEX
Name:	DSC01166 (Medium).jpg
ID:	512439   Click image for larger version
Name:	DSC01167 (Medium).jpg
ID:	512440   Click image for larger version
Name:	DSC01169 (Medium).jpg
ID:	512441   Click image for larger version
Name:	DSC01170 (Medium).jpg
fastpcuser is offline        Reply With Quote
Old 05-30-2014, 05:38 AM   #25
Dylwad
Originally Posted by osat View Post
Hi.
-not enough rpm
-too much feed
Hope that helps.
Best regards.
I can cut for days with the same bit in GF, it's the CF that wears them out fast. Kyocera bits are cheap, I have tried many different strategies and settled on where I am at. Machine is rigid, accel tuned for the small parts, runout is good.
What feeds and speeds do you use on CF with uncoated carbide?
Old 05-30-2014, 05:53 AM   #26
Dylwad
They look great!
6K twill weave? Where do you get the carbon sheet? is one side textured?
Old 05-30-2014, 06:22 AM   #27
osat
CF:
Diamond coated:
0.8mm 24000rpm, feed 1000mm/min, Depth of cut/pass: 1/2 D (0.4mm) strategy: constant z machining >spiral
1.5mm 18500rpm, feed 3500mm/min, Depth of cut/pass: ~1/2 D (0.8mm) strategy: constant z machining >spiral
CF:
Carbide not coated:
1.5mm 18000rpm, feed 2500, Depth of cut/pass: ~1/3 D (0.55mm) strategy: constant z machining >spiral (I don`t use them any more for CF)
As I wrote your problem is probably cutting double site tape!
That data I wrote is for perfect finish
Old 05-30-2014, 06:42 AM   #28
Dylwad
CF:
Diamond coated:
CF:
Carbide not coated:
Thanks!
I am running very close to the same chip load, much slower speeds and feeds, similar strategy. The tape I use is .09mm thick, and I get the same results cutting through it or just up to it, actually get the best results when the final pass is .2mm deep into the sacrificial board.
Old 05-30-2014, 06:48 AM   #29
osat
Here is one of my projects:
Name:	18072010202 (Custom).jpg
ID:	512445   Click image for larger version
Name:	milli 001 (Custom).JPG
ID:	512446   Click image for larger version
Name:	milli 003 (Custom).JPG
Old 06-01-2014, 04:44 PM   #30
fastpcuser
Originally Posted by Dylwad View Post
They look great!
These are only 3K but I will get 6K in future. I get my CF out of china but it is 100% CF no Fiberglass sandwich...
These have glossy finish on both sides.
Old 06-22-2014, 09:51 PM   #31
petertha
That's really impressive. Did you make the aluminum parts as well? Maybe you have a build thread or description somewhere of what the model is all about? I'd like to learn more.
petertha is offline        Reply With Quote
Old 06-23-2014, 06:33 AM   #32
osat
Hi petertha.
Aluminum parts are made at work on HS milling machine, all CFK parts are made on my CNC router at home.
This is (almost all part) conversion from nitro robbe millennium 90 helicopter to electric.
I have no build treed about it but i can give you some info.
Basic for build was main drive train. I add trust bearings on main shaft and make it rigid as much as possible with no play in links and adjustable tracking on the tail to eliminate all possible vibrations. Every thing else was build around that to fit.
It was my first FBL heli and still my favorite one.
Setup at the moment:
-Radix 710 V2
-Edge 105
-Scorpion HK-4035 560KV
-PowerJive 120-HV
-AC-3X FBL
-BLS 251 1x
-DS 8717 3x
-JLog 2
-Jeti DS-16 radio with RSat2
-With Turngy Nanotech 4000 12S (2x6s) it weights 4.7kg
At the moment I`m designing stronger main gear (I have striped 2 gears this year)
ID:	517743   Click image for larger version
ID:	517744   Click image for larger version
ID:	517745   Click image for larger version
Old 07-07-2014, 06:29 PM   #33
corona007
Ha! if only the shop was that clean right now
Cutting Carbon is no fun, it wears out carbide bits fast, I am lucky to get 10 minutes out of a 1mm bit, 25 minutes out of a 1.6mm bit. I can go through 15-20 bits cutting parts from a 12x12" sheet of .8mm carbon. Larger production shops use PCD coated bits, which are $$$ but last a whole lot longer.
Wow, You go through bits pretty fast...
I used 2 bits 1) 1/32" 1) 1/16" to cut everything in these pic.
I also used the same bits to cut rev one of my vibe but that doesn't count since it was G10.
http://helifreak.com/album.php?album...ictureid=87123
ID:	520631   Click image for larger version
Wooohoo....
corona007 is offline        Reply With Quote
Old 08-01-2014, 11:23 PM   #34
fastpcuser
My Cnc Service is still available
Old 08-04-2014, 12:21 AM   #35
fusionsx00
i need a motor mount with a heat sink , only problem is heat sink will be 35mm deep.
it can be cut from the side which is 9.5mm deep
the space between the fins can be increased or decreased for easier cutting.
any of you guys have experience with that?
fusionsx00 is offline        Reply With Quote
Old 08-08-2014, 04:51 PM   #36
prototype3a
Do you have a render of the part?
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL
prototype3a is offline        Reply With Quote
Old 08-11-2014, 12:40 PM   #37
RMcQuillen
PM Sent
RMcQuillen is offline        Reply With Quote
Old 07-11-2016, 01:40 PM   #38
strad68
Default Cutting jobs
Looking to have some parts machined. 2mm, about 8x14, I'd like to email a DXF to anyone offering affordable services.
strad68 is offline        Reply With Quote
